Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
What PDFs for SGs website?
Painting guides/Eavy Metal 13%  13%  [ 3 ]
Battle Reports 43%  43%  [ 10 ]
Terrain 26%  26%  [ 6 ]
Background/Fluff articles 17%  17%  [ 4 ]
Total votes : 23
Squats v5.1 Khazak's Stronghold
 Post subject: Squats v5.1 Khazak's Stronghold
PostPosted: Sun Apr 04, 2004 4:48 pm
With regards to the "Old PDFs" thread I've started this poll to see what people want to be put up on the SG website.
Since Jervis hasn't provided any info on exactly what they want and reworking all Primarch's material would be a mammoth task perhaps it would just be better to rework some of the things people want to see again the most.
If you remember particular articles please provide as much info as possible (WD issue no. etc.)
Cheers!  :)
PostPosted: Thu Apr 22, 2004 2:20 pm
How close are we to getting some of these articles?
Chris
Chris
PostPosted: Fri Apr 23, 2004 10:23 am
Whoops! Sorry about not following up on this recently. -I have had some computerproblems and a bunch of other stuff on my mind lately.
Basically I got a mail from Jervis saying that if we send the WD articles in at a steady pace -something like an article every week or two -they will go up on the site accordingly.
From this poll I suggest that we start with some Battlereports.
Primarch: Is it possible to split up the WD compendiums and rework them into 72 dpi or do the bunch need to be re-scanned? Alternatively I don't mind re-making some of the pdfs from scratch (though it will probably prove a bit too much of an overwhelming task to re-do everythig! :p )
Cheers! :)
PostPosted: Tue May 04, 2004 6:18 pm
Finally had the time to loook at the PDFs.
A 13 pages battlereport weighs in at 4,5 mb if I simply cut them out of the original compilation PDFs.
Is this too big do you think?
The pro's are that it is really easy to do thus more articles can go up on the Fanatic site faster.
The con is of course the size making it a bit problematic for people with slow internet connections...
Alternatively I'll just have to re-write the text and add the pics from the original scans. This would make the files much smaller but also take a considerable ammount of time.
Any thoughts on this?
Cheers! :)
PostPosted: Tue May 04, 2004 9:03 pm
Can't you get programs that can read text from images, thus saving you rewriting all the text...?  ???
www.darkrealmminiatures.com
PostPosted: Tue May 04, 2004 9:22 pm
I think I got one with the software bundle for my scanner but I've never tried it. Guess it's worth a try. :)
Cheers! :)
PostPosted: Mon May 10, 2004 11:31 am
Yep, they are called OCR (Optical Character Recognition), IIRC.
The Fifth Horseman.
Quality over quantity.
PostPosted: Mon May 10, 2004 7:32 pm
You're right. I've tested the program but it will only read .tiff images. This means that I have to take a copy of the original image from the PDF, run it through Photoshop and convert it to Tiff, get it into the OCR program, extract the text, set up the new document in InDesign and finally save everything as a PDF again :p  It works but it is a bit more work than I expected :-:
Cheers! :)
PostPosted: Mon May 10, 2004 8:01 pm
Less than typing all the text out again tho I guess... :;):
PostPosted: Mon May 10, 2004 10:20 pm
Indeed  :;):
I've just begun work on the oldest battlereport I could find. It's SM1 Dark Angles vs. Orks the battle includes two gargants, a Warlord, two Warhounds and a Capitol Imperialis.
Should be finished in a couple of days if nothing interrupts.
Next up I was thinking of doing one of the battle reports from the release of Titan legions?!?
Cheers! :)
PostPosted: Mon May 10, 2004 11:04 pm
I'ved used OCR extensively and it translates the text and pictures to an editable format like a word file for example. This however is not a "copy" of the actual article, although the information may be the same as the format changes.
As of this moment I have ALL old rulebooks and WD articles prior to epic 40k.
I am in the process of obtaining MOST of the Citadel Journals with epic articles.
Regardless of poll result, I will commence the rescanning at a lower resolution in July.
Let me know what you guys need.
PostPosted: Wed May 26, 2004 9:01 pm
I'm afraid no progress has been made recently to this project due to quite a bit of work at school lately (Finishing off some big projects before the exams) :(
Final assignment is to be presented next week, then I have to complete the Portfolio website (Epic section will also have to wait for now) by mid June and then it is time for the exams. Then with Roskilde Festival and later hollidays it will at least be mid July before I have time to get any work done :{
Cheers!
PostPosted: Wed May 26, 2004 10:41 pm
Like I said, I will commence the project and will let you know when its completed. Hopefully Jervis will be clear on what he needs by then.
PostPosted: Thu May 27, 2004 12:34 am
Hmm, I hadn't read this thread before... are all the old epic battle reports from WD etc going to be available online? :o
That would be so cool!!!
PostPosted: Thu May 27, 2004 9:47 am
Quote (primarch @ 26 2004 May,22:41)
If Jervis doesn't then the EPICentre will most certainly host them...
Tom Webb
Users browsing this forum: No registered users and 109 guests
