Making order out of Chaos
 Post subject: Making order out of Chaos
PostPosted: Tue May 06, 2014 2:46 pm
I have started a project which should (if completed) include all my 6mm chaos stuff and a good deal of turned imperials, some of which would be proxies, and I need a spot of help to organise stuff.
Q1 Is there a comprehensive list of all Chaos unit types across all Net:EA Chaos armies? I have seen the army lists of course, but was wondering whether a full list of units including all models exists. Will do my own if there isn't.
Ideally, extending to units included in Netepic Gold which are not listed in Net:EA, for completeness' sake.
I will post a few other queries as they come up, a typical one being: what do you suggest I use this proxy (pic would be provided) model for?
Back from oblivion (again)?
 Post subject: Re: Making order out of Chaos
PostPosted: Tue May 06, 2014 4:38 pm
I think the massive army list compilation used a shared unit datafex for each main faction, so you could collect it from there.
As to the actual models, I gave up trying to trace them a long time ago :)
My shifting projects
PostPosted: Tue May 06, 2014 6:13 pm
I think that's how I'll have to proceed - thanks.
As for the models - I am lucky enough to be old enough to have most, albeit not all, models; but I tend to favour conversions and proxies, so here as an example is question 2:
Q2 What do I use this as? Note the 6mm flamer in the central hole, he's the demon behid the engine >:D
PostPosted: Tue May 06, 2014 6:41 pm
For red corsairs … if you think it could fly/be put on a flight stand i recon that's a great harbinger bomber. If it has to be ground based then whichever size titan takes your fancy. Other option is brass scorpion, but that looks far too big for DC2 no voids.
For black legion i'd have said death wheel or decimator.
PostPosted: Tue May 06, 2014 7:01 pm
Very nice paint job !
PostPosted: Tue May 06, 2014 7:09 pm
As I have a pair of Deathwheels, I could make this a third - thanks Apocolocyntosis.
What size would a Harbinger be?
L4- thanks ;D
PostPosted: Tue May 06, 2014 7:16 pm
A harbinger would be about the size of the above mini ;) Or, given that aircraft are scaled all over the place that could easily be harbinger size. The forge world one is huge (bigger than your mini), but stats wise it is only DC4 and if GW had made the mini it would be much smaller than the FW one. As an additional size guide: GW's space marine landing craft is meant to be DC4 as well.
PostPosted: Tue May 06, 2014 7:23 pm
Very useful - brings the old size dilemma of the Thunderbrick to mind (my theory is that it's a TARDIS - bigger on the inside).
Thanks Apoc. I'd go for lander size.
PostPosted: Wed May 07, 2014 5:25 pm
Sigh.
Now you've done it Apoc ;D instead of working on my noise marines I went down to the dungeon (where I store unmade models) and found something I can use for a Harbinger. Trouble is it's big! 28cm long......
And to make things worse I found a smaller beastie which can be a Hell Talon. But I need two, so I have this other model.....
I decided to give them a flavour, so probably the Harbinger will be a very unusual Nurgle model, whilst the two Talons will probably go to Slaanesh and Tzeentch. Khorne gets the fighters of course. Pics will go in the Utter Chaos thread http://www.tacticalwargames.net/taccmd/viewtopic.php?f=7&t=27357
PostPosted: Wed May 07, 2014 5:54 pm
:nooo
hah look forward to seeing it, 28cm is a pretty big flyer :D
PostPosted: Wed May 07, 2014 6:12 pm
:nooo
That it is - sigh!
PostPosted: Wed May 07, 2014 9:14 pm
That's...that's... that's like a BFG fighter made into Epic scale. Holy crap.
PostPosted: Thu May 08, 2014 6:06 am
They are definitely not BFG designs, although they appear similar The not-Vipers have a very different engine design, with a cluster of thrusters at the rear and no external sign of an engine housing; and the flat thingy in the middle which is so reminiscent of a Cylon fighter had a turret I removed. But those slats are very Cylonesque, and for the non-purist they could very easily represent some generation of Vipers and Cylons. The models is that they are no longer in production.
The collection I bought are from a defunct game called Starforce 300; I did some research since my first post here and was surprised to find out that the models are Citadel designs (!) http://www.collecting-citadel-miniatures.com/wiki/index.php/QT_Models_scifi_range
In fact some of the spaceships shown here are actually old BFG designs, possibly adopted from this range.
Here is the not-Vyper:
http://www.collecting-citadel-miniatures.com/wiki/index.php/File:SF2_DRAGONFLY_two_man_fighter.jpg
And the not-Cylon:
http://www.collecting-citadel-miniatures.com/wiki/index.php/File:SF4_MANTA_armed_tug.jpg
This (which I do not own) is very suspiciously labelled 3-man fighter, and is even more Cylonic:
http://www.collecting-citadel-miniatures.com/wiki/index.php/File:C43_Spaceship_15.jpg
And there's even a thread here: http://www.tacticalwargames.net/taccmd/viewtopic.php?t=11473
PostPosted: Thu May 08, 2014 4:50 pm
I'm referring to size, not design mate. A BFG fury interceptor is stated to be around 5 times as long as a Thunderbolt. In epic scale they'd be huge on the table, much like the giant 28cm model noted above.
[pedantic mode off] :)
Love seeing those old minis though. Thanks for posting them. Old school Gamesworkshop was great.
PostPosted: Thu May 08, 2014 5:58 pm
Oops, someone else mentioned BSG, and when I read your BFG I was still thinking BSG! ANd then I myself mentioned BFG to turn this confusion to chaos - which is appropriate! ;D
