Thousand Sons List
 Post subject: Thousand Sons List
PostPosted: Mon Dec 20, 2004 6:25 pm
In light of the recent semi-official inclusion of Silver Towers and the overall progression of the chaos lists and miniature lines, I have revised my Thousand Sons list.  I will be posting a new version on the Yahoo sites that host such stuff.
I wanted to know if you guys wanted me to try to post it here.  If so, is there a way to post the Word doc, or will I have to reformat it to put it in as text?
PostPosted: Mon Dec 20, 2004 6:44 pm
Quote (nealhunt @ 20 2004 Dec.,18:25)
Uhm, which progression? Last I checked, epic chaos minis won't be out until 2006 at best....
PostPosted: Mon Dec 20, 2004 7:03 pm
Hi NealHunt,
definitely interested to see it - I think you'd have to paste it as text, but higher intellects than mine could perhaps be more conclusive. :p
Back from oblivion (again)?
PostPosted: Mon Dec 20, 2004 8:14 pm
Jervis and crew's latest word on the chaos line is that there son't be a new sculpt on infantry sprues. ?That means the lists are being modified to conform to the existing sprue composition.
For example, there will not be Horror and Screamer units. ?Flamers and LoChange will be the only Tzeentch daemon units.
Also, as the budget for new sculpts is limited, more of the old figs will probably be made available and the LatD list will be adding official Silver Tower stats.
Plus, I think my new design is more in keeping with the design philosophy that Jervis has professed - only 2 new units (Rubric Terminators and Cabal Sorcerers), 2 new upgrades (Thrall Wizards and Warp Flame) and no new special rules.  I dropped some of the units as superfluous, and replaced others with rough equivalents that have been added to the lists in the past few months.
For example, rather than have a Tzeentch Sorcerer Lord upgrade, I just included a mandatory Chaos Lord and Sorcerer upgrade in each infantry formation.
PostPosted: Mon Dec 20, 2004 11:01 pm
In plain text:
THOUSAND SONS ARMY LIST
Strategy Rating
2D6+1
IMPORTANT: If you roll a double on the dice (i.e. two 1?s or two 2?s etc), then the Chaos Gods have smiled upon you and you may add one sacrifice point to any formation in the army (see summoned units below).
Initiative Rating
Thousand Sons formations have an initiative rating of 1+.
Factions
All Thousand Sons are followers of Tzeentch.
Summoned Units
As Chaos. The type of unit that can be summoned are:
Lord of Change, Flamers
Note that no more than 3 sacrifices may be used by a formation in a single turn, including Thrall Wizards used as sacrifices.
RUBRIC TERMINATORS
Type Speed Armour Close Combat Firefight
Infantry 15cm 4+ 3+ 3+
Weapons: Combi-bolters & power weapons
Weapon Range Firepower
Combi-Bolters (15cms) Small Arms
Power Weapons (base contact) Assault Weapons, macro-weapon, extra
attacks (+1)
Notes: Reinforced Armour. Thick Rear Armour. Fearless, Invulnerability Save, Teleport
THOUSAND SONS CABAL SORCERERS
Infantry 15cm 4+ 4+ 4+
Weapons: Bolters & Chainswords
Autocannon 45cm AP5+/AT6+
Psychic Powers (15cms) Small Arms, Extra Attk (+1)
OR (base contact) Assault Weapons, Extra Attk (+1)
Notes: May use Thrall Wizards.
SILVER TOWERS OF TZEENTCH
AV 15cm 4+ 4+ 3+
Weapons: Sorcerous Bolts (x3)
Tzeentch Cannons 45cm 3xAP4+/AT4+
Beam of Power 60cm MW5+
Notes: Skimmer, Invulnerable Save, Fearless
DOOMWING FIGHTER
Aircraft fighter 5+ na na
Weapons: Flamecannon (FxF)
Flamecannon 15cm AP4/+AT5+/AA5+, ignore cover, Fixed Forward Arc
Notes: Invulnerable Save
FIRELORD BOMBER
Aircraft bomber 4+ na na
Weapons: Twin Lascannon (FxF), Flamecannon, (FxF), Firestorm Bomb Rack (FxF)
Twin Lascannon 45cm AT4+/AA4+, Fixed Forward Arc
Flamecannon 15cm AT4+AT5+/AA5+, ignore cover, Fixed Forward Arc
Firestorm Bombs 15cm 2BP, ignore cover, Fixed Forward Arc
SUNS OF DAMNATION TITAN LEGION
Initiative Rating
Suns of Damnation titans have an initiative rating of 1+.
Factions
All Suns of Damnation are followers of Tzeentch.
SUNS OF DAMNATION WARLORD CLASS BATTLE TITAN
as Warlord
Weapons: 2 turbo-laser destructor (FxF) , 1 arm-mounted volcano cannon (FF), 1 arm-mounted gatling blaster (FF) .
Turbo-Las Destr 45cm 4 x AP5+/AT3+
Inferno Gun 30cm 3BP, macro-weapon, ignore cover
Volcano Cannon 90cm MW2+, Titan killer (D3)
SUNS OF DAMNATION REAVER CLASS BATTLE TITAN
as Reaver
Weapons: 1 rocket launcher (FxF), 2 arm-mounted turbo-laser destructors (FF).
SUNS OF DAMNATION WARHOUND CLASS SCOUT TITAN
as Warnound
Weapons: 1 arm-mounted Vulcan mega-bolter (FF), 1 arm-mounted plasma blastgun (FF) .
Vulcan Meg-Bolt 45cm 4 x AP3+/AT5+
7.5.2 Using The Army List
One Thousand Sons Chaos Lord character in the army must be upgraded to a Thousand Sons Warlord character. This additional upgrade does not cost any additional points.
Thousand Sons Formations
Formation Type, Units, UPGRADES ALLOWED, Points Cost
Thousand Sons Retinue
1 Chaos Space marine stand with Lord and Sorcerer upgrades and 8 Thousand Sons units
Rhinos, Dreadnought, Defiler, Dreadclaws, Chaos Land Raiders, Sacrifices, Thrall Wizards, Icon Bearer, Daemon Prince
350 points
0-1 Thousand Sons Rubric Terminators
1 Lord and 1 Sorcerer upgrade and 4-6 Rubric Terminator units
65 points each
0-1 Thousand Sons Chosen
1 Lord and 1 Sorcerer upgrade and 4-6 Chosen units
50 points + 65 per unit
0-1 Thousand Sons Disc Riders
1 Lord and 1 Sorcerer upgrade and 9 raptor units
Sacrifices
350 points
0-1 Sorcerous Cabal
1 Lord and 1 Sorcerer upgrade and 9 Cabal Sorcerer units
450 points
Thousand Sons Armour
4 to 9 Chaos Predators and/or Land Raiders
Warp Flame
50 points per Predator and 75 points per Land Raider
Silver Tower Company
4 to 9 silver Towers
None
65 per unit
Thousand Sons Upgrades
Upgrade, Units, Cost
Rhinos
Up to 5 rhinos.
10 points each
Chaos Land Raider
Up to 4 land Raiders
75 points each
Defiler
Up to three Defilers
75 points each
Dreadnought
Up to three Dreadnoughts
50 points each
Thrall Wizards
Up to two thrall wizards
Thrall Wizards can serve two purposes. They can be used as sacrifices, or they may add the following weapon to any Thousand Sons Sorcerer, including Cabal Sorcerers:
Sorcerous Power na Asslt Wpn, +1 Attk, MW
OR (15cm) Small Arms, +1 Attk, MW
Either use expends the thrall wizard. No more than 3 sacrifices may be used per turn by a single formation, including thrall wizards used as sacrifices.
50 points each
Sacrifices
Up to three Sacrifices
25 points each
Icon Bearer
One Icon Bearer Upgrade
50 points
Dreadclaws
10 points per unit in the formation
Warp Flame
Warp Flame assault weapon with the following statistics is added to each vehicle in the unit:
Warp Flame na Assault Wpn, +1 Extra Attk
+15 points per vehicle
Daemon Prince
Replace the unit in the formation that includes the Chaos Lord or Warlod character with a Daemon Prince Unit. Note that Thousand Sons Daemon Princes replacing Lords or Warlods with the Sorcerer upgrade also gain the Sorcerer upgrade.
Thousand Sons War Engines and Aircraft (1/3 points)
Suns of Damnation Warlord Titan (850 points each)
Suns of Damnation Reaver Titan (650 points each)
Suns of Damnation Warhound Titan (250 points each)
Doomwing Interceptors (150 points for three)
One to three Firelord Bombers (150 points each)
Devastation Class Cruiser (150 points)
Despoiler Class Battleship (250 points)
PostPosted: Fri May 27, 2005 2:05 pm
The list is now posted in the vault on the epic website:
http://www.specialist-games.com/epic/vault.asp
It's in .doc format, with commentary balloons in the margins based on issues I've identified.
It's very much in line with previous versions, but I'd still like feedback on the adjustments and especially on the issues where I inserted commentary.
Thanks.
Users browsing this forum: No registered users and 114 guests
