Just one more thing... Void shields
 Post subject: Just one more thing... Void shields
PostPosted: Thu Sep 05, 2013 8:28 pm
Colombo impression here i come : http://www.youtube.com/watch?v=biW9BbWJtQU ;D
So this came up last night. Seemed like a dumb question but in light of "the great flak debate" were weren't so sure. Couldn't find an FAQ (though i'm sure someone now will :D ) We had a titan which got hammered in FF but ended up winning as we decided the hits on void shields don't count in resolution. Were we right ?
Hits on titan void shields. Do they :
A. Count in the assault resolution ? (The chart says "kills" but we know hits on multi DC WEs do count.)
B. Generate blast markers (inc the one for coming under fire.)
 Post subject: Re: Just one more thing... Void shields
PostPosted: Thu Sep 05, 2013 9:10 pm
They don't count for combat resolution or BMs, though of course you would receive one for coming under fire.
PostPosted: Fri Sep 06, 2013 8:35 am
Remember only BMs cause adverse effects, not Hits (check out 1.3 on Blast Markers).
As Zombo says, Hits on shielded titans do not count where they do not cause damage and thus generate a BM, either in shooting or assault. From the rules:-
SPECIAL RULE
5.4.1 Imperial Void Shields
Imperial Titans are protected by void shield generators. The number of void shields each Titan has is noted on the Titan’s datasheet. Each void shield will automatically stop one point of damage and then go down. Do not make armour saves for damage stopped by void shields, nor allocate Blast markers. Once all of the shields have been knocked down, the Titan may be damaged normally and you may make saving throws against any hits that are scored.
(my emphasis)
PostPosted: Fri Sep 06, 2013 9:11 am
I might be new to the game, but that doesn't appear to tally up with anything in 1.3. Surely it should be 'Remember that only damage causes adverse effects in combat, not hits'? The BMs are coming from the damage after all.
This still gives us an explanation in that Void Shields stop the damage from happening.
The Wargaming Trader
PostPosted: Fri Sep 06, 2013 7:30 pm
Well at least this didn't cause an international incident ;)
Sounds like we were playing it right (presuming IJW is correct in his clarification of "damage.")
Thanks all.
PostPosted: Fri Sep 06, 2013 7:35 pm
He is. A stand removed or a WE that lost a point of damage is what counts in assault resolution, not merely hitting something with your CC or FF value.
Users browsing this forum: No registered users and 125 guests
