Quick post error
 Post subject: Quick post error
PostPosted: Wed Jul 09, 2008 6:28 pm
Quick post generates an error when I attempt to use it that blocks it from functioning
Error: syntax error
Source File: http://www.tacticalwargames.net/forums....st=Drop me a line if you want some %27Nids :-);
Line: 1, Column: 50
Source Code:
PostPosted: Thu Jul 10, 2008 8:22 pm
yup, same here, have to use add reply instead. still, it's not too hard to live with once you are aware of the problem.
regards
jim
PostPosted: Thu Jul 10, 2008 10:49 pm
I will investigate. Thanks.
PostPosted: Sat Jul 12, 2008 4:09 pm
Here is another weird one for you, CS...
SOMETIMES when I reply to a PM, the reply button disappears and won't come back.  It works fine on some messages but not on others.  I haven't been able to ID any sort of pattern.  Odd.
Here is what it looks like.  The buttons actually appear briefly but then vanish.  :O
PostPosted: Sun Jul 13, 2008 6:02 pm
Yes "Quick Post" doesn't work but "Add Reply" works.
