Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
Komandoes ????
 Post subject: Komandoes ????
PostPosted: Tue Mar 22, 2011 10:56 am
Does anyone use komandoes in epic ?
I don't see the point in them, but as an old blood axe would like to find a good use for them ?
I am using the GW Gazz Hoard army.
I am just interested in your experiences/ ideas :)
 Post subject: Re: Komandoes ????
PostPosted: Tue Mar 22, 2011 11:28 am
Not really. In general they're not that useful.
Even in the EpicUK version of the Gaz's Ork list where they get their own formation, they cost the same as Stormboyz formations but are not as good (Ie: They're overpriced even in that list).
They're pretty much the only "dud" unit in the Ork list.
PostPosted: Tue Mar 22, 2011 1:06 pm
Cheers !
I was thinking that I was missing something, but it seams that they are useless ??? Its a shame as I like the models...
Thanks any way !!
PostPosted: Tue Mar 22, 2011 2:13 pm
I wouldn't call them useless. They're scouts, so you can use them on their own for area denial and ZoCing. As infiltrators they're handy as additions to mobz as they allow you to base-to-base up to two units when engaging, which is nice for Orks if they're engaging a high FF low CC unit that they can't quite reach with a 15cm charge.
They're basically exchanging the free Grot unit that comes with a Boy unit for these abilities, I think that's a pretty fair shake.
PostPosted: Tue Mar 22, 2011 2:15 pm
Only dud? How about the battlefortress?
Been a while since I looked but I think there are some variant lists in the orc section that make better use of kommandoes
PostPosted: Tue Mar 22, 2011 2:18 pm
Didn't it get a points drop in the TC & EUK lists and now it's fine?
PostPosted: Tue Mar 22, 2011 2:19 pm
Battlefortress has some potential uses; kommandoes are just flat out worse than stormboyz.
PostPosted: Tue Mar 22, 2011 2:20 pm
Really? I thought Grots were the best FF unit in the Orc army (and if the warband gets into CC it should win anyway).
For me at least, if I buy a Boyz + Grots pair, it's for the Grots, not the Boyz...
edit: The models do have one use; if I was starting an Ork army from the current SG boxed sets I would mix them with Nobz on the stands to stretch out the warbands I could make - you get enough boyz and grots for 4 small warbands, and if you make stands of mixed mega-armored nobz and unarmored nobz (kommandos) you get enough nobz as well.
PostPosted: Tue Mar 22, 2011 2:33 pm
? Last time I checked Grotz were FF 6+. :P
You're right on Orks winning more in CC though, Kommandoes extend that range by a wide margin which is pretty handy.
PostPosted: Tue Mar 22, 2011 3:08 pm
I use'm ... cause they are ... Kool !!!! ;D
PostPosted: Tue Mar 22, 2011 3:15 pm
Grot rules, grot kills doesn't count for combat resolution.
PostPosted: Tue Mar 22, 2011 3:24 pm
A truly grate reason !!!
And I like the battle fortress !!!
PostPosted: Tue Mar 22, 2011 3:29 pm
Is it not worth having a mixed formation of 1-2 Kommando and the rest Stormboyzs, so that the formation gets a ranged attack? They're scouts so the Kommando can be set up far forward and the formation can chain with the 20cm ZOC. It's what I was thinking of using.
PostPosted: Tue Mar 22, 2011 3:33 pm
Given the difference in speed and role between the two unit types, I can't see how you wouldn't be better off keeping them separate. A Deth Kopta or two added to a Stormboy formation gives them a cool ranged attack with a great save.
PostPosted: Tue Mar 22, 2011 3:37 pm
Indeed ... ;) :D ;D
Users browsing this forum: Google [Bot] and 114 guests
