Emoticons acting funny???
 Post subject: Emoticons acting funny???
PostPosted: Tue Aug 31, 2004 11:46 am
Is it just me or does some of the Emoticons not work?
I some of my recent replies I've noticed that only the "regular" smiley seems to come out right with the rest of the emoticons appear as code.
Is it just me? Or could some of the emoticons have been somehow erased from the server???
Here's a quick test: ?:) ?:p ???? ?:cool: ?:;):
Cheers!
Edit: Odd... Now they all seem to work, but I've often had problems with Cool, toungesmiley and laugh...
PostPosted: Tue Aug 31, 2004 3:26 pm
I just type them in manually. I memorized "the codes" ... previous occupational hazard ... :;): ?Otherwise I have had a few problems too using the "quick post" option ! :o
PostPosted: Tue Aug 31, 2004 4:31 pm
Interesting, I have not had any problems, but I do not use the "Quick Reply" option. (Old Habits die hard  :laugh: )
dafrca
              - Cities of Death, page 59
PostPosted: Tue Aug 31, 2004 4:44 pm
Yes I have also had problems with the Emoticons not showing up right, but only in the quick post, not the regular reply section.
my 2cents,
iblisdrax
PostPosted: Tue Aug 31, 2004 4:52 pm
Aye, I've posted about this before, seems that it's happening again, and yes, it does seem to be the quick post option.
PostPosted: Tue Aug 31, 2004 5:36 pm
Well, you know emoticons, they are so... well... emotional.... :;): :p
PostPosted: Tue Aug 31, 2004 11:57 pm
Just a quick test. SOme random smilies: :p :angry: :;): :laugh: :O
Do these work? If you are getting the IB code for the smilies, then it is a problem with the board code running, and not the server exactly...
EDIT: Seems OK for me. I would guess that there is a problem with your machine accessing the full code of the board (including the code which substitutes the smilies for the short code). Does this happen at a particularly busy time for the internet?
PostPosted: Wed Sep 01, 2004 3:30 am
They all seem fine CS. :)
PostPosted: Wed Sep 01, 2004 3:07 pm
Test:) :( :D test spacer:p :cool:
www.darkrealmminiatures.com
PostPosted: Wed Sep 01, 2004 3:09 pm
Hmmm...
From that it seems that when you quick reply it doesn't put the space it needs before each emotion- I hadn't noticed this because I usually check a post first and put them in....
PostPosted: Wed Sep 01, 2004 3:13 pm
Yes, I noticed that a "space" is required ...  :D  :;):
PostPosted: Wed Sep 01, 2004 3:28 pm
Yup, that's what I've started to do too.
To borrow the immortal words 'it works'
PostPosted: Wed Sep 01, 2004 3:44 pm
"Indeed"  ???  Learn by doing ! :;):
PostPosted: Wed Sep 01, 2004 10:23 pm
Quote (stormseer @ 01 2004 Sep.,07:09)
Hmmm...
Interesting, so the Quick Reply does not add the space but the normal reply does?
dafrca
PostPosted: Thu Sep 02, 2004 1:31 pm
Yes, that seems to be it.
