Adding to the Calendar
 Post subject: Adding to the Calendar
PostPosted: Wed Nov 18, 2009 1:10 pm
CS, since the update I don't see anyway of adding events into the calendar?
I'm sure there used to be an option when you created a new post to add an entry in the calendar but that seems to be missing?
PostPosted: Thu Nov 19, 2009 12:54 pm
Hi. Thanks for pointing this out.... I dont quite understand what is happening. The calender is enabled, and that should mean that the option comes up with a new topic.... but it doesnt.
Of course, I would check the support forums and documents.... but they were taken down about a year ago! I am becoming increasingly disillusioned with this board software.  :sad:
PostPosted: Fri Nov 20, 2009 5:03 pm
Interestingly, if I edit a topic that has already been posted, I can add a calender event that way!
