Too many pins! |
furgie
Post subject: Too many pins! Posted: Wed Dec 31, 2003 12:47 pm |
| Brood Brother |
Joined: Mon Dec 29, 2003 9:00 pm Posts: 330 Location: Devizes, Wiltshire
Hi all,
I have loads of old models from the original epic box sets, plus stuff from Titain legions etc.
Is it Ok to use the square based troop models?
| Top |
Warmaster Nice
Post subject: Too many pins! Posted: Wed Dec 31, 2003 12:55 pm |
| Brood Brother |
Joined: Tue Sep 30, 2003 9:15 pm Posts: 7948 Location: Denmark
Welcome to the boards! Yup, no problems at all. In fact I believe a few of the new models willl be on square bases (the IG heavy weapons teams) You are pretty much free to base any way you like as long as the base is no bigger than 4 cm on any side and no shorter than 0.5 cm on any side - but at least 2 cm on one side. As an example you could have bases 0.5x2 cm or 4x4 cm or a round base 2 cm in diameter.
_________________ Sofa General
Nobody expects the Inquisition!!! http://theepiclounge.wordpress.com/
| Top |
stormseer
Post subject: Too many pins! Posted: Wed Dec 31, 2003 2:06 pm |
| Brood Brother |
Joined: Fri Feb 14, 2003 9:52 pm Posts: 4598 Location: Suffolk, UK.
Welcome to the boards Furgie!
...On a related note, anyone know if the square base sprues will be available from GW? ....I could do with a few sets for basing support weapons etc... ?
_________________ www.darkrealmminiatures.com
| Top |
nealhunt
Post subject: Too many pins! Posted: Wed Dec 31, 2003 4:43 pm |
| Purestrain |
Joined: Thu Feb 13, 2003 10:52 pm Posts: 9617 Location: Nashville, TN, USA
I seriously doubt it. I use 3/4" craft sticks, that I cut into squares (tin snips cut them like paper).
_________________ Neal
| Top |
Legion 4
Post subject: Too many pins! Posted: Wed Dec 31, 2003 4:48 pm |
| Brood Brother |
Joined: Thu Feb 13, 2003 5:13 pm Posts: 37005 Location: Ohio - USA
You can used whatever bases or models you want, it makes no difference. ?Jervis even mentions that in the early E:A downloads. I've been playing Epic since SM1 in '90 and most of my infantry are on square bases. ?So as I said it makes no difference. ?However, the square bases are no longer available from G/W MO, but occasionally they show up on Ebay, Bartertown, etc. I have some I'm keeping in reserve ! ?The same goes for models, in some case Jervis gives stats and in others he says "use as" ... for example a Gorgon Mk.2 or 3 can be used as a Chimera, etc., etc. ? Everything old can be used ... ? ?
_________________ Legion 4 "Cry Havoc, and let slip the Dogs of War !" ... "People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
| Top |
primarch
Post subject: Too many pins! Posted: Wed Dec 31, 2003 7:33 pm |
| Brood Brother |
Joined: Fri Feb 14, 2003 12:46 am Posts: 27069 Location: Edmond, Oklahoma USA
For those who like square bases (like I do) an easy outlet is to buy GW fantasy 20mm bases. The ones you use for rank and file troops in that game. They are the same size and with a little flock will look indistinguishable from the standard ones.
| Top |
pixelgeek
Post subject: Too many pins! Posted: Wed Dec 31, 2003 10:55 pm |
| Brood Brother |
Joined: Sun Feb 16, 2003 8:10 pm Posts: 2643 Location: Edmonton, Alberta
| Quote (primarch @ 31 2003 Dec.,10:33) | | For those who like square bases (like I do) an easy outlet is to buy GW fantasy 20mm bases. | Or buy Warmaster bases and chop them in half. :-) That might be a bit of a pain though
As an added bonus you can use the Warmaster bases for troops like Bikes, Boarboyz etc. I've even based my latest unit of Terminators on the Warmaster bases.
_________________ Guns don't break formations. Blast Markers break formations.
| Top |
Legion 4
Post subject: Too many pins! Posted: Thu Jan 01, 2004 2:14 am |
| Brood Brother |
Yes, I've used W/M bases for Cyboars too ... looks good.
| Top |
Jimbo
Post subject: Too many pins! Posted: Thu Jan 01, 2004 9:26 am |
| Brood Brother |
Joined: Fri Feb 14, 2003 11:01 pm Posts: 3495 Location: Wessex
| Quote (primarch @ 31 2003 Dec.,22:02) | | Seriously though using them as you suggest for bike, cyboars and similar units is a good idea. | they can work well
for the majority of my bases I use plasticard and cut it up and have had virtually no problems
_________________ Jimbo
Felix's Gaming Pages
Felix's Gaming Pages Blog
Almost Always Right...
| Top |
furgie
Post subject: Too many pins! Posted: Thu Jan 01, 2004 12:46 pm |
| Brood Brother |
Many thanks for all your posts.
regards,
Furgie
| Top |
primarch
Post subject: Too many pins! Posted: Thu Jan 01, 2004 10:58 pm |
| Brood Brother |
No problem Furgie, welcome to the boards!
| Top |
Tas
Post subject: Too many pins! Posted: Fri Jan 02, 2004 4:33 am |
| Brood Brother |
Joined: Thu Mar 06, 2003 10:01 am Posts: 7823 Location: Sydney, NSW
Welcome also! From where do you hail? Its quite an international community here!
_________________ Tas My General blog: http://tasmancave.blogspot.com/ My VSF Blog: http://pauljamesog.blogspot.com/ My ECW Blog: http://declaresir.blogspot.com/
| Top |
nealhunt
Post subject: Too many pins! Posted: Fri Jan 02, 2004 5:34 pm |
| Purestrain |
I've also found metal bases in the hobby shops for about the same prices as GWs plastic ones, and you can buy them in a wider variety of sizes.
| Top |
Ork Dreadnought
Post subject: Too many pins! Posted: Sun Apr 11, 2004 9:13 pm |
| Brood Brother |
Okay, I know its all gold as far as material is concerned, but 17 pinned topics is a bit much
Its a pain to scroll down to the bottom of the page before we actually see new posts.
_________________ "Do not act incautiously when confronting little bald wrinkly smiling men!"
-- Rule One (Terry Pratchett, Thief of Time)
| Top |
