Images of old models?
 Post subject: Images of old models?
PostPosted: Tue Feb 17, 2004 1:10 am
Well, being an Epic newcomer, I was wondering if you fine folks had websites with images of older Epic stuff? I've been to De'Ayne's Gallery and Felix's Gaming Pages, Stuff of Legends doesn't seem to have an Epic section... any others?
PostPosted: Tue Feb 17, 2004 6:01 am
Unless I missed something, De'Ayne's if full of Epic ?  Chris help me out here ?  Also check out ebay ... there is usually a lot of old stuff there, too. :;):
PostPosted: Tue Feb 17, 2004 8:33 am
Stuff of Legends has ALL the old catalogue pages which have the models on
http://www.solegends.com/citcat911/index.htm (look on right)
or for example Capitol Imperialis
http://www.solegends.com/citcat911/c212 ... talimp.htm
Another useful link
http://www.epicollector.com/
Jimbo
Felix's Gaming Pages Blog
Almost Always Right...
PostPosted: Tue Feb 17, 2004 9:46 am
Those 2 are the best that I can think of Jimbo.
If you want to see anything specific Hergrmir then ask- somebody here will have one!
Tas
PostPosted: Tue Feb 17, 2004 11:37 am
De'Aynes is PURE Epic, I don't see how you couldn't find any Epic pictures!
List me what you want to find, and I will send you some links, if we have to required pics.
Chris
Chris
PostPosted: Tue Feb 17, 2004 11:53 am
Quote (Jimbo @ 17 2004 Feb.,07:33)
Another useful link
Hey, I've got that catalog!
"Do not act incautiously when confronting little bald wrinkly smiling men!"
-- Rule One (Terry Pratchett, Thief of Time)
PostPosted: Tue Feb 17, 2004 6:48 pm
Sorry for the poor writing on my part. I mean, I have been through De'Ayne's and Felix's, and spent a while going through everything. And there's great stuff, inspirational stuff, and lots of stuff. But I also happen to know there's more stuff. Specifically, I was looking to see the Eldar, Squat and Chaos ranges in their full glory.
And thanks for the SOL link, I'd been there, but the GW section didn't have the Space Marines/Epic link up; I'd never thought to check the catalogue.
PostPosted: Tue Feb 17, 2004 11:13 pm
Just SAVE'd SOL ... Jimbo again proves his worth to the Regiment ! :;):
PostPosted: Wed Feb 18, 2004 2:39 am
Doomwings, Firelords, Slaanesh Daemon Engines, old CSMs.
I'm looking into a lot of those for purchase, and just want to see them before they turn up on my doorstep, so I can anticipate assembling other than ranks upon innumerable ranks of Guardians. 78 and counting...
PostPosted: Mon Aug 08, 2005 11:03 pm
Is it just me, or are Chaos forces particularly well suited to take on loyalist marines?  I just seem to have a harder time against them than I do when facing all other armies...
While we're at, does anyone have any good tips?
Thanks,
Al
Note to self:  add clever signature
PostPosted: Tue Aug 09, 2005 3:05 am
Keep them at range and out of CC range where they can use sacrifices to call in nasty demons and overrun you.
Helltalons are nasty in pairs, take one out with your aircraft then ignore the other one and go strafing!
Tas
PostPosted: Tue Aug 09, 2005 3:08 pm
In addition to what Tas said, pick your assaults carefully.
A daemon-heavy formation is a prime "clipping" target.  Typically, CSM players put the daemons out front to soak hits.  Daemons suck at FF (except Flamers), so you can engage at extreme range and count on very few casualties to your troops.  You should win.  Daemons desert broken formations, so even though you inflicted few direct casualties, the daemons all vanish.
You still need to prep with BMs and try to outnumber as much as possible, but it works.
Also, make sure you are using the newest daemon summoning rules.  Daemons are now ~3x as expensive to summon as they used to be and it makes a big difference on balance.
PostPosted: Thu Aug 11, 2005 8:33 am
But if my opponent doesn't use many deamons?  the ones he does use go strait into assult.  I find that he gets sooo many more marines than I do, plus more tanks and some Super Heavies.
PostPosted: Thu Aug 11, 2005 3:09 pm
Use the latest version of the list that was posted also.  It has a significant increase in daemon cost, restrictions on WEs and a drop in power/rise in cost for Helltalons.
Needless to say, that makes a big difference.
CSMs will simply have you outnumbered.  You will find it nearly impossible to break them with ranged fire, but with TSKNF, he won't be able to break you either.  CSMs can, however, wear you down faster.
You will have to assault, so pick your assaults and hit him on your terms.  You will almost always want to firefight.
You should have more activations, so use your activation advantage to stay back out of range of his assaults.  Most daemons only have an effective assault range of 20cm or less (5cm summoning distance + 15cm move to base).  That should be easy to stay out of for the most part.  Flamers (35cm), Beasts (45cm), and GDs with wings (35cm) are more problematic but do your best.
If that doesn't work, try to move a formation into range to support the threatened formation.
If you can't move a formation after he positions at the end of the turn, you will still have a good chance to win the strategy roll and go first at the beginning of the turn before he can come after you.
Basically, this boils down to protecting your forces.  Chaos will expend themselves.  Deamon pools become exhausted.  Broken formations can be more easily destroyed.
It's not going to be easy.
You have some advantages:
Thawks give you maneuverability he can't aspire to.  Don't do suicide missions.  Use them on the flanks even if the target is less "juicy," take the win, and live to  fight next turn.  There's nothing worse than a Thawk which makes it off the ground to strafe for the rest of the game.
Whirlwinds give you relatively inexpensive artillery (at least compared to buying a retinue just to get Defilers).  Use them to prep for assaults or simply to hammer a broken formation and eliminate it entirely rather than allow it to rally.
Chaplains have Inspiring, making clipping assaults more effective, while the CSM list now has no Inspiring characters (outside Greater Daemons).
PostPosted: Thu Aug 11, 2005 5:18 pm
Thanks Neal.
By 'clipping' I assume you mean assulting the end of a formation as opposed to its front, so as to avoid fighting the whole formation?
The new version of the list will, I'm sure, will make it that little bit easier.  (Quintaan was using the new list the one time I beat him)
Users browsing this forum: No registered users and 107 guests
