Land Raider Terminus Ultra
 Post subject: Land Raider Terminus Ultra
PostPosted: Tue Jun 28, 2011 7:21 am
I need the opinion of the following vehicle:
Type: AV
Speed: 25cm
Armour: 4+
CC: 6+
FF: 4+
weapons:
3×twin lascannon 45cm AT4+
2×lascannon 45cm AT5+
hunter-killer missile 60cm AT4+/AA5+
Reinforced armour, thick rear armour
175 point / each (Land Raider upgrade +75 point / each)
A point value is ok? Change anything?
Into the fires of battle, unto the anvil of war!
http://www.epichq.blog.hu
 Post subject: Re: Land Raider Terminus Ultra
PostPosted: Tue Jun 28, 2011 8:40 am
too cheap as an upgrade
PostPosted: Tue Jun 28, 2011 8:44 am
+100?
PostPosted: Tue Jun 28, 2011 10:06 am
If you price a vehicle cost at 175 points (whether correct or otherwise), the upgrade cost will be in that vicinity.
So an upgrade could be as much as +125 to +175 points
It cannot be too cheap as although you have taken away the transport capacity, it hits AT very well with a lot of shots which is meant to be an uncommon thing.
I will not even pretend to like this vehicle, and with 6 shots per round, it leaves some War Engines wondering whether they are being outclassed. Remember this thing also gets a SR5, Init1+ and ATSKNF. Being bought as a single also allows it in a formation to garrison and start on Overwatch. These are just some of the things to consider when working out a cost. It is a lot better than a standard LR if you require the shots and not the transport capacity.
PostPosted: Tue Jun 28, 2011 11:53 am
... A note on the upgrade... if it's replacing a land raider then the points are about right...
FF should probably be 6+ since the thing has no real close short range/AP weapons, the thing is just a heavy gun boat (tank). I'd drop the hunterkiller too, Ni on all imperial vehicles can take them, none of them have it.
If it's 0-1 per Landraider formation, it wouldn't be too bad however it is a very strong tank (on advance odds are you get 2 AT hits per turn, 3 on sustain.) That thing has a 70cm threat range too.
PostPosted: Tue Jun 28, 2011 2:35 pm
I made up a Terminus for inclusion in the Apocrypha of Skaros.
Its stats were the same as yours, but I left off the HK missile. I charged between 100 and 125 points for it, depending on the list version. Of course, I'm erring on the side of "I'm a lot more likely to hear if it's too cheap than the reverse".
Honestly, if I could have given it fewer shots, I would. So I'd definitely recommend leaving off the HK missile.
The Apocrypha of Skaros 1.1
Rogue Trader Expedition 0.4
The Horus Heresy 0.5
Night Lords 0.1
My Trade Thread
PostPosted: Tue Jun 28, 2011 2:43 pm
Seconded on FF6+ and dropping the Hunter Killer Missile - that shouldn't be represented in Epic.
150ish as an upgrade could be a starting price to test and I would probably add the option to Devestator, Land Raider and Predator formations. They're meant to be rare and to stop them altering things too much I would make them 0-1.
PostPosted: Tue Jun 28, 2011 3:49 pm
OK, thanks.
Are you sure you throw missiles? The tank's weapons include: http://www.games-workshop.com/MEDIA_Cus ... Raider.pdf
It looks good on it... 8)
The FF is 6+
Cost: +150 point / each
In my opinion, not worth more, it is worth two and a half Land Raider. It is true that many shots, but only one armour save and no transport capacity.
PostPosted: Tue Jun 28, 2011 4:21 pm
The HK missile isn't standard, anyway. Non-standard upgrades virtually never get included in Epic. Plus, it makes the thing a lot more useful - and you want this to be weaker, not stronger.
Personally, I think FF4+ (or 5+) is still quite justifiable. The ordinary LR only has two TLLCs and the TLHB, after all - an extra TLLC and two more LCs ought to be worth a fair bit in a firefight (they're certainly as dangerous as five Guardsmen or five Assault Marines).
Night Lords 0.1
My Trade Thread
PostPosted: Tue Jun 28, 2011 6:02 pm
ok. I give myself. I throw the rocket ...
PostPosted: Wed Jun 29, 2011 12:13 pm
is there any way of mimicking the 'power overload' rule from 40K. does epic have a 'gets hot' equivalent?
PostPosted: Wed Jun 29, 2011 12:16 pm
Slow Fire.......and I hate it and wish I could throw it out of a airlock...well at least on units that aren't WE
PostPosted: Wed Jun 29, 2011 2:19 pm
Indeed. Slow Fire is basically Satan, IMO.
Night Lords 0.1
My Trade Thread
PostPosted: Thu Jun 30, 2011 3:14 pm
Yesterday I tried the Terminus Ultra.
Not worth 250 points, because efficiency is nowhere near the Warhound.
Max 200 points.
PostPosted: Thu Jun 30, 2011 5:17 pm
Max 200 points.
Why that high? I thought you'd costed it at as a 150 point add-on to a formation?
Users browsing this forum: Google [Bot] and 61 guests
