Multiple Barrage Templates
 Post subject: Multiple Barrage Templates
PostPosted: Sun Jan 06, 2013 4:10 pm
Hi all! Another quick question:
I have two barrage templates covering an enemy formation of 4 units. When placing the templates, I cover all 4 units but one of his stands is covered by the two templates due to how I had to connect the two templates.
How many hits do I roll?
1) I roll 4 dice since I cover all 4 units
2) I roll 5 dice (the extra dice is since I cover one of his units "twice" with the two templates)
We have been playing it as option 1 but wanted to make sure.
Thanks!
 Post subject: Re: Multiple Barrage Templates
PostPosted: Sun Jan 06, 2013 4:23 pm
You are correct, the templates just designate the total area hit by the barrage
The only case where units take multiple hits from a single barrage is in the case of war engines
PostPosted: Sun Jan 06, 2013 4:39 pm
Agreed. The templates are placed so that they touch each other without overlapping, and designate those units that are affected by the barrage.
Note, this is the one occasion where the normal "front to back" mechanic is not applied. Ideally you dice to hit each unit in turn and then resolve the actual hits separately, though you can speed this up by dicing for each group of similar units.
PostPosted: Sun Jan 06, 2013 6:40 pm
there are some people who play the 'front to back' method with barrages, the templates tell you how many dice to roll, but casualties are removed front to back as per normal shooting..... I'm not sure if this was in the rulebook at some point, but it does prevent barrage 'sniping' and means tyranid players don't have to adopt strange shaped formations to prevent the precious synapse-warriors being shot from miles away.....
PostPosted: Mon Jan 07, 2013 10:44 am
Fine as a house rule (though it throws up its own weirdness), but the rules are pretty clear: "roll to hit all units under the template".
PostPosted: Mon Jan 07, 2013 11:31 am
That was never in the rulebook, and it's always been either a house rule, or a simple misunderstanding of the rules.
Here's the wording from the first test version of the rules that Jervis put up on the web in the early part of the 2000's:
To fire a barrage declare take a barrage template and place it on the table where you want the barrage to land. You are allowed to place templates over your own units, or units from several enemy formations, just so long as you get as many units from the main target under the templates as you possible can. All units –friend and foe alike – under the templates are attacked.
Next refer to the data sheet to work out the total number of barrage points. The whole formation fires at once, so the number of barrage points for each weapon added together to find the total number of barrage points. When you have worked out the total of barrage points refer to the barrage table below.
The barrage table tells you the hit roll required to hit each unit under the barrage template. Roll to hit all units (friend or foe) under the template with the appropriate to hit values. If formations other than the main target formation suffer any casualties then they receive one blast marker for each unit lost. In order to speed dice rolling we recommend rolling to hit all units of exactly the same type together, and then removing any casualties from those closest to the enemy first. For example, if you ended up with an Imperial Guard Commander, six Guard infantry stands, and three Fire Support stands under a set of bombardment templates, I’d roll once to see if the commander was hit, then roll six dice all together to see how many of the Infantry stands were hit, and three dice altogether to see how many fire support stands were hit. You get the idea, I’m sure!
The example of play got removed before final publication, but the basic wording remained the same.
PostPosted: Mon Jan 07, 2013 11:43 am
I think there are some other occasions, generally special attacks such as critical hit explosions that hit specific nearby units, and I think Drop Pod Deathwind attacks as well?
Users browsing this forum: No registered users and 121 guests
