Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Can you turn back time? I believe you can!
 Post subject: Re: Can you turn back time? I believe you can!
PostPosted: Wed Apr 02, 2014 8:21 pm
I have had the same problem with the clock, i followed CS's advise and took a look in the user preferences and found that i needed to choose central european time in order to get the clock right.
PostPosted: Wed Apr 02, 2014 8:30 pm
I selected BST. I'm not a European yet. This is too confusing. I need help.
But then, you all knew that.
PostPosted: Thu Apr 03, 2014 9:38 am
Yes I don't think the forum is set correctly. The clock, the timezone and DST settings all need to be set consistently, if you adjust the forum time by changing the timezone for example then it won't work correctly for all the members.
PostPosted: Thu Apr 03, 2014 3:02 pm
Oh, but you are ;).
Anyway, I've also tried to update the time, and run into the same problem. I'd rather have an extra hour at work today, but it really isn't 3pm.
PostPosted: Sun Apr 06, 2014 10:08 pm
Hoi! CS! Pay attention! :gah
PostPosted: Mon Apr 07, 2014 5:35 am
*mumble*grumble* Two times every damn year.....
Happy now? ;)
PostPosted: Mon Apr 07, 2014 6:13 am
Satisfied, but never happy. ;)
I have to say I am relieved that I didn't have to resort to musical terrorism this time.
Many thanks CS! ;D
EDIT:I'm still an hour behind. I checked the preferences and I am on GMT with BST selected... :-\
PostPosted: Mon Apr 07, 2014 4:14 pm
I can confirm that this is the case.
CS wants to be thinking ahead all the time it would seem ;).
PostPosted: Tue Apr 08, 2014 9:14 am
Any better? We are now on central African time!
PostPosted: Tue Apr 08, 2014 3:57 pm
No. The board is telling me it is an hour earlier than it really is. I have GMT selected as timezone with daylight savings selected.
Are you changing the server OS time, or the board preferences? Or both? What do the settings look like?
PostPosted: Tue Apr 08, 2014 5:11 pm
CS now officially stands for "Clock Sucks". >:D
PS Don't say that too quickly!
PostPosted: Tue Apr 08, 2014 5:37 pm
Time is A Relative Dimension In Space....
By using Tac Comms Itravel two hours back - or west. Either way, O0
Back from oblivion (again)?
PostPosted: Wed Apr 09, 2014 3:32 am
I swear, I am just going to set the board clock to Singapore time and you can all just deal with it! ;) We dont mess around changing the clocks here... mostly because we are almost on the equator!
This is the problem. Although messing around with the clock setting here is not fun, its infinitely preferable to changing the server clock twice a year. I have not touched the server settings since before the clocks changed in the UK, and I would rather not do so.
I have now changed the clock on the boards here back to GMT + BST, which should put the board time back one hour from when you posted, Kyrt. This should make your time reference now correct.
If anyone whose name is NOT Bissler is still showing the wrong time, please check that you have GMT + BST (daylight savings) checked in your preferences, and if there is still an issue, let me know.
Thanks.
PostPosted: Wed Apr 09, 2014 3:57 am
That sounds great, wish I lived near equator. I changed a bunch of clocks my GF had already changed... confusion ensued.
PostPosted: Wed Apr 09, 2014 1:25 pm
Testing...
