New Posts
 Post subject: New Posts
PostPosted: Fri Aug 17, 2007 2:43 pm
Hi. I occasionally get emails saying that the New Posts feature is acting strange. Now, I dont use this, and when I try it out, it seems to be working fine.
Is anyone currently have trouble with this?
What problems have people had in the past?
Thanks.
PostPosted: Fri Aug 17, 2007 2:47 pm
Always use it, Always fine.
But note:
when someone votes in a poll but doesn't post in that thread the thread still jumps up in the new posts screen.
So you can see where the latest vote has happened.
Light at the Horizon.
Warp Rift
Project Distant Darkness
Eldar MMS
GothiComp Hall of Fame
PostPosted: Fri Aug 17, 2007 3:13 pm
I always use it. I discovered that the only time I have problem with it is when I change the date on my computer (which I do once every three months), in which case it's back to normal in a day or two.
If you're wondering why I change the date on my computer, I can explain it if you want me to.
PostPosted: Fri Aug 17, 2007 4:17 pm
No problemo over here.
Back from oblivion (again)?
PostPosted: Fri Aug 17, 2007 7:36 pm
No problem using it.  Ever.
PostPosted: Sun Aug 19, 2007 1:51 pm
I always use it. I have actually had some problems recently... figured it was just my end somehow?
'The server at www.tacticalwargames.net is taking too long to respond' I just hit 'Try again' and it works then...
