dangerous terrain tets for countercharge and consolidation?
 Post subject: dangerous terrain tets for countercharge and consolidation?
PostPosted: Fri Jan 03, 2014 7:23 pm
Are these "moves"? You don't get to overwatch when these happen, do dangerous terrain tests not apply as well?
 Post subject: Re: dangerous terrain tets for countercharge and consolidati
PostPosted: Fri Jan 03, 2014 8:27 pm
Dangerous Terrain tests would still apply, Overwatch has specific conditions to be met for which movement count for allowing overwatch, from FAQ.
Q: Does a counter-charge trigger Overwatch?
A: No. The “move” referred to in the OW rule refers to moves made as part of
an action, as described in section 1.7.
Dangerous Terrain tests have no specific conditions to be met for which type of movement trigger the test, it is only when entering or starting to move whilst in Dangerous Terrain that matters.
1.8.1 Dangerous Terrain Test
Roll a D6 when you enter dangerous terrain, or when you start
to move if already in dangerous terrain
. On a roll of 1, the unit
is destroyed with no save allowed, but the formation it is part of
does not receive a Blast marker.
Units may choose to move through dangerous terrain cautiously.
A unit that is moving cautiously counts as having a speed of
5cm, but is allowed to re-roll any Dangerous Terrain tests that it
fails.
To help me understand why I class it as the overwatching formation don't want to hit their own troops that are making the assault as they are too close for getting safe shots off (don't want to cause friendly fire).
PostPosted: Fri Jan 03, 2014 8:28 pm
I believe they should be as well.
However, as 5cm moves are treated as moving cautiously, in most instances they would be saved.
PostPosted: Fri Jan 03, 2014 8:30 pm
However, as 5cm moves are treated as moving cautiously, in most instances they would be ignored.
Technically they could re roll a DT test.
PostPosted: Fri Jan 03, 2014 9:08 pm
Can you move cautiously with a counter-charge or consolidation?
I can't really see a unit "cautiously counter-charging", likewise isn't the consolidation is meant to represent the movement during an assault? Can't see that being a time for caution either.
PostPosted: Fri Jan 03, 2014 11:28 pm
We play it Gingers way...
MoK's Painting Blog
Now Showing:
PostPosted: Sat Jan 04, 2014 1:23 am
Well, DT tests only tend to apply to vehicles, often these can move 10cm in a counter-charge or in Eldar consolidation considerably further. The DT test (or cautious move) acts as a reasonable risk/constraint.
And I am less sure that consolidation represents movement during the assault - I thought Hack-down hits did that. I always understood that Consolidation was a post-assault activity, hence why consolidation back into air-transport is deemed to take place at the end of the turn and thus replaces disengagement.
Users browsing this forum: No registered users and 126 guests
