(Rules Question) Cover Saves and Counter Charges
 Post subject: (Rules Question) Cover Saves and Counter Charges
PostPosted: Sat Jan 04, 2014 11:07 pm
Do formations defending in an assault who use their counter charge move still get a cover save if in cover?
I know that an attacking formation never uses cover saves but can't find anywhere that explicitly states yes or no on the above.
Appreciated,
Ryan
MoK's Painting Blog
Now Showing:
 Post subject: Re: (Rules Question) Cover Saves and Counter Charges
PostPosted: Sat Jan 04, 2014 11:35 pm
If the target units remain in cover at the end of their counter-charge, AFAIK they still get the cover save.
Put another way, why would they lose their cover save under these circumstances?
PostPosted: Sun Jan 05, 2014 1:17 pm
I've previously played opponents who tried having me believe otherwise against my siege list, I gave them the benefit of the doubt but this essentially pinned my troops in place and meant that the flanks of trenches.or indeed many formations became very vulnerable to assault.
Cheers for clearing it up Gavin!
MoK's Painting Blog
Now Showing:
PostPosted: Sun Jan 05, 2014 1:26 pm
Because they are charging and "all the normal charge move rules apply...".
We were confused about this a couple of weeks ago too, and the rules are definitely not as clear as they could be on this I think. Couldn't find anything in the FAQ but it may have been an old one we were looking at.
PostPosted: Sun Jan 05, 2014 1:41 pm
This does pop up often and I believe has been added to the FAQ updates for better wording.
I think the main problem comes from players mis-reading the rules.
I've had games where players claim the rules say no cover save for "a charge move" and believe a counter charge comes under this move but the rules are actually no cover saves for "Taking a charge action" with the charge action being the engage action and defenders do not take an engage (or charge) action.
From 1.12.5
. Infantry units from formations taking a charge
action may not take cover saves (they are assumed to have left
cover to charge the enemy)
, but other infantry units
may take cover saves normally.
PostPosted: Mon Jan 06, 2014 9:37 am
From 1.12.5
Cheers dptdexys, though if that is the best argument in favour of this ruling then the rules could definitely do with being clarified in the FAQ I think.
I would suggest the main problem is not at all players misreading, but rules being miswritten, hence why this issue often pops up as you say. The problem is that there is no such thing as a "charge action"! "Engage" is an action. whereas "Charge" is a move - the normal rules of which also apply to a counter charge. Hence the confusion. I don't think players can be blamed for misreading a passage that conflates both an action and move in the same sentence.
I suppose the interesting question is whether or not the rule designers intended the lack of cover saves to apply to an "engage action" or to a "charge move"? I expect only to an engage action but I don't know this many years down the track... and both interpretations could make sense in terms of fluff.
Anyway, I suspect the confusion could be rectified by something like the following(?):
"Infantry units from formations taking an engage action may not take cover saves (they are assumed to have left cover to charge the enemy), but other infantry units may take cover saves normally."
PostPosted: Mon Jan 06, 2014 10:55 am
Indeed. Earlier bits of the assault rules make quite a big thing of distinguishing between the two phrases:
'1.12.3 Make Charge Move
A formation undertaking an engage action is allowed to make one move (not a double distance move as is the case in many sets of wargame rules, not least many Games Workshop games), and then fights an assault against the enemy formation that was chosen as the target of the charge. This move is known as the charge move.'
Emphasis not added by me.
So 1.12.5 contains a typo one way or another, either it's 'charge move' or 'engage action'. Given that the justification is leaving cover to charge the enemy I still think 'charge move' makes more sense in the context.
Also, if it's 'engage action' you get the absurd situation where an engaging formation that didn't move at all (already in firefight range) doesn't get cover saves while units counter-charging 10cm get cover saves. That's the kind of rule that destroys suspension of disbelief during a game. :(
The Wargaming Trader
PostPosted: Mon Jan 06, 2014 10:58 am
The NetEA rules include this:
'Q: Do the Cover Save and Cover to-hit modifier apply in Assaults?
A: Defenders in an Assault get the Cover Save from any terrain they are in but attackers never get a Cover Save from terrain. The -1 to-hit modifier is not applied as there are never any modifiers to attack rolls in Assaults.'
Which I suppose has the advantage of being very clear.
PostPosted: Mon Jan 06, 2014 11:51 am
Thanks folks: I would also read 'charge action' as 'engage action'.
R>
MoK's Painting Blog
Now Showing:
PostPosted: Mon Jan 06, 2014 1:13 pm
I think that if you say "charge action" it's much more likely mean "engage action" than "charge move".
The distinction between actions and moves is pretty clear and never used interchangeably, whereas people often say "my tacticals are going to charge your scouts" when they declare an action.
PostPosted: Mon Jan 06, 2014 8:55 pm
Even if I agree with you, "you think" still doesn't help much when people could justifiably have exactly the opposite interpretation, especially when this actually makes more sense in some circumstances, like that Wartrader just mentioned.
And the distinction is not clear at this point in the rules because the terms are conflated - that's the problem. I'd still recommend that this is clarified further in the FAQ, if not the rules themselves, given one word change would appear to eliminate the problem. If it keeps popping up despite the FAQ (with the FAQ ruling Wartrader refers to having been in place at least 5-6 years now), then clarifying the wording may be worthwhile.
PostPosted: Mon Jan 06, 2014 10:49 pm
Calling the Engage Action move a Charge Move (to differentiate between a normal move) is what allows you to enter a ZofC to get into base contact.
The engage whilst staying still is already covered in the overwatch and movement FAQ sections.
A move, even if the player moves 0 is still considered a move.
From overwatch section,
Q: Is a formation that is allowed to move as part of an action, but which
decides to remain stationary, considered to be moving for the purposes of
triggering Overwatch fire? For example, if I take an Engage action, but don’t
move any units as they are already within firefight range of the enemy, can
my opponent make an Overwatch attack before the Assault takes place?
A: Yes, to both the question and the example. Overwatch is triggered when an
enemy formation “completes a move”. Formations that could move but
remain stationary have still “completed a move” and are therefore eligible
targets.
From Movement scetion,
Q: One of the FAQ entries draws a conclusion that seems overly broad to me.
Section 1.7.1 talks about various orders allowing formations to move. The
Overwatch section of the FAQ rules that any time a formation is allowed to
move, it must move.
A: You can move zero, if you wish, but that is still considered a move. You
don’t have to move. In fact, some orders like Sustained Fire require you to
stay stationary. Other than that order, you are merely moving zero.
Withdrawls are different, in that they are optional movement. If you choose
not to move, you have not moved and do not allow a formation in
overwatch to activate against you.
When a unit does break, it does choose where and if to withdraw. I
personally advance my broken formations. There is a chance they may
unbreak next turn and it provides consternation to my opponent. However,
if you end your move (and yes, you can still move zero) within 15 cms of an
enemy, the unit is destroyed.
PostPosted: Mon Jan 06, 2014 11:01 pm
You're missing my point - regardless of the rules about 0cm moves, it 'feels' wrong to have a formation that moved further keep it's cover saves and a formation that moved 0cm automatically lose it's cover saves.
PostPosted: Mon Jan 06, 2014 11:24 pm
I don't see how it feels wrong because to me it doesn't, your engaging another formation and know the positives and negatives of that action.
For me it stops gamey situations of players trying to take advantage of rules and situations and negates having to track which units have or haven't moved.
PostPosted: Mon Jan 06, 2014 11:33 pm
We'll have to agree to disagree on that.
Users browsing this forum: No registered users and 96 guests
