Hi all,
My Battle for Armageddon Boardgame-based Campaign fan supplement is available here for playtesting and initial feedback:
File comment: Battle for Armageddon Boardgame-based Campaigns
BattleforArmageddonCampaignRulebook1_2.pdf [159.09 KiB]
Downloaded 765 times
This BFA-based campaign system allows Epic games to replace the abstracted battles between counter "stacks" in the boardgame. It also allows for occasional small skirmish WH40K games ("strike opporunities") that proceed the Epic battle, serving to modify the Epic battle that follows in some meaningful way.
If anyone here either has BFA or has the motivation to download it and make your own copy, it would help me a lot if you would play a game or two of BFA using the campaign rules, and then send me your feedback. For those interested in downloading it, there's a Zip with everything you need, including the board fixed by Rastamann and the Chaos Attacks expansion, available here:
https://sites.google.com/site/sydneyepic/dashboard/resourcesAs this is my first attempt at such a supplement, I am open to any and all feedback you may have. Thanks in advance.
ABOUT THIS FAN SUPPLEMENT
I've been working on this fan supplement off-and-on since 2008. At one time, it was a massive tome weighing in at more than 200 pages (that version, which I've kept as a separate branch, is a hex-based map campaign system that does not require Battle for Armageddon), but it more recently morphed into a less ambitious system that leverages the excellent Battle for Armageddon boardgame.
