May or must engage into base to base ?
 Post subject: May or must engage into base to base ?
PostPosted: Mon Nov 12, 2012 6:48 pm
Can a unit that makes an Engage action enter an enemy zone of control without going into base to base if it has enough movment to do it ?
I suddenly have a doubt !
 Post subject: Re: May or must engage into base to base ?
PostPosted: Mon Nov 12, 2012 7:44 pm
AFAIK, there is no compulsion to move into B-B during a charge even if you enter an enemy ZoC, the only compulsion being that if you do enter the ZoC of an enemy unit, you must move towards the enemy unit whose ZoC you have entered (1.7.3 2nd para).
However if you elect to make a counter-charge, I think you may be required to use the entire move at that point (1.12.4 3rd para) - towards the nearest enemy, which may not be the chargers.
PostPosted: Tue Nov 13, 2012 12:36 am
Here is the relevant FAQ from the NetEA tournament Pack 2012:
Q:How should we interpret section 1.12.3 when it says “Remember that a charging unit that enters a zone of control must move into base contact with the nearest enemy whose zone of control has been entered”?
A:The intent of the rule is that if you enter a ZoC, then you must attempt to move into base contact with the nearest enemy unit whose ZoC you have entered. If you start a move in a ZoC, you can either move into contact with the closest enemy unit, or exit the ZoC by the shortest possible route.
If a unit does not have enough movement to make it into base contact it still moves as much as possible towards the closest unit. The intent of the rule is that you should not be able to charge through a ZoC to reach a unit further away but should always move towards the closest enemy unit even if you cannot make it into base contact.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
Users browsing this forum: No registered users and 131 guests
