Rules Q: skimmers and overwatch
 Post subject: Rules Q: skimmers and overwatch
PostPosted: Sun Nov 23, 2014 9:00 pm
Hi folks,
Wandering if act of forcing FF by skimmer in assault can trigger overwatch (from other formation).
Has anyone had that situation in game?
Fight not for hate of what lies ahead
But for love of what you protect
 Post subject: Re: Rules Q: skimmers and overwatch
PostPosted: Sun Nov 23, 2014 9:39 pm
No. OW is only triggered by an enemy formation making a "move". While this definition includes Withdrawal and Consolidation "moves", lifting off the ground to get out of reach of CC weapons is not a "move".
PostPosted: Sun Nov 23, 2014 10:49 pm
It doesn't include consolidation moves,Ginger.
PostPosted: Mon Nov 24, 2014 12:12 am
How so? Consolidation is deemed a "free Bonus move" and thus was always capable of triggering OW as far as I was aware. The same is true for Withdrawal "moves", and given both can be of considerable length (Eldar) both have always been able to trigger OW.
I might add that as these moves occur without activation in 1.7, the FAQ may need amending.
PostPosted: Mon Nov 24, 2014 1:52 am
Nevermind, was thinking counter-charges. Too many "c" moves.
PostPosted: Mon Nov 24, 2014 4:33 am
So lifting off to force firefight is not 'popping up'? Unfortunately it is not stated precisely in rules:/ -seems strange because for eg. charge/countercharge over impassable terrain, as long as before consolidation move skimmer is 5cm from open ground does count as popping up (skimmer pops down at the conclusion of action- end of consolidation move here).
Relevant rules: 2.1.13, paragraphs 3,4 and 6.
PostPosted: Mon Nov 24, 2014 1:41 pm
No, "lifting off" is not the same as "popping up" - these are terms that are hard to define in English, so have always caused difficulties.
(Dave - this might be worth a FAQ :) )
"Popping up" is a term that is declared after a successfull activation at the start of movement. The Skimmers are considered to have risen high off the ground - possibly several hundred metres - allowing them to clear high obstacles like hills, trees, buildings etc. It is in effect a short flight during which the Skimmers do not touch down until the end of their action. (Note, this is still much lower than aircraft fly.)
"lifting off" is a much more limited term suggesting the Skimmers rising a few meters off the ground to get out of CC range, and this effect only lasts for the duration of the assault. As such "lifting off" and any subsequent movement is subject to terrain rules.
The distinction between these terms is important during an assault.
  • Skimmers that "Lift off" are still subject to terrain rules, so may not enter Impassable terrain and must take DT tests if they start in, or move into / over Dangerous terrain. If the skimmers are carrying troops, these may disembark before the skimmer "lifts off".
  • A formation that declares it is "Popped up" ignores terrain so may assault enemy located in terrain that it would otherwise consider Dangerous or Impassable. This is because the formation only "pops down" at the end of it's action, *after* it takes it's consolidation / withdrawal move. Note, it will take a DT test at that point if it lands in Dangerous terrain.
    However, troops inside the skimmer may not disembark once it is "popped up", so if Eldar in Wave Serpents declare an Engage, they must stay "popped down" for the transported troops to get out after the 'charge' move - at which point the transports may "Lift off" to use their FF.
PostPosted: Tue Nov 25, 2014 3:01 am
Thanks Ginger & Dave.
It sounds clearer but as mentioned it's worth including it in FAQ, if only to keep enjoyment in friendly games, bare tournament struggles ;D
