Rules question - Rolling for criticals
 Post subject: Rules question - Rolling for criticals
PostPosted: Sun Aug 02, 2009 4:12 am
Following on from another thread.
My Shadowsword takes 5 points of unsaved damage, having already taken 1 point of damage in a previous turn.
Do we roll for 2 criticals, or 5?
PostPosted: Sun Aug 02, 2009 5:10 am
No idea. I would assume it's 5. There doesn't seem to be any reference to 'max capacity'.
My concern is those units that get a random movement. If a Warhound cops two criticals from the same firing action, does it stagger twice?
Morgan Vening
PostPosted: Sun Aug 02, 2009 8:57 am
You would roll for 2 criticals.
FAQ
Q: In the rulebook in section 3.2.3 it
says to roll for a Critical Hit for every
hit made on a War Engine. Do you
actually roll of each hit or for each
point of damage that the WE takes?
A: Roll for a Critical Hit for each point of
damage
not for each hit. Only damage to a
we can potentially cause a Critical Hit, not
just hitting the War Engine with fire.
PostPosted: Sun Aug 02, 2009 9:41 am
...Only damage to a
Sounds to me that you don't roll for criticals for saved hits. But if a Shadowsword takes 5 hits and don`t save anything then it has to roll 5 times for ciritcal hits.
PostPosted: Sun Aug 02, 2009 9:50 am
But it only takes 3 points of damage not 5 despite how many failed saves it makes it can only take 3 points of damage.
The mention of hits is in regards to the rulebook at 3.2.3 misrepresenting hits as failed armour saves and being misleading.
PostPosted: Mon Aug 03, 2009 3:22 pm
FAQs are not reviewed and parsed out carefully like rules are.  Also, they are written in response to a specific question.  That particular FAQ was a response to the critical hit rules which confuse "hits" and "damage" in their text.  It was intended to clarify whether a WE had to roll for every hit, or only those that caused damage.  It doesn't address this question.
I think it can be done either way.
Personally, I'd go with 5, as the WE did actually suffer 5 unsaved hits, each of which did a theoretical point of damage.
Plus, if you're hitting it with that much damage, you should have a pretty good chance of getting a huge explosion.   :p
It's just the Ork in me, baby...
Dakka Dakka Dakka Yippee Yo Yippee Yay
PostPosted: Mon Aug 03, 2009 4:16 pm
I'm with Neal. It's not clear one way or the other, so go with the most cinematic version, i.e. the version with the highest chance of stuff exploding.
PostPosted: Mon Aug 03, 2009 4:28 pm
I've always played with 'dc lost' number of critical hit attempts, although I can see the funny in allowing more than that.
Users browsing this forum: Google [Bot] and 188 guests
