engage
 Post subject: engage
PostPosted: Sat Apr 25, 2009 11:44 am
in the engage the zoc doesn't count right? but with my movement i can go thru  another enemy unit to reach the most far of them in Close combat?
PostPosted: Sat Apr 25, 2009 11:49 am
If you check the rules for movement, 1.7.3 Zones of Control, it clearly states that ZOC:s may not be entered, unless engaging. When engaging and entering ZOC, you have to make contact with the nearest enemy whose ZOC then is negated so you can engage the next unit and so on.
That is why close combat specialist troops often have the Infiltrators rule, to be able to ignore ZOC:s so that you can get a) more troops into combat and b) more favourable engagements by making sure FF specialists use their CC value (for instance).
Also, you may you may never "go through" enemy units unless you are a war engine "barging" into multiple units to engage them in CC.
/Fredmans
Follow my Epic painting projects: Tyranids vs Steel Legion and Inquisition vs Lost and the Damned @
http://www.tacticalwargames.net/taccmd/viewtopic.php?f=7&t=14636
