Page 1 of 2 |
[ 18 posts ] | Go to page 1, 2 Next |
Possible exploitation of the Intermingled Rule? |
| Clockwerks |
| Top | |
| Markconz |
Joined: Mon Jul 28, 2003 10:43 pm Posts: 7925 Location: New Zealand |
| Top | |
| code_ronin |
| Top | |
| Tiny-Tim |
Joined: Tue Jul 05, 2005 1:32 pm Posts: 4895 Location: North Yorkshire |
| Top | |
| nealhunt |
Joined: Thu Feb 13, 2003 10:52 pm Posts: 9617 Location: Nashville, TN, USA |
Yep. You did it right and it is brutal. As Tiny Tim said, it generally only takes one time to teach this lesson. The FAQ's also state that the "intermingling distance" for scouts is 10cm, which means that a poorly placed scout formation can truly tank an entire army. Personally, I think this is a heinously bad ruling, but nonetheless for the time being it stands. The group I play with is absolutely fastidious about not being intermingled. We used to not only measure multiple times, but tell the other player explicitly that the intent was that the formations were not to be intermingled, just in case something was bumped accidentally. Now, we did it that way so long that we all take it for granted that unless it is blatantly too close, the formations are not to be intermingled. _________________ Neal |
| Markconz |
| Top | |
| code_ronin |
| Top | |
| Markconz |
| Top | |
| code_ronin |
| Top | |
| Markconz |
| Top | |
| fuseboy |
| Top | |
| phindar |
| Top | |
| nealhunt |
I don't think this is necessary. I think the real problem is that the scout intermingling distance was boosted to 10cm to "solve" a rare effect that potentially prevented CC assaults which, imho, wasn't problematic even in its most extreme theoretical application. This forces a screening formation to be too far extended to be an effective screen. They are too easy to simply engage because they are so far outside of 15cm support range. It also doesn't help that people don't tend to realize how the intermingling rules work until they get slammed. But as noted, once it happens, it rarely happens again. While there might not be nearly as many historical instances of pickets causing panic when they retreat, there are dozens of famous examples where a battle line was outflanked and routing spread down the line as the flank crumbled. If you require 15cm from all intermingled formations, it will clearly stop such things from happening. I think that would be a bad thing. _________________ Neal |
Page 1 of 2 |
Who is online |
Users browsing this forum: No registered users and 117 guests |
