Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4, 5
Can you turn back time? I believe you can!
 Post subject: Re: Can you turn back time? I believe you can!
PostPosted: Wed Apr 23, 2014 2:06 pm
The Bissler wrote:
I just selected a European time zone in the end. This fixed the clock but the problem I have is that all posts are now displayed in German! This is useless as they only taught French and/or Spanish at my school.
Note: only one of the two points stated above is true.
Sorry to hear they did not teach French/Spanish at your school Bissler.
PostPosted: Thu Apr 24, 2014 9:14 am
Il me semble que vous avez volontairement mal compris moi ! Comme vous pouvez dire mon grade standard français a m'a été fort utile. Il y a eu quelques occasions où il est venu en utile lors de l'imputation sur les forums ! Jamais dans la vie réelle.
PostPosted: Fri Apr 25, 2014 4:35 am
Google translate is fun ;D
PostPosted: Fri Apr 25, 2014 7:50 am
Hena wrote:
No eikun vaan yrittämään tämän kääntämistä ja sittenpä ehkä huomaat miksi suomen kieli on hiukka epäreilu tietokoneille. Tämä on kuitenkin yksinkertaisesti kirjoitettua suomea ilman mitään yrittämistä tehdä kovin vaikeaa tekstiä.
"I took them, but try this translation and Then I maybe you'll realize why the Finnish language is a particle unfair computers. However, this is simply written without any attempted Finnish"
;D ;D ;D
I wonder if my French message made as much sense as this did when translated!
PostPosted: Fri Apr 25, 2014 8:07 am
Nobody can compare online translators until you have wrestled with Vietnamese! Seriously, the language uses the (mostly) Roman alphabet, and there still is not a single decent translator online, meanwhile the various Chinese languages and dialects seem to be not too bad with international translators. I just dont understand it.
Oh year..... time stuff....
Kyrt wrote:
So, the server clock is wrong and must be changed to fix the problem "properly". If you're concerned about having to change it twice a year, bear in mind that if the server is set up correctly to use an NTP server, it should not be necessary to change it manually. Are you on a completely self-managed system? If not, maybe you can just bounce this one to the hosting provider with a link to this post?
Unfortunately, we are on an entirely self-managed server... So I have no-one to blame but myself! It does mean that we have unlimited bandwidth and space though, so there is that.
I need to go into the server settings shortly anyway, so I will have a poke around (stop sniggering at the back!) and see what else I can break while I am there.
PostPosted: Sun Apr 27, 2014 6:30 am
OK... I THINK that I have set the server to UTC... Has that made any difference at all?
PostPosted: Sun Apr 27, 2014 7:49 am
OK.... That didnt work, so I resync'ed the clock on the server and that seems to have done the trick.
PostPosted: Sun Apr 27, 2014 6:31 pm
Let's have a look and find out.
The time is now correct, for me at least, thank you CS :).
PostPosted: Mon Apr 28, 2014 5:15 am
Hena wrote:
In case you didn't just do it, I'd suggest using ntp.
http://www.pool.ntp.org/
Yes, that's exactly what I used. :D
