Vassal Map
 Post subject: Vassal Map
PostPosted: Fri Jun 19, 2009 1:23 am
Does anyone have made a ready to go map? With the deloyment zones for sides and corners marked, the half way lines and most importantly the GT standard level of terrain added?
PostPosted: Fri Jun 19, 2009 8:49 am
Chris this thread on the vassal forum has saved games of two maps I've done to try and create the feel of a tournament board. The buildings are on darker areas of ground that are designed to show the edge of the terrain.
No deployment zones marked. What I do now is put an infantry stand on the edge and move it forward 15cm's using shift and the correct direction arrow (move 5 cms up or down). Then I clone this across the board. Same for the centre line.
PostPosted: Fri Jun 19, 2009 3:39 pm
How do you make maps? I can unpack the model but how do I manipulate a map in say GIMP?
PostPosted: Fri Jun 19, 2009 3:49 pm
Short answer, You don't.
Start a game. Build the table then save it. When you want to play load this saved game instead of starting a new one.
PostPosted: Fri Jun 19, 2009 6:11 pm
Vassal maps are a graphics file... .png sometimes or .gifs IIRC basically open source.  The big issue I had with them was aligning a scanned hex map with Vassal's hex overlay, but this is not a big problem with Epic.  :-}
It is possihl4e to make 'counters' for terrain, and set their properties so they can't be manipulated in game (or manipulated only with an Alt-click).
You might look at VASL for a wealth of geomorphic maps -- these too should be open source, and shouldn't be too difficult to port.
