Help making an ork list with my old models
 Post subject: Help making an ork list with my old models
PostPosted: Wed Dec 02, 2009 7:40 pm
I am planning to go out to a local epic night, with my long mothballed epic orkseses.
I have been reading the book and checking out online lists, but I am a little stymied by the army list. It's almost as if there are too many choices, so without having played the newest version of the game, I am a little at sea about unit sizes and composition.
I am going to post my available models list; any help anyone might like to give me would be appreciated. I am most excited about the gunwagons, stompas, and battlefortress models, so would like to use a vehicle heavy force.
Ork Warlord
0 Warlord Stands (can make one)
Ork Oddboyz
3 Lifta-Droppas
3 Bubble Chuckas
3 Pulsa Rokkits
0 Big Gunz Stands
Ork Nobz
4 Stands (can make more)
Ork boyz
12 Stands with heavies (can make more)
70 Stands with no heavies
Ork Grotz
4 Stands
Ork Stormboyz
4 Stands
Ork Kommandoes
4 Stands
Ork Warbikes
5 Stands
Ork Warbuggies/Wartracks
10 buggies
Ork Skorchas
8 skorchas
Ork Deth Koptas
0 koptas
Ork Battlewagons
45 Green Plastic Battlewagons
19 Red Plastic Battlewagons
16 Grey Plastic Battlewagons
Ork Gunwagons
6 Spleenrippas
3 Lungburstas
2 Gutrippas
2 Bonecrunchas
1 Gobsmasha
Ork Flakwagons
2 Weirdboy Battle Towers
Ork Battlefortress
2 Gibletgrindas
Ork Gunfortress
1 Skullhamma
Ork Killa Kan
0 Killa Kans
Ork Dreadnought
6 plastic dreadnoughts
1 metal dreadnought
Ork Big Gunz
10 Traktor Kannons
6 Shokk Attack Gunz
2 Hop Splat Gunz
Ork Stompa
6 Stompas
Ork Supa Stompa
1 Supa Stompa
Gargant
1 Gargant
Great Gargant
0 Great Gargant
Fighta-Bommers
0 Fighta Bommers
Landa
0 Landa
Kill Kroozer
0 Kill Kroozers
Battlekroozer
0 Battlekroozers
Other models
Ork Boarboyz
5 Boarboyz stands
Ork Wildboyz
4 Wildboyz stands
PostPosted: Wed Dec 02, 2009 9:57 pm
Heh, if you want some more infantry,  I can bring some sprues to Da Bunka tomorrow.  That being said,  you should look at what Chad (Shaggrud Deathblasta) runs.  His list is fairly brutal.  That being said I'm debating on whether to run chaos or squats :)
PostPosted: Thu Dec 03, 2009 2:24 pm
What Squat list do you play with? I'm trying to put one together as we speak and would love some pointers :D.
Tom Webb
PostPosted: Thu Dec 03, 2009 2:44 pm
I've like to help but I've only played against Orks and don't feel I have enough experience to comment all that much.
Looking over what you have you seem to have a good amount of a lot of things. You could do with more Nobz stands and Grotz stands - Grotz are very, very useful in epic, because their death does not cause blast markers or a point of combat resolution to the opponent. Oddboyz generally are good. Many SM era units, particularly vehicles are more abstracted into gunwagon, battlewagon, etc  these days. You'll want Flakwagonz for ground AA too, not sure how many you might have. You should really try to acquire some Fighta-Bommerz if possible as these are very useful for lots of things, possible a Landa too.
Checkout the Strategy and Tactics section of the forum though, there are some Ork threads and tips there that may help.
PostPosted: Thu Dec 03, 2009 3:34 pm
The main issue you're going to have is lack of AA ability.  Without any Fightabommas and limited flakwagons, you're basically wide open.  Eventually, you'll need to pick up some of those units but with all the Gunwagons you could probably scratch build some AA turrets.
If you want to stick with vehicle-heavy, you could make a ~2000 point list like this...
Warband + 2 gunwagons, 3 battlewagons, 1 Flakwagon (that gives one spare transport slot) - 410 points
Warband + Battlefortress + Gunfortress - the gunfortress is for firepower and to run in front of the Battlefortress.  Depending on the situation, you may be able to leave the Battlefortress loaded with troops so you can use a long-range assault. - 460 points (official) or 440 points with the NetEA/EpicUK mods
Big Kult of Speed - all the Skorchas and Warbikes, fill in with Buggies
Big Blitz with 2 Oddboyz (your choice) - optimum composition is usually considered to be a ratio of 1 Oddwagon, 1 Gunwagon, 2 Flakwagons but you're limited on flakwagons - 350 points
Blitz with 1 Zzapwagon (You could also add a Gunfort to this - in addition to the firepower, having a WE to block line of sight to the rest of the formation can be useful for shielding that valuable Zzap) - 200 points
Blitz with 1 Zzapwagon - 200 points
Another way to go with the models you have is a slow, tough wave.  You can make a 2000 point base with that as well.  It would need some fast elements and some smaller formations to provide flexibility with respect to maneuver and activations but it would be a durable core to build on.
A warband with 2 Stompas and 2 Dreads - This formation can garrison.  The Stompas and Dreads are Walkers, so they are good for moving in cover with the infantry.  If you have to get in the open the infantry can use the vehicles for cover saves.  You only have enough for 2 warbands, so you can't do this and 2 mechanized mobz. - 420 points
Stompas + Supastompa - 475 (official), 500 (NetEA/EpicUK mods)
Gargant (obviously) - 650
Uge Big Gunz + 3 Oddboyz - Personally, I mount several Shokk Attaks on one stand and count those as an Oddboy.  That would give you 12 stand + 3 Oddboyz.  Optimally, I would suggest adding a Nob or two if you can scrounge up the models. - 475 (plus any Nobz)
Pretty much any mix-n-match of those could work as long as you plan for the formations to work together.  Aside from the lack of AA, you could have a functional and well-rounded 3500+ point army if you threw it all on the board.  Aircraft and a few flakwagons for the infantry mobz would get you to a solid 4K army and give you a lot of choices at lower point levels.
Basically, your models come out to pretty nice even formations.  There aren't very many obvious things to fill in for expanding the army but if you decide to, some things you can do with relatively few models:
* Fightabommas - great aircraft and can boost activation count
* Landa for air assaults
* Another Warband, for air assaults or to move to a Big formation
* Stormboyz formation - 6-8, plus 1-3 Deth Koptas is a popular choice
Users browsing this forum: Google [Bot] and 130 guests
