Fixing the Marauder Bomber
 Post subject: Fixing the Marauder Bomber
PostPosted: Thu Mar 15, 2007 7:01 am
Cross posted on the sg forum.
So time to resurrect an old thread?
The Marauder Bomber is without doubt (to me) the worst aircraft in the game. Ok so a formations has the firepower to shoot one or maybe two Fighta Bomberz out of the sky, but against longer range defences or other fighters its pretty much toast.
This relates to several factors.
1 - It is short ranged, which means it will normally take flak. The consequences of this are outlined in point 2. Yes I know you could clear all the flak away, but the attack isn?t that stunning, leading to point 3. One hydra battery will on average kill one marauder a turn if they come near them, that is 150 points of multi-purpose ground vehicles killing 150 points of aircraft.
2 ? If you take any hits you have a 50/50 chance of losing a plane per hit. So what? But if you do you loose more than just half your firepower. A two plane formation has 2 barrage templates hitting on AP4+/AT5+ and two twin lascannon shots. Kill a plane and now its one lascannon shot and one template but only AP5+/AT6+.
3 ? The attacks themselves, compare them to a ground battery. Whirlwinds get two templates, but hit on AP3+/AT4+. This leads onto the whole air/ground advantages/disadvantages.
Ground and air (artillery/bomber) units have different advantages and disadvantages.
Ground units can still do something when they fail an activation, can use sustained fire and can take objectives. But they can also be targeted by most weapons, be assaulted etc.
Air units can strike anywhere and only be targeted by flak. Indeed against a flak less enemy you can have a field day. But they have high chances of failing to activate if facing a properly equipped enemy.
In essence the Marauder is being compared with Imperial artillery and Whirlwinds.
Against the whirlwind the Marauder exchanges the ability for slightly more firepower until a plane dies and more importantly range, for a 1+ initiative, toughness, warhound allowance etc.
Against Imperial artillery the marauder offers more firepower than the basilisk and a better chance of firing every turn against the manticore and bombard. Otherwise it costs more, disallows some titan options etc.
In both cases they aren?t worth it in comparison. For marines taking whirlwinds and/or Warhounds gives reliability and options air doesn?t ? something important in a low activation army. Switching that for the chance to brave flak in the enemy deployment zone isn?t worth it. For Imperials paying more for quite often less simply seems a bit mad ? you can kill more effectively with regular artillery than risking all on planes.
Finally of course it is compared to thunderbolts. For the same price thunderbolts are double the activations, can suffer more flak as a result, but as the bomber is so vulnerable to flak its safe to assume both planes avoid it, has the ability to act as a fighter and has more firepower ? 300 points of bombers give 15cm 4bp and 2 A45cm AT4+ shots against 4 15cm AP4+, 4 30cm AT4+ and 4 30cm AP5+/AT6+ for the fighters.
So how to correct this?
The Bomber needs to offer something to both Imperial air arms ? I believe increased firepower and range vs increased risk. In essence a combined arms plan to be more effective than a load of artillery firing till the barrels glow.
Several options exist.
Option 1
Make the points equal to the plane. A simple drop to 250 points for 2 bombers provides the above gamble to both marines and Imperials.
Option 2
Make the stats equal to the cost. Here an equally simple change of 2bp to 3 bp means the bombers firepower degrades more evenly as well as providing a very slight firepower boost.
Option 3
Make the plane tougher, i.e. reduce the gamble. The big problem is the ease at which the expensive bomber gets blown away. Changing it to a warengine affects squadron survivability greatly. The following vaguely correct maths tries to illustrate this.
All hits from the same attack ? being a WE means you can play hit allocation to both your advantage and disadvantage when receiving damage from different formations.
2dc 5+
1 hit - 1/9 dead
2 hits - 5/9 dead (the effect of criticals when two hits sustained somewhat overdone, but don't matter too much)
3 hits - 5/81 chance of knocking both out (5/9 for first and 1/9 for second)
2dc 6+
1 hit - 5/36 dead
2 hits - 5/6 dead (5/36 of critical, 25/36 of two failed saves)
3 hits - 25/216 (about 10%) chance of knocking both out (5/6 for first and 5/36 for second)
And of course currently
4+
1 hit ? 1/2 dead
2 hits ? 1 dead
3 hits ? 1/2 chance of knocking both out
I would change the damage to 2dc 6+ with all other stats being equal if the price point remained at 300.
Option 4
A mix of the above, make it equal to the models.
a) Specialist games plane
Its tiny. I would suggest
Type - Fighter bomber
Save - 5+
Heavy bolter, 15cm, AA6+, Rear Arc
Assault Cannon, 30cm, AP5+/AT5+/AA5+, Fixed Forward Arc
Twin Missiles, 45cm, AT5+, Fixed Forward Arc
Bombs, 15cm, 1BP, Fixed Forward Arc
Past experience with a similar plane suggests 225-250 points for 2
b) Forge World plane
This looks like a proper bomber.
Type ? Warengine bomber
Save ? 6+
Twin Lascannon, 45cm, AT4+/AA4+, Fixed Forward Arc
Twin Heavy Bolter, 30cm, AA5+, Fixed Rear Arc
Twin Heavy Bolter, 15cm, AA5+, 360 degree Arc
Bomb bay, 15cm, 3BP, Fixed Forward Arc
2DC. Critical hit effect, the bombers control surfaces are
damaged causing the craft to crash and be destroyed.
Points around 300, maybe 325 for 2
Note if you wanted it to be a 'meaty' medium bomber and have 2dc 5+ as well as 3bp a points rise would be in order. I would think 350-400 points. It is delivering twice the firepower of a basilisk battery, though admitably will if facing threats only fly twice during a 3 turn game - I doubt the squadron will be downed however.
PostPosted: Thu Mar 15, 2007 9:05 am
We've been trying them at 250 and they are still not really worth it in our opinion.
250 and 3BP each perhaps?
I wouldn't downgrade their armour at all.
Trouble is they get compared to Phoenix Bombers, which are godlike in their terrible destructive power... :D
PostPosted: Thu Mar 15, 2007 9:08 am
I'd, personally, favor the second suggestion I think. This has the feel of two things: One, it feels like a proper bomber with heavy payload and durability. Two: It has that 'second world war air-fortress' feel to it. Where you've got turret gunners on it, heavy payload, huge size and it's built to survive whatever flakk the enemy throws its way and throw some back in return.
I more or less share the same sentiment about the underpowered levels currently (Seriously, main line bomber which is less potent then a fighter, for higher price? Who actually fields these things?) I like the Marauder Destroyer in the AMTL list as well, though I think that one may have gone a little too far in the opposite direction. If I only had an opponent (And an army which could field these things) I'd be happy to try one, or both, of the above options.
PostPosted: Thu Mar 15, 2007 10:25 am
Well 2dc and 6+ save is a boost to armour - you will still probably get nailed by a Hydra battery, but the odd one hit no longer has a 50% chance of killing you - it drops to 5/36 (5/6 chance of failed save, 1/6 chance of critical) or about 14%.
If you want a 'meaty' 3bp medium bomber it would have to be 2dc 5+ and 3bp and would probaly need a points boost.
The suggested stats for the SG model - making it a fighter bomber - sorta compare with the phoenix, so would be priced around that.
Of course you could always copy the Tau tigershark - a fighter with the armour of a medium bomber in its current incarnation - though I can't see that staying the way it is if the testors are on the ball.
Oh and some people swear blind they are fine and they regularily field them. Sadly I never play them :(
PostPosted: Thu Mar 15, 2007 3:04 pm
I'd go with the FW bomber's 2DC stats.
PostPosted: Thu Mar 15, 2007 3:09 pm
The durability stats are wrong in places.  I posted corrected ones on the SG boards.  To recap my posts there:
2DC6+ armor is actually close to a 2x increase in durability.  If you assume that the current stats are worth ~250, that means 2DC6+ should be in the  325-350 point range.
I favor a simple point change rather than complete overhaul of stats.
PostPosted: Fri Mar 16, 2007 2:45 am
Reply in sg thread
SG thread
Users browsing this forum: No registered users and 102 guests
