Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
DC/Baltimore Rogue Trader
 Post subject: DC/Baltimore Rogue Trader
PostPosted: Wed Jul 23, 2003 3:39 pm
Thanks for fielding that question Neal, I was scrounging for my long post on this matter, but you save me the time.
I agree, that for a new person into epic, the most recent version is best.
PostPosted: Wed Jul 23, 2003 5:03 pm
It would definitely be best to start with E-A. It's being supported and the models that will soon come into availibility will all be for E-A.
Having said that, I very partial to NetEpic and the old Space Marine 2nd Edition / Titan Legions. Acquiring some of the lead would be highly problematic though.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Wed Jul 23, 2003 9:39 pm
This is the post I gave to this question when the forum was beginnings:
Net epic
These rules are based on the second edition rules known as Space Marine and its add on Titan Legions. While there are many simularities between the two, there are also many difference. I will concentrate on net epic alone, but keep in mind it shares the same basic mechanics with SM/TL, most of the changes are in the details.
Overview
At its core, the basic mechanics are quite simple. You place one of three orders: first fire, advance and charge. These limit the actions of your forces so some forethought is needed when placing them. First fire orders permits you to fire first in the firing phase, but at the expense of movement, advance permits some movement but you fire LAST. Charge permits double movement, the ability to engage in close combat, but no firing.
Combat is done by rolling the attack dice according to how many each unit has, rolling a to hit number and determining hits. Weapons have a save modifer that will affect the target units saving throw.
Close combat is very simple each combatant rolls 2d6 and adds its close assault factor (CAF for short), the loser dies and is removed, no save, its very deadly and direct. Extra combatants against the same stand give the player who outnumbers an extra D6, therefore you can gang up on stronger opponents with weaker ones and have a chance to defeat it (albeit with heavy casualties).
Simply put that is the core system, so where do the comments regarding the systems complexity come from?
Simple, the detail.
Net epic/SM/TL has loads of special rules and chrome for individual units.Mastering the core rules is simple, the interaction of all the detail with the core rules takes longer to master if ever.
Example: Titans use a different hit/location resolution, they use templates where you see the hit scatter and affect SPECIFIC parts of the titan, alll with different results when damaged (will the titans head get blown off and it will fall on the nearby building or will the reactor meltdown and kill everyone in sight?). You also arm titans, selecting and perchasing weapons for your titan, basically you arm them according to the necessity of the game and the costs for more effective weapons is greater than less effective ones.
Titans also interact differently with infantry since their mighty defenses make it impossible for them to gain close combat bonuses by ganging up.
Army construction
In net epic you use army cards which give you a "preset" battlegroup (or detachment which is the term used in net epic). The formations come in company size, support and special cards. The algorithm for construction is simple. For every one company card you can add 5 support cards and one special card.
THose are the basics, keep in mind there is a LOT more o go into, but since I want to make a simple comparison between the three, lets keep it simple. Feel free to ask more in depth questions.
Epic40k
This was a brand new system, with little in common to its predecesor SM/TL
Overview
Unit stats are more streamlined listing speed, range, firepower, assault and armor.
The turn sequence is similar to SM/TL in which there is a movement, shooting and assualt phase and instead of a end phase like net epic, it has a rally phase. Players move according to initiative which depends on the army (SM has a higher strategy rating, then say IG). Instead of a standard move you can issue a special order which are: Overwatch (you cant move but you fire at units that move within 5cm of you and you re-roll misses), assault (you move faster, but your firepower values are reduced), March (you move very fast but you assault AND firepower values are halved).
Shooting is very different from SM/TL, in epic 40k each unit does not fire individually but contributes a firepower value to the whole unit that fires. You add all the firepower from the unit and cross reference a table to find out how many dice youget to roll. Firepower can be modified by various factor such as cover and open terrain. Once the amount of dice are determined you roll them against a target detachment and compare your rolls with the units armor stat. IF you roll higher than the target's armor it is removed. Their not a save per se, but their are "skills" that may provide one (more on that later).
Blast markers- Epic 40k introduces a for of suppression that reflects reduced unit effectiveness under fire. The more you get fired at (firepower), the more blast markers you get. Get enough blast markers and the unit effectiveness is seriously compromised.
Close combat is also a lot different than SM/TL, like shooting individual units and circumstances add to a global assault total plus a die roll. The higher roll wins the combat. Blast markers are inflicted in close combat. The wider the number you win by the easier it is to inflict casualties. Unlike net epic where one roll resolves close combat between two particular units, in epic 40k you need to consult a table to determine the close combat difference (how much you win the roll by). This table tells you the number you need to roll to eliminate units in close combat. Roll for each unit involved.
Skills, there are no real special rules in epic 40k, there are a handful of skills that give an extra edge to units, like marines being stubborn and re-reolling failed morale checks or heros that actually get a saving throw.
War machines, these are titans and other big units, they have a damage capacity which works like hit points, when they reach zero it is destroyed, they have some tables for damage, but not as elaborate as net epic. The war engines have few special rules and obey much thesame rules as other units (blast markers ect).
Army construction
The construction is more free-form, with fewer restrictions than net epic. You make up your own deathcmnts within the guidlines for that list. Less regimentation.
As above this is very basic, keep in mind there is more to this game than that mentioned.
Epic A
It combines concepts from both games and is currently being tested.
Overview
Unit stats are similar (in name) to epic 40k ones, but they actually have a to hit value (like net epic) and not a additive firepower value (like epic 40k). Weapon stats have returned similar to net epic as well. UNits have a close combat stat and a firefight stat which is used in close combat for units not in base to base contact (those that are use the close combat stat). For long range combat you use the weapon stats provided for that unit. Also fire has been divided into AT for anti-tank and AP for anti-personel fire.
The turn sequence is more in keeping with modern game design and offers a "unified" turn sequence where you move that unit and fire in the same activation. If you played warzone or void the mechanic is similar. This does away with the phases of the previous two games. As actions you can move, double move, march (triple moves), overwatch, charge, hold and several special actions. You complete you actions then pass play to the other player unless...
Initiative. They use the warmaster mechanic where you can retain the initiative by rolling a D6 versus a target number which depends on the army (SM retain easier than say Orks). The more you try to retain initiative the harder it gets, other factors like blast marker impact on this ability.
Blast marker, just like epic 40k, with some differences, blast marker reduce  effectiveness by "freezing" (pinned down) a unit per blast marker to simulate the the shock of firepower in combat.
Firing and saving throws are similar to the SM/net epic mechanic with the difference that you have the difference of AT and AP shots.
Close combat is a meld between the two different systems, but IMO, still looks more like the epic 40k mechanic than the SM/net epic one. Blast market are placed too and fire fights occur with models not in base to base contact.
Again, very bare bones overview of the basics, there is a lot more in this game too.
Comparison
The different systems appeal to different tastes:
1. If you like lots of detail, chrome and easy army construction method, SM/ netepic probably for you.
2. If you like a streamlined version with more abstraction of certain mechanics at the expense of detail, but more manuever and quicker resolution, then epic 40k is probably for you.
3. Epic A, is in between the two. In my view it leans more towards number two, but thats my opinion. Playtest it and decide where on the spectrum it falls.
It lacks a summary for AT, which I can add if you like. Let me know if there is an aspect that needs more depth of expanding and I'll do it.
PostPosted: Wed Jul 23, 2003 10:07 pm
It's good idea to keep Neal's & Primarch's replies close at hand as this question comes up often enough and probably will again the closer we get to E-A's birth. That being said, it appears to all of us that E-A is the way to go for the "new" Epic player ...  :;):  Good job, guys !
PostPosted: Wed Jul 23, 2003 10:52 pm
Thanks for all the replies... I'm drooling over it. And another thing I think Epic:A has going for it will be the glossy colorful rulebook/boxes...
Knowledge is power.
PostPosted: Wed Jul 23, 2003 11:28 pm
There's a pic of the rule book cover on the G/W Epic site, IIRC ...  :)
PostPosted: Wed Jul 23, 2003 11:57 pm
Quote (Legion 4 @ 23 2003 July,15:28)
There's a pic of the rule book cover on the G/W Epic site, IIRC ... ?:)
I believe this is the mock-up.
http://www.specialist-games.com/epic40k/default.htm
dafrca
              - Cities of Death, page 59
PostPosted: Thu Jul 24, 2003 1:22 am
It a good cover, I would have wanted a battle scene between loyal and traitor marines ala SM, but it all good! :)
PostPosted: Thu Jul 24, 2003 2:28 am
That is a really nice bit or artwork- reminiscent of the old SM1/2 era drawings of large plain spanning battles.
Tas
PostPosted: Thu Jul 24, 2003 7:13 pm
Quote (Tas @ 23 2003 July,18:28)
That old, large battle artwork is what pulled me into Epic. I loved the idea of a large massive battle.
dafrca
PostPosted: Thu Jul 24, 2003 8:16 pm
I know what you mean Dafrca.
I remeber fingering through those old WD's and seeing those pictures of the battle of Tallarn (the most bloodiest battle during the horus heresy with casualties in the millions!) or that picture with all the CI's and marines charging each other.
Thats what epic is all about!!
PostPosted: Thu Jul 24, 2003 10:22 pm
Quote (primarch @ 24 2003 July,12:16)
Yep, I remember one picture that shows an Eldar Titan falling after taking damage. The "little" people around it. Or the shot of a whole hord of Orks charging accross an open plane.
Man that was a fun time, when I was new to Epic and had no expectations other then a fun time trying to smash my friends army  :laugh:
dafrca
PostPosted: Thu Jul 24, 2003 11:22 pm
Quote (dafrca @ 25 2003 July,07:22)
Man that was a fun time, when I   had no expectations other then a fun time trying to smash my friends army ?:laugh:
You mean you don't now?  I know hardly have any other expectations! :D
Tas
PostPosted: Thu Jul 24, 2003 11:24 pm
I agree...those old pics were absolutely inspiring!  The one with all the CIs lined up and hordes of Guardsmen advancing before them was my favourite!
Maybe it would be worth building a gallery of all these cool pics?
Tas
PostPosted: Thu Jul 24, 2003 11:32 pm
Taz,
It would have to be unofficial or require a password or GW wouldn't like it one bit.
Maybe someone could ask Jervis, but I don't think his power extends out that far. The photos probably have corporate ownership.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
Users browsing this forum: Google [Bot] and 64 guests
