Signature
 Post subject: Signature
PostPosted: Fri Jul 18, 2008 12:14 pm
Use the 'tinyurl' website.
You enter the long url you want, and it gives you a routing address that is only 10 or so characters long.
PostPosted: Fri Jul 18, 2008 1:53 pm
I've updated mine to the new board syntax / addresses.
PostPosted: Sun Dec 07, 2008 6:39 pm
When someone post a message, there is no clear separation between the message and the signature. So sometimes, it can be very confusing.
Can this be fixed ? (by adding an empty line or a "___" between messages and signatures)
PostPosted: Sun Dec 07, 2008 6:49 pm
You don't see a thin, green line separating messages and signatures?
I see it in all posts I've looked at.
It should be right here:
V
PostPosted: Mon Dec 08, 2008 11:54 am
I think that this may be a browser issue. If I remember correctly, pixelgeek posted a similar question.
Also, check your settings. If your account has pictures turned off (I think!) it doesnt show... or something like that.
PG.... What did the problem end up being here?  ???
PostPosted: Mon Dec 08, 2008 6:09 pm
Quote: (Hena @ 18 Jul. 2008, 01:14 )
Any good ways to solve this (cranking up the limit is not that good way)?
Use TinyURL.com to create shorter URLs
PostPosted: Mon Dec 08, 2008 6:10 pm
Had to do with the profile settings. I had "hide signatures" turned on and it was hiding the line but not the signatures. :-)
I think it was a problem with the old sigs that were ported over not registering as sigs.
So when I enabled it the line showed up again.
PostPosted: Tue Dec 09, 2008 2:16 am
Problem solved ! Thanks !
In Account Options : "Display member's signatures when viewing posts?" => YES
If "NO", no green line between messages and signature, and also no "Quote" grey box (not great to identify quoted text and new comments !)
