Popping up
 Post subject: Popping up
PostPosted: Tue Aug 23, 2005 4:08 pm
Hello,
I would like my fellow epic players? opinions on a proposed HOUSE rule. I say house with such vigor in order to keep confusion driven back and allow each of those who do respond a chance to think about what I am suggesting for what it is. I want to take a more realistic look at the skimmer pop-up rules. Realistic? In a game that involves aliens and laser beams? Yes, because so much of the epic rules are based on real world combat, I think, at least for my peace of mind, the skimmers need some tweaking. Now, I posted this in the elder thread, and it was deleted without word to me. Although I thought this was tasteless and rude, I have licked my emotional wounds and am ready to get some feedback. If this does turn out to be the wrong area for such a post, please let me know before all 500 Death Strike Missile batteries are fired upon it, blowing it to the last millennium. This is not, I repeat, is not an experimental rule change or suggestion. It is simply something I would like to implement into my games with my friends, and need some of what I consider professional feedback. Thank you for your opinions, suggestions and time.
Skimmer Pop-up changes
Skimmer may pop-up when on over watch. A spotter on the terrain they are hiding behind is sufficient enough to allow them to fire at moving enemies.
Skimmers may NOT pop-up when taking a sustain fire order. The moving up, albeit short and not complex, is just enough to keep them from firing at both maximum effect and with complete accuracy.
15cms rule. This is how far away from terrain blocking LOS the target must be before the skimmer can see it and fire on a pop-up.
Also, Skimmers may NOT see past any terrain, even if they are right beside it, if the terrain is 15cms or wider. They are hover craft, not planes and simply cannot levitate high enough to achieve the angle necessary for targeting.
Does the latter part make sense? I could write up a couple of examples if I need to.
Thanks again.
PostPosted: Tue Aug 23, 2005 4:54 pm
If you want something more realistic, why not just draw LoS from a set height, say 15cm up?  There's certainly less abstraction that way.
PostPosted: Tue Aug 23, 2005 5:04 pm
good idea
processing :l
PostPosted: Tue Aug 23, 2005 10:40 pm
"A skimmer may pop-up to shoot -over- blocking terrain.
If the target is closer to the terrain piece than the skimmer then no LOS exists , thus the target may not be fired on.
If the skimmer is closer, or both are equidistant from the terrain piece, then there is a LOS.
Popping up in no way effects the distance that can be seen -into- a terrain piece."
This is a house rule a lot of groups seem to be using. For a full discussion see here:
http://www.specialist-games.com/forum/t ... PIC_ID=167
Users browsing this forum: No registered users and 98 guests
