Post new topic Reply to topic  [ 77 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
IMPORTANT
 Post subject: IMPORTANT
PostPosted: Wed Jul 02, 2008 12:05 pm
Sorry mate but they are smaller by about half the size.
My head is full of War...
PostPosted: Wed Jul 02, 2008 12:33 pm
To clarify, you mean that the images that I am seeing are half the size that you posted them, or that the images that you are seeing are half the size of the images that I am seeing?
PostPosted: Wed Jul 02, 2008 12:42 pm
The images that I posted are half the size of the same images that you have posted.
PostPosted: Wed Jul 02, 2008 1:31 pm
This could be one of two things. These boards scale images, depending on your monitor resolution, and some images are clickable for the full size version. The fact that the images that I see are larger than the ones that you see, makes me think that this is an issue with either your account here, or the computer that you are using.
What is your monitor resolution?
PostPosted: Wed Jul 02, 2008 1:48 pm
The resolution for the screen and monitor is 800x600
PostPosted: Wed Jul 02, 2008 1:54 pm
That is probably it. My resolution is set at 1280 x 1024. Do you have access to a larger res screen/computer to check this?
You can take a little comfort in the fact that we can see your pictures better than you can!  ???
PostPosted: Wed Jul 02, 2008 2:10 pm
If I change my screen resolution to 1024 x 768 pixels (maximum) will this improve what I see here, image wise?
Why has it changed since update?
PostPosted: Wed Jul 02, 2008 2:24 pm
I think that it probably will help (if not, let me know). The boards have an added scaling feature, which stops a single page running twice the width of your screen which then also allows text to do the same and makes reading difficult, and this is a recent addition.
PostPosted: Wed Jul 02, 2008 3:14 pm
Hi CS,
I change my screen resolution to 1024 x 768 pixels (maximum) and downloaded image from my computer using 1024 x 768  and still the picture is too small. (From my perspective)
Before update I was downloading at 800x600 and the image filled the screen. Could it be something to do with the account?
Thanks for all your help so far.
PostPosted: Wed Jul 02, 2008 5:45 pm
Heya CyberShadow, some of the guys don't realize the boards are back at this new URL. The old URL gives this error:
"Not Found
The requested URL /cgi-bin/forum/ikonboard.cgi was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request."
Would it be possible to make a forwarding page at the old address, so people know where to go?
PostPosted: Wed Jul 02, 2008 7:11 pm
YEp ! O-Man sent me the link !  And here I Be ! :D  Great Job C/S ! :hi:  Much appreciated as always ! 8v)   U Da Mann ! :vD
PostPosted: Wed Jul 02, 2008 8:24 pm
1. Sticky threads older then 30 days seem to dissappear. I guess that is not the intention with sticky threads.
2. The forum is slower then the old one. When I open a thread it takes a little time more in my perception to show everything in it.
Light at the Horizon.
Warp Rift
Project Distant Darkness
Eldar MMS
GothiComp Hall of Fame
PostPosted: Wed Jul 02, 2008 8:56 pm
CS, even better would be a mass emailing to all members.  I haven't ever seen an email from TacCom so I doubt anyone would feel annoyed by it.
FYI the Quick Post still doesn't work for me (and I am using the favored IE).
PostPosted: Wed Jul 02, 2008 9:24 pm
Warhead - I checked... The boards are set to resize pictures to a maximum file size. So, if the maximum post size is 150Kb, any pictures are automatically resized to meet this minimum.
O-Man - The redirect is something that I have on the list to sort out. In the meantime, I have added a temporary solution. Let me know what you think.
blackhorizon - The pinned thread over 30 days issue is something that I am already contacting the board developers about. I will sort this when I can. These boards should actually be faster than the old ones. I have not found them slower - Anyone else have this problem?
Moscovian - I am against mass-mailing people as a general rule. The Quick Post thing is still under investigation.
Thanks guys.
PostPosted: Wed Jul 02, 2008 10:28 pm
That should work nicely. You're the greatest CyberShadow evar!
