normal and TK shots in same shooting match
 Post subject: normal and TK shots in same shooting match
PostPosted: Mon Jan 23, 2012 7:02 pm
Hi All
Assuming a Warlord is attacking another WE.
The warlord has 16 AT shots + 1 TK(D3) shot.
How would one work this since it is of course preferable to shoot away the void shields using the normal AT shots and then use the TK weapon to blast the hull.
Is it acceptable to shoot with the AT shots first, (hopefully) taking down the void shields and then the TK weapon on the hull?
Thanks
 Post subject: Re: normal and TK shots in same shooting match
PostPosted: Mon Jan 23, 2012 7:06 pm
You allocate MW (and thus TK) hits after the regular hits are allocated and saved for.
PostPosted: Mon Jan 23, 2012 7:12 pm
Cheers Dave
PostPosted: Mon Jan 23, 2012 7:42 pm
To expand a bit on what Dave said, there are basically 2 rounds of hit allocation. Normal AP and AT hits are allocated and resolved. Then all MW hits are allocated and resolved (starting over front to back as normal).
PostPosted: Mon Jan 23, 2012 10:31 pm
Thanks Neal
Does that apply to assaults as well?
PostPosted: Mon Jan 23, 2012 10:44 pm
It does, closest being base-to-base.
PostPosted: Mon Jan 23, 2012 11:44 pm
is this the same for hits from lance weapons too? it's how we play it in our group, but is this the 'official' way?
PostPosted: Tue Jan 24, 2012 3:06 am
There's never been an official way for allocating Lance, or Ignore Cover. We'd probably play Lance as a separate allocation phase between regular and MW (don't think it's ever come up though). For Ignore Cover we try to maximize the hits on things in cover where possible (ie no allocating IC to things out of cover when there are other things in cover that they could go on instead).
PostPosted: Tue Jan 24, 2012 9:12 am
Officially Lance, Ignore Cover etc are allocated with normal hits and it's up to the defender to place them, so Disrupt hits tend to hit grots, Ignore Cover hit the troops out of cover etc.
However, a lot of people play a "Gentlemen's Convention" that hits should be allocated in such a way as to make use of their special abilities wherever possible, so apply the lance hits on guys with reinforced armour etc, as long as that is possible. It's only a convention though, and not the official rule, but it's much fairer.
PostPosted: Tue Jan 24, 2012 9:28 am
I assume this is the kind of thing to be discussed in the 5-minute warm up during a tournament then?
PostPosted: Tue Jan 24, 2012 9:42 am
Yes.
PostPosted: Tue Jan 24, 2012 11:27 am
Also, am I going mad, or does the warlord only get 12 AT shots, and not 16?
PostPosted: Tue Jan 24, 2012 11:38 am
yeah it's 12, 4 from the gatling cannon, 8 from the TLDs
PostPosted: Tue Jan 24, 2012 12:13 pm
lol
Yea - my maths sucks :)
PostPosted: Tue Jan 24, 2012 2:26 pm
As others said, the "special" hits are allocated as part of the appropriate round, i.e. AP and AT hits with special abilities in the first round, MW hits with special abilities in the MW round. Defender allocates the hits within the limits of the rules (closest first, in range, LOS), so the defender directs where the special ability hits go.
Users browsing this forum: No registered users and 130 guests
