Colours are go
 Post subject: Colours are go
PostPosted: Fri Feb 14, 2003 6:26 pm
OK, I have allowed users to change the colour schemes with which they view these boards. This will allow them to (ultimately) tailor the boards to fit the site that they arrive from. Currently, all I have done is allow them, I have not actually set them up with colours yet!  :p
So, this means that if you view the board using different colours, they will be half done, or in some cases a lot less.
There are (will be) four schemes:
EpiComms1 - This is the now familiar blue/purple background, with black and grey. That has been set up for a while ow, and so wont change over the coming weeks.
DotCom - This is the mask for www.epic40k.com visitors. I started this, by making everything white, and didnt get much further. It is currently being modified.
NetEpic - This is for, guess what..., NetEpic visitors. This looks strikingly like the EpiComms1 colours, mainly because right now it is. I have simply copied the first colour scheme and renamed it. I will start changing this around later.
Standard Ikonboard Skin - I cant delete this, so I will use it. Currently it is at the factory setting of pastel blue. I will mess around with this as I go. the aim is to use this scheme to create a neutral set of colours which will fit in with all three sites.
So, over the next few weeks, I will mess around with these colour schemes. This will have two results. Firstly, the colours will change slowly, and at times may not fit together very well. Also, some parts of the board may be one colour while other parts are another set. I will try to keep this as tasteful as I can, but I make no promises!  :{
In addition, I will be working on the three schemes all at the same time, so it may take longer than it should. Please bear with me. I will have this place looking the best I can, as quickly as I can.
Thannks.
