TacCmd RSS Feed
 Post subject: TacCmd RSS Feed
PostPosted: Thu Sep 15, 2011 11:32 pm
With huge thanks to Jodrell, who sent me the quick setup for this, the RSS feed for these boards is now up and running. You can point your RSS readers to:
feed.php
 Post subject: Re: TacCmd RSS Feed
PostPosted: Fri Sep 16, 2011 8:42 am
super! :)
An online epic force creator:
Armyforge
PostPosted: Fri Sep 16, 2011 8:53 am
Awesome!
Now if I only knew what this was or how it worked I be even more stoked! I see the little RSS logo alot but that's my knowledge on the subject! LOL!
PostPosted: Fri Sep 16, 2011 9:25 am
check out google.com/reader...
Armyforge
PostPosted: Fri Sep 16, 2011 9:28 am
:D
1. Download and install an RSS aggregator. I use Klipfolio, but a lot of web browsers do this for you too.
2. Add the web address to the aggregator. You can add many RSS addresses to the same aggregator.
3. The aggregator will then update you with all the new posts, sent directly to you, with links to click on to take you to the post if you want to read it.
PostPosted: Fri Sep 16, 2011 9:46 am
By the way, you can also get feeds for an individual forum or topic:
feed.php?f={forum id} - forum feed
feed.php?t={topic id} - topic feed
Examples:
feed.php?f=7 - Epic 6mm Feed
feed.php?t=21369 - Feed for this topic
PostPosted: Fri Sep 16, 2011 9:53 am
I should probably put a footer image to RSS subscribe to that page (forum/topic). Not too difficult, and I will add this to the todo list for next week.
PostPosted: Tue Sep 20, 2011 10:40 am
If I might be so bold as to offer a suggestion, a function to like or thank for a post would be nice (o:
Let there be code.
PostPosted: Fri Sep 30, 2011 10:56 am
This would be really helpful, I just encountered exactly the problem of how to feedread Taccom while searching for this tiny icon. Luckily I found this thread before giving up ... Cheers, keep up the good work :)
Tale of Epic Gamers - Beginnings of my Guard Army
PostPosted: Fri Sep 30, 2011 11:46 am
You should now find a 'feed' link at the top of the page when logged in on all threads and boards.
It is the last option, after 'email friend' in the thread views at the top of the page, and above the 'subscribe' option in board views.
PostPosted: Fri Sep 30, 2011 11:49 am
The icon seems to be missing: the <img> tag points to http://www.tacticalwargames.net/images/feed_taccmd.png which doesn't exist.
PostPosted: Fri Sep 30, 2011 11:53 am
Yeah. The feed wasnt working inititially as it default to http://www.taccmd.tacticalwargames.net/taccmd
So, I had to delete the second 'taccmd'. Should work now.
