Kreig. They are broken.(or rules questions about Gorgons)
 Post subject: Kreig. They are broken.(or rules questions about Gorgons)
PostPosted: Mon Sep 18, 2017 7:28 pm
For me to hate a list, it must be worse than necrons...
Ok enough whining.
We were playing last week, and I had the opportunity to prep two loaded Gorgons and assault.
So far so good.
There was a bit of a gap between the gorgons, and having lots of spare activation, I cunningly shot at the gorgons with scouts from 10cm on the right flank, then was going to assault the other Gorgon from 12cm to the left. So that way only Gorgon one would be inside FF, and gorgon two (the right most) would have to either stay still or counter charge the near by scouts.
So here began the first argument.
The guardsmen of Gorgon two 'disembarked' not counter charged, 'disembarked', this meant they could take their 5cm move to the Left and bring themselves into FF.
Worse was to come,
The Left most Gorgon, who would be blocking some of these disembarked troops, then counter charged 5cm towards the assaulter, and so stopped blocking the FF of the guardsmen.
Then the guardsmen in that got out.
So we had a question there. Does disembark all happen at once, or can it happen at different times as above, AND can units disembark in the opposite direction form the nearest unit.
- sadly i think the answer to both is how we played it. But I am sure you appreciate why I was raging.
This got worse.
Having lost the assault, the guardsmen all got back in the Gorgons.
Trying something different, I air assaulted with a squad of bikes and Thunderhawks, trapping the units in the left most Gorgon. The guardsmen got out of the right Gorgon and we thought the assault. It was a draw. But as I had lost a bike, I no longer had the left goron pinned.
So the guardsmen got out, and I was toast in the next round.
So two issues here, between assault rounds can units disembark.
Can units disembark and walk past / over units in close combat? - in this case the guardsmen sat to the left of the bikes that were next to the gorgon, it just seemed weird.
And, AGAIN, they don't need to enter base contact as its a disembark and not a counter charge?....
Finally, and really at the end of my tether, I air assaulted with terminators (yup, it was a pretty crazy list I was also running).
One of the Gorgons had by then taken a hit.
This time my opponent had left the guardsmen out of the vehicles, so I put a terminator into each of four guardsmen, ...but.. the gorgons counter charged also putting themselves into close combat.
I scored three normal and two macro hits. One of the gorgons had already suffered a wound and my opponent was loath to lose one. So he separated the hits as follows, three normal's into the first gorgon, then two macros into guardsmen.
My understanding is that all normal get resolved, then all macros get allocated and that the player chooses where the front is.... but, can the front move. In other words if the gorgon was the front for the normal hits, surely it would also be front for the macros? (If I had been guard i would have happily had them into the gorgons anyways). - but do want to clarify this.
Thanks for your thoughts.
p.s look how dreadful and expensive plague towers are. even Orky-o-sarus' can't easily trebbile and don't get to be fearless with a commissar! this list is way too good!! Please NERF. (but only after Copenhagen :) )
 Post subject: Re: Kreig. They are broken.(or rules questions about Gorgons
PostPosted: Mon Sep 18, 2017 7:31 pm
Found one answer (enough for me to claim a miss-trial... I mean draw)
Can a unit that disembarked other units still counter-charge?
No, disembarking happens at the end of a move.
PostPosted: Tue Sep 19, 2017 12:27 am
Don't be dragging the good name of Necrons into this :o
Toronto Wargaming Group
PostPosted: Tue Sep 19, 2017 5:38 pm
Ok enough whining.
So far so good.
Worse was to come,
yes, this is correct, the troops may disembark wherever they like
Yes, it's basically a whole second counter charge
provided the enemy units have sufficient units to negate their ZoC, yes
Yes
unfortunately your opponent could do this, same as an ork player with grotz, if they are all in BTB then they are all equally close targets, you effectively have two pools of dice to assign, and as they are all at range zero, there is no 'closest to furthest' like there is with shooting
in your example with the terminators, you could have been cheesy, and put the stands in BTB with two guardsmen stands each, this way the gorgon would not be permitted to BTB your terminator units as they already have 2 units in BTB
Plague towers are awesome, for the loss in speed you gain a heck of a lot of firepower, and orkeosaurus get to carry a MW AA wyrdboy around so they have their own nasty tricks ;) I do agree that Krieg are overpowered at present and the stats back that up (2 UK tournament wins this year and a 12% loss rate is pretty damn good) I have heard on the grapevine that EUK are considering options to balance the list....
PostPosted: Tue Sep 19, 2017 9:26 pm
12%? Wow. Not a very good quality rating, that.
PostPosted: Tue Sep 19, 2017 9:52 pm
I have to admit that my win ratio with Krieg is a lot higher than with Steel Legion and I'm no good with either. It'll be interesting to see what they do if they do anything
PostPosted: Tue Sep 19, 2017 10:12 pm
I'm not sure epic UK Krieg need another nerf. There's no doubt they're top tier but one army has to have the most powerful assault unit in the game and hey that's Krieg. In addition, they're run almost exclusively by people like Richard and Mike so seem even scarier.
They have plenty of weaknesses (ie speed, activations, etc) - also Dan were you running the half dozen thunderbrick list into them? If yes, you've taken a skewlist and got a terrible match up. That's what happens with skewlists.
My record against epic UK Krieg is actually better than my record with them - there's definitely counter plays and rough match ups for them.
As one of the Krieg tournie winners this year, my success was heavily influenced by them basically being amazing on the special mission run in Exeter and rolling bucket loads of 6s against Richard in the final game so read into that what you will.
As for the hit allocation thing. Plenty of armies can do this (Orks, nids, TK sons with daeomons, squats with warlords, etc etc). IMO tyranids actually do this way better than Krieg. 20 hits in cc, well I'll take them all on my 20 gants. Not even the risk of a failed armour save or crit. Plus no BMs or combat res.
PostPosted: Mon Sep 25, 2017 10:29 pm
One interesting combination of rules that you might potentially argue about in your first example is the combination of the disembark, counter charge and charge rules:
1.7.5 Transport vehicles
Transported units may disembark at the end of any move after the move in which is it was picked up. ... Units may embark or disembark as part of a counter-charge move (see 1.12.4). ...
1.12.3 Make charge move
... A charging unit that enters a zone of control must move into base contact with the nearest enemy whose zone of control has been entered. ...
1.12.4 Counter-charges
... All the normal charge move rules apply ... Units can choose not to counter charge if they wish, but if they do counter charge they must head towards the nearest enemy. ...
So:
a) Disembarking can only be done at the end of the counter-charge move, which means one must first counter-charge, even if that counter-charge is 0cm.
b) If a unit counter-charges, it must go in the direction of the nearest enemy.
c) If a unit enters a ZoC it must move into base contact
If the gorgon uses its counter-charge in order to be able to then disembark, and is in ZoC of the scouts, one might argue that it must use its full move to attempt to base the scouts before the guardsmen are allowed to disembark. The guardsmen don't have to disembark towards the scouts, but they'd be further away at this point. The contentious point is enters. The gorgon technically didn't 'enter' the scout ZoC itself, but the FAQ on options for finding oneself in a ZoC doesn't help fully. Normally the unit would have the option to leave the ZoC, but 1.12.4 is clear that this is not an option - you must move towards the enemy, not away from it outside its ZoC.
PostPosted: Mon Sep 25, 2017 10:42 pm
There's also another curiosity in the 1.7.5 RAW (that personally I probably would not enforce):
... If the formation has engage orders then they may be placed in base contact with an enemy unit. Otherwise they may not be placed within an enemy unit’s zone of control. ...
So you're not allowed to disembark into a ZoC (i.e. an uncontacted unit) without contacting it. I don't think this is typically enforced - I've seen plenty of people disembark infantry to the front of their transports, inside the ZoC of their target without basing them. It would be quite restrictive when firefighting scouts, as you'd have only a narrow band 10-15cm in which to place your units without being forced to CC them.
Users browsing this forum: No registered users and 141 guests
