Phase III E-A Tyranid Army List...
 Post subject: Phase III E-A Tyranid Army List...
PostPosted: Tue Aug 05, 2003 8:24 pm
- So, what are you guys using for Marine Scout Snipers? ?
I tried taking the heavy weapons guys and removing the missile launder magazine, along with a little filing.
They look okay, but not as good as I had hoped.
- Should I revert to the old plan whereby IG troopers were fielded as SM scouts?
- Also, what do you think about using the old IG bikes for scout bikes?
In case you are wondering, my home-grown chapter is intended to be scout-heavy, so I'm looking for ideas.
PostPosted: Wed Aug 06, 2003 4:16 am
This may not be any help, but I'm waiting to see what (or if) G/W produces (any).
I'm not big on converting 6mm Infantry ...
I can barely see as it is!
PostPosted: Wed Aug 06, 2003 4:37 pm
Neal,
So far I have been using my Ratlings for any snipers I've needed and I haven't used SM and IG snipers together so only one type has been used.
Here are some ideas:
- Use GZG NAC proxies. There's a guy with a cloak that has a remarkable resemblance to the 28mm GW SM sniper. Add in a C&C Machine gun if you want a longer sniper-looking weapon. Alternately you could use a little plasticard or plastic stock to approximate the rifle.
- Base your snipers specially on pennies or other distinctive bases.
- Use the second edition Eldar Guardians (the one with the long laser rifle) and do a head swap.
- Use the Eldar ranger model and do a head swap.
- Take any SM models (including the basic trooper) and add in a C&C Machine gun if you want a longer sniper-looking weapon or alternately you could use a little plasticard or plastic stock to approximate the rifle.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Wed Aug 06, 2003 7:56 pm
One thought that crosses my mind is why do you need a model at all?
Now before you think me crazy follow me for a moment first.
What if you took a small piece of plastic about 3/4th the size of a man as your start? Mount a suitable looking barrel on one end. Maybe even use small wire to make bipod etc. Now mount this ?sniper? onto a penny with some texture on it. Cut a small section off of a used dryer sheet. Use white glue to ?mold? the sheet over our ?blob sniper? into a shape you like. Maybe even simulate the head with a small raise in the correct spot etc. Add some further texture on your new found ?camo netting?. Leave the barrel sticking out of the netting of course. Paint it with camo colors, but make them slightly different so you can see the ?figure? slightly without having a full figure there. Put two or three on a penny and Scout Snipers you will have. Make variations using legs from broken models or small roundish beads of plastic for heads sticking out. Etc.
Not the best, but with some paint might look good.
dafrca
              - Cities of Death, page 59
PostPosted: Wed Aug 06, 2003 8:38 pm
I'll have to admit, dafrca, that is a very cool idea ! ?Those are good ideas too, Maksim, especially the GZG ESU Naval Infantryman with the cape, just like the old USSR Naval Infantry use to wear. ?Good thinking guys ! ?:;):
PostPosted: Thu Aug 07, 2003 6:44 pm
I think an IG guardsman would be a great model to work from, using your suggestion, dafrca.
Cut off the gun and trim down the base, leaving a roughly accurate pose.  Cut and cock the leg.  Put the "gilly suit" over him and attach the gun so it sticks out.
PostPosted: Fri Aug 08, 2003 1:12 pm
Yeah, great ideas Dafrca and Neal, I think I'll try something along those lines for my IG when I come to do them....
www.darkrealmminiatures.com
PostPosted: Mon Sep 01, 2003 8:06 pm
I was thinking about Snipers this last weekend at CONQUEST. The IG force could have really used some!
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Thu Apr 15, 2004 12:46 pm
This thread has been archived.
PostPosted: Fri Apr 29, 2005 12:02 am
With Maksim doing an excellent job on the Tyranid list in the Vault (I recommend everyone give it a read through and leave their comments on it), it has stirred my enthusiasm for the bugs. But, since last edition I have been much more interested in the idea of a seeding swarm.
So, while I dont want to second-guess the progress on the main list, I wondered what the general opinion is on a Phase III Tyranid force.
I dont want to go into stats and detail like that, since I will simply follow the main force list in stats, but what differences would there be between the lists?
Not Included
As a Phase III list, I would guess that the force would be primarily smaller, infantry units. Very few, and possibly no titans, with very limited vehicles (or even probably none).
Would an Attack force have Spore Chimneys? I dont know much about the background of these, but would they be present in the initial stages of a Tyranid invasion?
Additions
I guess that there would be a load of Gaunts, Genestealers and Lictors, with similar numbers of all of the infantry, and in particular Tyranid Warriors.
Anything else that would be definately in or not in the force? Anything that there would be lots of, or few of? Any special rules to be included in the force?
Thanks.
PostPosted: Fri May 06, 2005 9:03 pm
Hi CS,
Sounds interesting. I think that we're all a little slow lately (myself included).
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Fri May 06, 2005 10:23 pm
Thanks. I think that I will wait for the new 40K Tyranid Codex (in a month or so), then I will get back on this. To be honest, it is an excuse to use all manner of exotic bugs from as many different manufacturers as possible (I could use a list of alternatives out there, if anyone has suggestions). I guess that there will be less armour, no war engines and lots of a huge variety of infantry. Epic - its all about the grunts!  :D
PostPosted: Sat May 07, 2005 2:05 am
Hi Iain,
You might want to check out some of the various E-A Nid threads that I have listed that have many different types of Nid proxies listed.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
