Blood Axe List |
MaksimSmelchak
Post subject: Blood Axe List Posted: Mon Jun 09, 2003 6:29 am |
| Brood Brother |
Joined: Sun Feb 16, 2003 4:43 pm Posts: 7258 Location: Sacramento, California, USA
Anyone have ideas how to convert the following FW SM vehicles or which proxies are ideal to use for Epic:
- Damocles Command Rhino A Rhino with command antennas, satellite uplink, etc.
- HELIOS LAND RAIDER A special Landraider with a missile launcher on top of the hull.
- LAND RAIDER - CRUSADER A special Landraider that trades out its side lasers for x6 heavy bolters, adds gatling cannons up top, and has fragmentation charges on the hull.
- LAND RAIDER PROMETHEUS COMMAND TANK A special Landraider with command capability.
- LAND SPEEDER TEMPEST A Landspeeder with a one-man armoured cockpit, larger wings, missiles, and a souped-up engine.
- Whirlwind Hyperios A SAM Rhino for the SMs.
- How about the following FW IG vehicles:
- ATLAS RECOVERY TANK It looks like a Leman Russ chassis with an A-frame towing jig and other recovery equipment.
- Chimera (Gryphonne IV pattern) with autocannon turret A Chimera with an autocannon turret.
- CYCLOPS DEMOLITION VEHICLE It looks similar to the German WWII remote control demolition tank. It's essentially a tankette packed with explosives.
- Imperial Valkyrie Airborne Assault Carrier Air cav for the IG.
- Imperial Vulture Gunship A gunship to cover the air cav.
- SENTINEL POWERLIFTER A sentinel with two load carrying claws / cargo arms. Anyone have recall from "Aliens 2?"
- TARANTULA SENTRY GUN WITH HEAVY BOLTERS A Tarantula variant with twin linked heavy bolters instead of the standard twin linked heavy lasers.
- TARANTULA SENTRY GUN WITH LASCANNONS A Tarantula variant with the standard twin linked heavy lasers.
How about the following E-A SM units:
- HUNTER (use a Whirlwind to represent Hunters for the moment) Another SM SAM Rhino. How does this compare to the Whirlwind Hyperios?
- LAND SPEEDER - Standard (No models yet, use whatever you have to hand!) It's the same as the Epic-40k metal Landspeeder except without the heavy support weapon mounted under the chassis.
- LAND SPEEDER TYPHOON (No models yet, use whatever you have to hand!) It's a standard Landspeeder with two AP missile launchers mounted on either side of the rear fuselage.
- SPACE MARINE COMMANDER
Forgeworld link: http://www.forgeworld.co.uk/
Shalom, Maksim-Smelchak.
| Top |
Legion 4
Post subject: Blood Axe List Posted: Mon Jun 09, 2003 6:41 am |
| Brood Brother |
Joined: Thu Feb 13, 2003 5:13 pm Posts: 37005 Location: Ohio - USA
| Top |
Chris
Post subject: Blood Axe List Posted: Mon Jun 09, 2003 7:51 am |
| Brood Brother |
Yep, I did the same with a Helios, I plan to do a couple more.
For Hunters/Hyperios, just use a standard Whirlwind, but paint the launcher a different colour than the rest of your Whirlwinds.
Rhino Command Tank - Standard Rhino with a few BFG ariels stuck on the top?
Just a few ideas...
Cheers, Chris.
_________________ Chris
| Top |
chubbybob
Post subject: Blood Axe List Posted: Mon Jun 09, 2003 9:35 am |
| Brood Brother |
| Quote (Chris @ 09 2003 June,07:51) | For Hunters/Hyperios, just use a standard Whirlwind, but paint the launcher a different colour to the rest of you Whirlwinds.
Rhino Command Tank - Standard Rhino with a few BFG ariels stuck on the top? |
Hi,
Rhino AA vehicle: I did an AA version of a rhino a couple of years back. I used a plastic rhino and added the launcher from a H&R Russian SAM-8 Gecko launcher (I think). This is the result:
http://www.angelfire.com/games4/chubbyb ... aatnk4.jpg
Rhino Command vehicle: The Rhino command vehicle you can do following modern practice . I added to the structure of an existing vehicle:
http://www.angelfire.com/games4/chubbyb ... cctrk1.jpg
This one is actually the hull of a plastic Orc battle wagon that I used as the hull for a series of recce vehicles.
Cigar Challenge: The commander's cigar was a challenge i.e. bet from a friend!
Bet you can't put a cigar in his mouth... heheheh!
Bob DeAngelis
| Top |
stormseer
Post subject: Blood Axe List Posted: Mon Jun 09, 2003 10:40 am |
| Brood Brother |
Joined: Fri Feb 14, 2003 9:52 pm Posts: 4598 Location: Suffolk, UK.
Like the AA variant, Bob, and the cigar... ?
Hehe, great stuff!!
To make the Damocles, I'd make the uplink dish from a bit of thin plasticard, and maybe add some whip ariels made from thin wire or something similar....
_________________ www.darkrealmminiatures.com
| Top |
Legion 4
Post subject: Blood Axe List Posted: Mon Jun 09, 2003 4:24 pm |
| Brood Brother |
Great Stuff, Bob!!!
A command vehicle (like a US M577, check the GHQ site, is nothing more than a "tall" M113. I've commanded from both.)
It can just have a built-up superstructure and more antennas. Or even a small "dish" for Satcom. Again... easy ? ?
We use the SM-1 Mk1 Whirlwind as FA and the SM2/E40K Mk2/3(pl) as AAA. Too easy... ?
_________________ Legion 4 "Cry Havoc, and let slip the Dogs of War !" ... "People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
| Top |
nealhunt
Post subject: Blood Axe List Posted: Mon Jun 09, 2003 7:20 pm |
| Purestrain |
Joined: Thu Feb 13, 2003 10:52 pm Posts: 9617 Location: Nashville, TN, USA
Hunter: ?I use a mix of the old and new Whirlwinds. The odd-man-out is the Hunter.
Landspeeder Typhoon: I was just thinking about this, but haven't gotten to the point of pulling out the figures to check sizes... ?
Would the old Whirlwind missile launcher boxes fit on a Landspeeder figure?
_________________ Neal
| Top |
stormseer
Post subject: Blood Axe List Posted: Mon Jun 09, 2003 7:39 pm |
| Brood Brother |
For the Landspeeder Typhoon I think you could quite easily make the missile boxes from a little piece of sprue or plastic rod cut to shape, as I think the old Whirlwind missile box would be a little too big I think....
| Top |
Legion 4
Post subject: Blood Axe List Posted: Tue Jun 10, 2003 5:26 am |
| Brood Brother |
Yes,
The SM1 Whirlwind launchers are too big.
Maybe E40K Thunderbolt missiles, suitably modified?
| Top |
MaksimSmelchak
Post subject: Blood Axe List Posted: Tue Jun 17, 2003 5:10 pm |
| Brood Brother |
I'm updating my latest ideas:
- Damocles Command Rhino A Rhino with command antennas, satellite uplink, etc. - This shouldn't be too hard since all I have to do is to add comms equipment until I get a "command" version.
- HELIOS LAND RAIDER A special Landraider with a missile launcher on top of the hull. - Most people have suggested using Whirlwind missiles, but I want something that better approximates the squarish missile box on the HELIOS.
- LAND RAIDER - CRUSADER A special Landraider that trades out its side lasers for x6 heavy bolters, adds gatling cannons up top, and has fragmentation charges on the hull. - I have had two ideas how to do this: - 1. Cut up three Leman Russ Bolter sponsons to approximate the heavy bolters and don't worry about the gatling cannons.. - 2. Use BFG Imperial weapons turrets to approximate the heavy bolters and the assault gun off of a Landspeeder.
- LAND RAIDER PROMETHEUS COMMAND TANK A special Landraider with command capability. - This shouldn't be too hard since all I have to do is to add comms equipment until I get a "command" version.l Landraider with command capability.
- LAND SPEEDER TEMPEST A Landspeeder with a one-man armoured cockpit, larger wings, missiles, and a souped-up engine. - I'm thinking that Brigade's SF300-506 Giap Grav scout vehicle makes an excellent Landspeeder Tempest. http://www.brigademodels.co.uk/NoFrames ... 0-506.html
- Whirlwind Hyperios A SAM Rhino for the SMs. - I'm looking at adding a small missile launcher to the Rhino frame. I don't want to use regular Rhino - Whirlwinds.
- ATLAS RECOVERY TANK It looks like a Leman Russ chassis with an A-frame towing jig and other recovery equipment. - I'll add an A-frame towing jig and a crane to an ATLAS frame.
- Chimera (Gryphonne IV pattern) with autocannon turret A Chimera with an autocannon turret. - I think that if I add a Mk.I metal Leman Russ turret that it would do the job!
- CYCLOPS DEMOLITION VEHICLE It looks similar to the German WWII remote control demolition tank. It's essentially a tankette packed with explosives. - NAVWAR - WWII German Vehicles - NT147 GOLIATH DEMOLITION VEHICLE - x 3 - 30p http://www.navwar.freeserve.co.uk/ - Irregular also has a WWII German Goliath version, but the casting is very poor.
- Imperial Valkyrie Airborne Assault Carrier Air cav for the IG. - I'll use the CAV Fenri for this.
- Imperial Vulture Gunship A gunship to cover the air cav. - I have no idea how to do this. It's looking like it'll take a lot of conversion!
- SENTINEL POWERLIFTER A sentinel with two load carrying claws / cargo arms. Anyone have recall from "Aliens 2?" - I still don't have any good ideas how to do this.
- TARANTULA SENTRY GUN WITH HEAVY BOLTERS A Tarantula variant with twin linked heavy bolters instead of the standard twin linked heavy lasers. - I have no idea.
- TARANTULA SENTRY GUN WITH LASCANNONS A Tarantula variant with the standard twin linked heavy lasers. - I'm going to use the old lead versions or the Brigade piece for this.
- HUNTER (use a Whirlwind to represent Hunters for the moment) Another SM SAM Rhino. How does this compare to the Whirlwind Hyperios? - This vehicle and the Whirlwind - HYPERIOS are the same thing in my book. - I'm looking at adding a small missile launcher to the Rhino frame. I don't want to use regular Rhino - Whirlwinds.
- LAND SPEEDER - Standard (No models yet, use whatever you have to hand!) It's the same as the Epic-40k metal Landspeeder except without the heavy support weapon mounted under the chassis. - I'll just cut off the gatling cannon mounted underneath the Land Speeder. I can use that gatling cannon for my Crusaders.
- LAND SPEEDER TYPHOON (No models yet, use whatever you have to hand!) It's a standard Landspeeder with two AP missile launchers mounted on either side of the rear fuselage. - I think that I'll have to make the missile launchers out of plasticard.
- SPACE MARINE COMMANDER - I'm going to mount special characters on pennies and build them a little mount to stand on. Painting regular plastic figures differently should be enough to distinguish them. - I'll use some proxy infantry where I can.
| Top |
centurion
Post subject: Blood Axe List Posted: Tue Jun 17, 2003 6:34 pm |
| Brood Brother |
Joined: Tue Feb 18, 2003 10:44 pm Posts: 729 Location: San Antonio, Texas
Well, I'm not an expert at converting, but I did the following: Crusader: I used four BFG chaos turrets to represent the side sponsons, two assault guns from the plastic IG sentinel and a melta-gun from the squat trike mounted on the turret. Land Speeder Typhoon: Cut a missile launcher from the Whirlwind in half and mount it on the sides of the Land Speeder.
Land Raider Prometheus: Use two bolter sprues from the Thunderhawk, cut in half and mount them one on top of the other and use the turret from the Whirlwind "sans" missiles as a command turret.
Well, that's about it.
I have photos, but no way of posting them. Any suggestions would be helpful.
| Top |
MaksimSmelchak
Post subject: Blood Axe List Posted: Tue Jun 17, 2003 7:28 pm |
| Brood Brother |
Centurion,
Crusader: I used four BFG chaos turrets to represent the side sponsons, two assault guns from the plastic IG sentinel and a melta-gun from the squat trike mounted on the turret. |
Land Raider - Crusader: I'm thinking along the same lines of using BFG turrets for the sponsons. I'm thinking that if I cut off the lascannons off the plastic Land Raider turret then I can easily move in the BFG turrets.
I really like the idea about the Sentinel guns and the melta-gun from the Squat trike.
Land Speeder Typhoon: Cut a missile launcher from the Whirlwind in half and mount it on the sides of the Land Speeder. |
Land Speeder - Typhoon: Do you mean the original boxy Whirlwind turret or the more recent one with missile tubes?
Land Raider Promethues: Use two bolter sprues from the Thunderhawk, cut in half and mount them one on top of the other and use the turret from the Whirlwind "sans" missiles as a command turret.
Land Raider - Promethius: I don't have the Imperial update. What does the command turret look like?
It's good to see you at the forum. I was wondering if you were going to show up here.
I still remember your Epic Golden Demon Sanguinius entry. It's an awesome conversion using Exarch wings on a SM body.
Shalom,
Maksim.
