text field issue when typing posts
 Post subject: text field issue when typing posts
PostPosted: Tue Jan 29, 2013 11:52 pm
When I post a reply (particularly if it's a quoted reply) I get an extremely annoying situation where if I try to highlight a line or two to correct/change etc the text field screen keeps skipping upwards so I lose sight of the lines I'm trying to write on. No matter what I do I cannot keep the field at the place I'm typing. I have to manually scroll down to get back to the line and then it skips up again.
Is this a known issue? It's bloody irritating!
 Post subject: Re: text field issue when typing posts
PostPosted: Wed Jan 30, 2013 9:30 am
Try enabeling the "Compatibility View" feature on your browser, the icon looks like a page that is ripped in half.
PostPosted: Wed Jan 30, 2013 11:34 am
Dobbsy wrote:
When I post a reply (particularly if it's a quoted reply) I get an extremely annoying situation where if I try to highlight a line or two to correct the text field screen keeps skipping upwards so I lose sight of the lines I'm trying to write on. No matter what I do I cannot keep the field at the place I'm typing. I have to manually scroll down to get back to the line and then it skips up again.
This is a new one to me....
PostPosted: Wed Jan 30, 2013 1:13 pm
There is a Danish warhammer forum called http://www.powerfist.dk, where we had what sounds like the same issue that you discribe, and one of the Admins created a guide to fix this, please check if its the same issue.
(I have translated the page in Google, so the website should show in english and not in Danish)
http://translate.google.dk/translate?sl=da&tl=en&js=n&prev=_t&hl=da&ie=UTF-8&eotf=1&u=http%3A%2F%2Fwww.powerfist.dk%2Fforum%2Findex.php%3Ftopic%3D36528.0&act=url
PostPosted: Wed Jan 30, 2013 2:32 pm
Which browser are you using Dobbsy? If it's IE, then there are sometimes compatibility issues with some forum software, so you can either switch to compatibility mode as suggested above, or try using a different browser.
SoƱando con una playa donde brilla el sol, un arco iris ilumina el cielo, y el mar espejea iridescentemente.
cron
