[Total War] Scenario Sample - Cleanse
 Post subject: [Total War] Scenario Sample - Cleanse
PostPosted: Sat Feb 28, 2009 8:16 pm
Yet another scenario from "EPIC: Total War".  Introduces a new special rule, and is quite a bit different from the standard tournament game.
It's inspired by the 40k mission "cleanse", as talked about in the EA rulebook... just made a little more challenging.
Let me know what you think!
PostPosted: Sun Mar 01, 2009 8:13 pm
Tough crowd... *LAUGH* :blues:
PostPosted: Sun Mar 01, 2009 10:08 pm
Chroma, I absolutely love the whole Epic:Total War project and all you have released yet, and see the locals using bits and parts in most future battles.
I´ll comment on "Cleanse" when I have digested it.
:agree:
Edit: Comment!
Looks very solid. I´m not sure how many formations will be left to control sectors after four turns, but keeping some intact for just this purpose might add a nice twist.
When setting up there is some choice the second player with regards to starting sector, though I assume it won´t matter much:
X11X
XXXX
2222
1- Player 1 starting sector
X- unclaimed sectors
2- potential Player 2 sectors - P2 could go sideways!
PostPosted: Mon Mar 09, 2009 3:34 pm
X11X
XXXX
2222
Well, technically, the "directly opposite" is supposed to only be:
X22X
Any other thoughts/comments?
PostPosted: Mon Mar 09, 2009 5:06 pm
Once all desired vanguards have been placed, the players take it in turn to set up their remaining formations one at a time, starting with the player with the higher strategy rating.
Help me out...  Where are the deployment sectors?  Any of them?  Just the ones on your table edge?  Is there a difference between how regular formations and vanguard formations are deployed?  The deployment section is rather vague (sorry) and could probably use some clarification for us dumb folk.
PostPosted: Mon Mar 09, 2009 5:16 pm
For starting sectors:
Gaming Area: Set up the terrain for the game in any mutually agreeable manner.  Divide the battlefield into twelve (12) equal sectors as shown below.  If one player sets up the terrain then their opponent may choose which two adjacent outer sectors they will deploy in, while their opponent will deploy in the two sectors furthest away. If terrain setup was a joint effort then the player with the higher Strategy rating may choose their starting adjacent outer sectors. If both players have the same Strategy rating then roll dice to see who gets their choice of starting outer sectors.
For the Vanguard formations:
They can then be placed in any sector that shares a side with one of the two sectors you've chosen for deployment.
So, if you pick a corner sector and one adjacent (either long or short side), you've got three sectors to potentially put Vanguard formations in.  If you pick the two "middle" sectors on the long edge, you've got *four* potential Vanguard sectors, but they're going to be quite close to the enemy.
Does that make sense?
And "vanguards" are kind of like "garrisons", except they're the "first ones there" instead of "pickets", so they've got different restrictions on what formations can be deployed.
PostPosted: Mon Jun 22, 2009 1:25 pm
Just a 'quickie'. Suppose we number the sectors :-
1,  2,  3,  4,
5,  6,  7,  8,
9,  10, 11, 12,
If 'A' chooses the two middle sectors (2 & 3), what sectors does 'B' get? If they get 9 & 12, doesn't that put player #B at a large disadvantage?
And on deploying the vanguard, what happens if both people can put their vanguard troops in the same sector?
PostPosted: Mon Jun 22, 2009 1:34 pm
'B' gets 10 & 11 in that diagram.  I'm still working on a way of showing that graphically in one map; perhaps I should add the word "adjacent" in there for the second player as well.
Well, then things are going to heat up pretty quickly!  *laugh*
There's nothing preventing the players from placing their vanguard formations in close proximity, and formations are placed in alternating sequence, so you're taking a risk putting stuff that close to the enemy.
PostPosted: Mon Jun 22, 2009 2:39 pm
Why not number the squares? Then you can say if one player chooses two of the adjacent 'corner' squares (1, 2, 5), the opponent gets the opposite two 'corner' squares (11, 12, 8). If the "middle" squares (2, 3) are chosen, the opponent gets the opposite middle squares (10, 11). Or you could just add three diagrams of the choices.
PostPosted: Mon Jun 22, 2009 2:42 pm
Played this on Friday; proved a good game. BAttle Report due soon!
R>
MoK's Painting Blog
Now Showing:
PostPosted: Mon Jun 29, 2009 2:23 pm
Played Cleanse against Netepic yesterday.
Eldar
650 Revenants
400 Aspects + Aut + EX
300 Nightwings
250 Storm Serpent
250 Storm Serpent
250 Cobra
200 Jetbikes
175 Night Spinners
150 Guardians
150 Guardians
150 6x Rangers
50  Gate
Imperial Guard
700 Leman Russ + Hydra
550 HQ Company + Hydra
350 Infantry company + support platoon
200 BaneBlade
200 BaneBlade
200 Shadow Sword
150 Rough Riders
150 Rough Riders
150 Hydra Battery
Eldar decided to choose the two central squares, and then deployed the Rangers ahead in the central squares, while the IG put the Rough Riders on either flank. The rest of the forces were deployed in the central squares.
In summary, fearing the volcano cannon, the Revenants advanced and blew away the Shadow Sword and were in turn broken by an infantry company based in a wood and an adjacent Baneblade. Having exposed the IG flank, the Eldar decided to try to clip the infantry using artillery and a guardian formation assaulting from a Storm Serpent - but the assault failed to poor positioning and worse dice rolling.
The HQ company advanced to cover the center of the table, but failed to dislodge the Rangers. A second attempt at a Guardian assault from the Gate also ended in disaster, and the IG reinforced the center with the Leman Russ company. But the tanks were funnelled by terrain into a narrow area - - - right in front of the Cobra ... Well Netepic isn't going to do that again in a hurry :( . However, the IG were slowly grinding forwards hemming the Eldar into their initial deployment area.
Conclusions
1) This is a really good scenario requiring more considered deployment than we gave it. The larger deployment zone means that even the weaker 90cm artillery can be placed in range of opponents, while there is even the possibility of 1st turn assaults if forces are placed 40 cm apart.
2) The goals are clear and the game-length is appropriate.
3) The terrain in the two central squares needs to be chosen with care as it dominates the game, allowing access to the inner edges of the outer squares. In our case there were some woods and a ruin which made the game very interesting.
4) We assumed that the Eldar Gate could be deployed along with the Vanguard, though it could be interpreted differently. Notes may need to include other items like this.
PostPosted: Mon Jun 29, 2009 10:03 pm
Quote: (Ginger @ 29 Jun. 2009, 14:23 )
Conclusions
Glad you enjoyed the scenario and thanks for trying it out!
There will be some Race-specific notes for dealing with things like this, but, for Cleanse, since there are no objectives to replace, technically, the Eldar army wouldn't be able to actually place the Wraithgate!
Sometimes the Eldar have to fight where there's no useful Webway access... it's part of the challenge!  *laugh*
Users browsing this forum: No registered users and 86 guests
