(rules query) Assault against landed SM Lander
 Post subject: (rules query) Assault against landed SM Lander
PostPosted: Sun May 25, 2014 3:46 pm
I won an assuallt against a landed Lander is it destroyed as per the aircraft rules or does it survive as the per fearless rules?
http://robsepicblog.blogspot.co.uk
 Post subject: Re: (rules query) Assault against landed SM Lander
PostPosted: Sun May 25, 2014 3:57 pm
If you engaged and won against a landed Fearless aircraft it would not be destroyed. It's a Fearless ground unit at that point.
However, a Fearless aircraft which performs an air assault and loses would be destroyed as per 4.2.5.
PostPosted: Sun May 25, 2014 4:01 pm
Oops, got that one wrong shall have to apologise next time I see my opponent. Thanks for the quick answer.
PostPosted: Sun May 25, 2014 4:20 pm
[shadow]One more thing would it be destroyed if there were enemy within 5cm as it is unable to move?[/shadow]
Edit: Just reread the rules and obviously they don't as they have not withdrawn! :{[]
PostPosted: Sun May 25, 2014 5:26 pm
I've not seen air assaults played differently to any other assault in that regard. Only as normal fearless ground units with a speed of zero, and therefore immune no matter who initiated the assault. The assault part of an air assault is just like any other assault ("land, disembark, fight an assault"). I know 4.2.5 says they are destroyed, but it reads to me like a clarification for what would be a common uncertainty around what happens to 0cm move units - landed aircraft being by far the lost common 0cm move units. Obviously it does not consider fearless. From a rules point of view, I'd file it under "unspecified". From a logic point of view, I can't really explain why air assaults would be different?
The FAQ just says:
"Q: What happens to Fearless aircraft that lose an assault?
A: Fearless aircraft are immune to the automatic destruction and are instead treated as any Fearless ground unit."
I'd quite like to play it your way - I hate landing craft :)
PostPosted: Sun May 25, 2014 8:15 pm
I believe it should be played as Kyrt says - Fearless units are *not* destroyed if they lose an assault (despite any desires to the contrary). This exact discussion over 4.2.5 was the subject of a similar debate some years ago, and it was agreed that 4.2.5 was there to reinforce the principle that "0"cm units which lose assaults are automatically destroyed.
PostPosted: Sun May 25, 2014 10:05 pm
Agree also with Kyrt. A fearless Landing Craft doing an air assault gets the fearless advantage.
PostPosted: Mon May 26, 2014 12:42 am
I've always played it as Kyrt describes it.
Fearless makes a unit immune to hackdown and I would consider Fearless to take precedence in this case.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Mon May 26, 2014 1:42 am
What section is that FAQ under? Didn't see it under 5.2.5.
PostPosted: Mon May 26, 2014 3:15 am
With Kyrt, Onyx and GlynG on this otherwise what's the point of fearless flyers?
PostPosted: Mon May 26, 2014 3:00 pm
NM, found it. I went straight to the Air Assault section and didn't bother flipping back a page.
