Supreme Commander Re-Roll
 Post subject: Supreme Commander Re-Roll
PostPosted: Sun Jan 18, 2015 11:50 am
What is the position with regard to using the Supreme Commander re-roll if off table.
Can they use the re-roll on the activation for an aircraft they are in? To come on and land.
What about if they are on a spacecraft? To planetfall.
Having trawled TacCom I seem to have both yes and no to both questions.
At the time of activation the formation being activated does not include the supreme commander.
In the case of planetfalling the landing aircraft carrying the supreme commander are not activated when the spacecraft is (ie they activate later in the sequence).
 Post subject: Re: Supreme Commander Re-Roll
PostPosted: Wed Jan 21, 2015 4:36 pm
As long as the SC is not on the table, you cannot use his/her re-roll. Therefore, you cannot use the reroll for the activation to "bring him/her in" but for all following activations (e.g. assaulting after planetfalling)
PostPosted: Wed Jan 21, 2015 4:56 pm
The SC reroll can be used when he is on an AC undertaking a ground attack order as it is one formation at that point.
Can't be used for spaceships as the SC is never part of the Spaceship formation.
Here's the FAQ
Q: If a formation is offboard (awaiting
teleport, in a transport aircraft, etc.)
can any special abilities of units in
that formation be used?
A: No. Special abilities of offboard units
may not be used. A specific exception is
made for abilities used to affect the
activation of the formation they are in.
For example, an Eldar formation with a
Farseer is held offboard in reserve and the
Eldar player retains the initiative to
activate this formation. Even though the
formation is offboard the Eldar player can
use the Farsight ability of the Farseer in
that formation to negate the penalty for
retaining the initiative. Similarly, a Space
Marine Supreme Commander may use the
Supreme Commander ability to re-roll the
command check to activate the formation
they are in if it was offboard but could not
be used to apply that same re-roll to a
formation that was onboard or to another
offboard formation.
@MephistonAG for all sorts of twitter madness
