How do you represent your commissars?
 Post subject: How do you represent your commissars?
PostPosted: Mon Feb 23, 2009 8:28 pm
What's your favourite way to represent a commissar? In particular when the commissar is attached to something that's commissar model unfriendly such as a bombard or a vulture?
PostPosted: Mon Feb 23, 2009 8:30 pm
Paint it black!  *laugh*
Or, at least, a black stripe/marking.
PostPosted: Mon Feb 23, 2009 8:37 pm
I've seen several people pop commisar models on small coins or other marker and then simply place it next to/on the base of whatever it is the character is being added to.
R>
MoK's Painting Blog
Now Showing:
PostPosted: Mon Feb 23, 2009 8:45 pm
Agreed, cut a base in half, stick the Commissar in the centre of 3. Paint up.
Just put him next to the unit in the formation.
A lot easier and cheaper than having spare Guard, Leman Russ, Shadowswords, etc painted in Commissar colours.
PostPosted: Mon Feb 23, 2009 10:49 pm
I have command stands with and without commissars and a few spare tanks and vehicles with commissars included,but I also have 8 mini round stands of commissars to put on/next to vehicles when I'm at a tournament.
PostPosted: Tue Feb 24, 2009 1:00 am
All my tanks are numbered in roman numbers. And my commissars allways join the "I" marked tanks.
And for infantry, I put my commissars in the commander unit.
PostPosted: Tue Feb 24, 2009 1:08 am
Round my way we play with 1 Commissar per 500pts, so you can model your army and plan exactly how many commissars to have, that way Commissars can always be modeled on / the tank painted appropriately.
PostPosted: Tue Feb 24, 2009 1:42 am
We use a stand of 5 Commissars and purchase Commissars based on SM2 ...  And on some Command stands I have a commissar figure. If you paint the figure in ... say a Tan Coat and hat ... he's just a commander ...  :))
PostPosted: Tue Feb 24, 2009 3:20 pm
I prefer the coin method;  here's half my Commissars:
Set phasers on "fun"!
PostPosted: Tue Feb 24, 2009 4:38 pm
For infantry I made command stands both with and without Commissars included.  Commissar Leman Russ is black with Commissar in commander's hatch.  The Commissar on seperate coin attached to a particular unit works well too.
For other vechicles if you don't want to paint or model them specifically for the Commissar, it's simple enough to drill a small hole hole in the hull or turret that is just large enough for a straight pin.  Paint up an appropriate Commissariate flag attached to straight pin and mark the vehicle that way.  The flag is removable whan not occupied by a Commissar.
PostPosted: Tue Feb 24, 2009 5:27 pm
For my infantry I have extra (basic inf) stands with and without Commisars to show them attached to the unit, and I have a Leman Russ modeled up to have a Comissar sticking out of it.
I'll probably mount Commisars to coins or small washers to represent the remaining "floating" commisars however.
PostPosted: Tue Feb 24, 2009 5:34 pm
For E:A ... I think that's a good solution J9er8.  :agree:  I guess you could do the same for Chaps, Libs, etc. ...
PostPosted: Tue Feb 24, 2009 7:56 pm
I am using the 1/500 pts rule as well. Makes it easy to plan when you start assembling. So far, I have only painted commissars for my companies, which will all have one, but I plan on building small dioramas that can be placed next to artillery or other pieces.
Infantry Company Commander with Commissar:
Leeman Russ with Commissar (tank also painted in black->shadow grey rather than adeptus->stone wall grey):
Plain Guardsman with Commissar (leading the left file):
/Fredmans
Follow my Epic painting projects: Tyranids vs Steel Legion and Inquisition vs Lost and the Damned @
http://www.tacticalwargames.net/taccmd/viewtopic.php?f=7&t=14636
PostPosted: Tue Feb 24, 2009 9:02 pm
1/500 points for me too.
So Commissar models hanging out of Leman Russ etc similar to above.
Great work on those by the way Fredman :)
Users browsing this forum: No registered users and 127 guests
