Starter sheet for new players
 Post subject: Starter sheet for new players
PostPosted: Wed Mar 02, 2011 10:14 pm
I am running an intro to EA this weekend at my FLGS and put together a sheet of Army Lists and other important info. I was wondering if any of you would recommend adding anything else to the sheet. I want to keep it at 1 page max, so that is the main requirement. Thanks for any help or comments.
Epic Starter Sheet.doc [35 KiB]
Downloaded 399 times
 Post subject: Re: Starter sheet for new players
PostPosted: Wed Mar 02, 2011 11:13 pm
Thanks for the link :) However, the site is called 'Armyforge' not 'Army Forge' (easier to find on Google).
Also the heading 'NetEpic Armageddon' should maybe be changed to 'NetEA' so as to be consistent with the rest of the page, could confuse people?
Is there room for a pic of someone's awesome EA army?
An online epic force creator:
Armyforge
PostPosted: Wed Mar 02, 2011 11:22 pm
Following Adam's comments, I would also title the sheet "Epic Armageddon", and use that throughout the document or the abbreviation "E:A". You need to be very carefull about confusion with NetEpic (an earlier varient of the game that still has a following on TacComs)
You might also change the font of the column titles to distinguish them from the contents.
Finally, I think the Epic-UK lists are rather more extensive than you credit them.
There are a number of other forums (eg Warseer) that you might want to reference - though this could confuse,
PostPosted: Wed Mar 02, 2011 11:56 pm
All,
Thanks for the recommendations. I changed up the Armyforge bit, cleaned up the acronyms, and changed fonts for the army lists. I also added in a portion how many of the lists overlap between the three sources of army lists. I wanted to concentrate more on what NetEA and Epic-UK add in regards to variant lists, rather than the adjustments made to the more official ones. This would give a new player a good idea what is out there for them to collect and play with. I was considering putting Warseer and others, but in all honesty, I see Taccom as a better resource due to higher traffic (for Epic that is).
I will see if I can add some of my painted Krieg or LATD stuff later. Will update if I can get the time. Thanks again!
Epic Starter Sheet 2.0.doc [35.5 KiB]
Downloaded 697 times
Users browsing this forum: No registered users and 93 guests
