More easy printing Army and Reference Sheets
 Post subject: More easy printing Army and Reference Sheets
PostPosted: Sat Jan 17, 2004 1:47 am
He guys,
We me and my friend swapped armies for a Epic:Armageddon game.
Well I'm glad I'm the imprial players.  Those pesky Humies have lost of fire power.  It's hard to get into close combat.
In the end I lost.  It game down to one roll.  If I won the strategy phase two full warbands charge into close combat, , I even had the warboss in position.  If I lose I suffer the sustained of over half the Imperial army.
Well Guess what happen...  :p
I was hoping the orks would do better they only have two victories in our games of Epic.
I definitely encouraging the use of an Orc lander with a upsized Stormboyz unit.
Any other ideas that work?
Thanks
PostPosted: Sun Jan 18, 2004 9:59 am
Hi,
we had 6 or 7 games orks against ig and the ig only came out winning once. The following things were quite effective:
1) Fightabommas, typically our Ork player has 2 squadrons a 5 fightabommas. They have  a good chance of disrupting IG artillery batteries or at driving away the rough rider screen of the artillery or tank companies in a single action.
2) Mobile warbands. Battle/Gunfortress plus some battlewagonz or gunwagonz to deliver a warband with some extra nobz, boyz and gretchin.
Using a march action on the first turn you should be able to bring them into charge range in the first turn (deployment 15 on table + 90cm move + 5cm loading out troops = 110cm). The gretchin screen and hiding behind the battlefortress (warengines block los) helps surviving the one or two rounds of punishment, the nobz help removing the blast markers.
My opponent (Mark) typically uses gretchin in the first, then boys and then nobz in the third line to protect the nobz. I typically mix in some nobz in the first and second line to use the save against enemy fire and to increase the chance of getting them into close-combat.
You could add some stormboyz to the mob, with their 30cm move they don't even need a transport vehicle and increase your charge range. Dont forget you can charge the battlefortress into the enemy and push troops aside. You should see that it is in cc as you can then assign the first hits to the battlefortress and hope for the saving throws.
3) Deth-Koptas
good gun (for an ork), skimmer, fast, acceptable saving throw, very disruptive
prefer them very much to gunwagonz
4) Stompa mob with Soopastompa (how whats the exact name):
great firepower but because it is so slow you can usually not really fire before the second or third turn. But this mob usually draws unproportionally high attention from e.g. the leman russ companies and can sustain 3 turns of punishment from one leman russ company (if they stay at range > 60cm, if they don't, they risk a 6 barrage point macro weapon attack).
not effective:
we had a nice looking stormboyz mob with 2 skorchas in almost all ork games, they never did any damage and were killed/broken very early. but at least they drew some attention to themselves
warbands on foot -> simply to slow
PostPosted: Sun Jan 18, 2004 5:17 pm
I try to give all my Epic forces some sort of transport ... I'm biased when it comes to Mech forces ...   :;):
PostPosted: Mon Jan 19, 2004 8:44 am
Thanks Guys,
I'll pass it on.  I have a huge respect for fighter bombas. I couldn't believe how effective my Hydras where against ME.
Those bastrads  :p
Just because I shot their commanding officer for cowardice they have a gudge against you.
PostPosted: Mon Jan 19, 2004 6:35 pm
Well ... that is a leadership technique ... it worked well for the Russians !  :o
PostPosted: Fri Jun 18, 2004 8:09 pm
I've made some more easy printing Army lists and Reference sheets (the Orks and Speed Freek ones are fully updated with the errata). If anyone would find that useful you can download them here:
Biel-Tan Army List v10.83
Biel-Tan Reference Sheet v10.83
Black Templars Army List v2
Black Templars Reference Sheet v2
Feral Ork Army List v5.1
Feral Ork Reference Sheet v5.1
Ghazgkhull's Ork Army List
Ghazgkhull's Ork Reference Sheet
Space Marine Army List
Space Marine Reference Sheet
Speed Freek Army List
Speed Freek Reference Sheet
Ulthwe Army List v1
Ulthwe Reference Sheet v1
White Scars Army List v2
White Scars Reference Sheet v2
EDIT: Added Space Marines, Black Templars and White Scars.
Easy printing Reference Sheets and Army Lists
Pics of my mini's
John Baldock
PostPosted: Mon Jun 21, 2004 5:03 pm
Cheers, now why doesn't everybody do them this way?
PostPosted: Tue Jun 22, 2004 6:28 am
More work while the armies are in playtesting I guess. I only started making them because I found them useful. :)
Pics of my mini's
John Baldock
PostPosted: Mon Jul 25, 2005 3:46 am
Does anyone know if Jervis is going to put the revised pop-up rules into effect? Has there been a settle on which version to adopt as the new rule?
This is my number one gripe about epic. On terrain LOS blocking heavy tables. Things like Eldar gain significant advantages.
Just curious.
Thanks,
Rob
PostPosted: Mon Jul 25, 2005 6:02 am
You are not the only one wondering about this:
http://www.specialist-games.com/forum/t ... PIC_ID=167
My group currently uses the version posted by Zak/Pixelgeek:
"A skimmer may pop-up to shoot -over- blocking terrain.
If the target is closer to the terrain piece than the skimmer then no LOS exists , thus the target may not be fired on.
If the skimmer is closer, or both are equidistant from the terrain piece, then there is a LOS.
Popping up in no way effects the distance that can be seen -into- a terrain piece."
PostPosted: Mon Jul 25, 2005 3:14 pm
As far as I know, that is intended to be the version put forward for testing.
The best answer could be provided by Greg Lane.  He's the Rules Review Champion.  I know he was working on a consolidated Experimental Rules/EA v.2 post for the vault, but he has had some significant real life issues.
He has begun to post just a bit recently, so perhaps it's time to nudge him a bit towards getting that vault-ready.
PostPosted: Mon Jul 25, 2005 11:03 pm
NH,
Quote (nealhunt @ 25 2005 July,15:14)
I wish him god speed to that revision... and any nudging you or others can throw his way.
:blush:
?:l
Rob
PostPosted: Tue Jul 26, 2005 2:23 pm
Tactica:  You can always email him.  He's not exctly insulated from the public.  His profile is on the specialist games forum under GJLane.  I think he uses the same name on here.  Also, Epicenter is the Memphis-based Epic website and you can probably reach him through there.
PostPosted: Tue Jul 26, 2005 2:33 pm
Looks like there needs to be a little more work on the "official" version of the rules ... We used a modified version of the SM2 rule and it work for us ...  :D
PostPosted: Tue Jul 26, 2005 6:42 pm
NH,
I'll drop him (GJLANE) a line. I don't know that lil'ol me is going to really motivate him one way or the other, but I'll at least let him know his work is much anticipated from at least one individual out here.
Rob
Users browsing this forum: No registered users and 125 guests
