Post new topic Reply to topic  [ 128 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
First try of Eldar
 Post subject: First try of Eldar
PostPosted: Thu Sep 09, 2004 11:12 am
Location: University of Essex, Colchester, UK (soon to be Brighton, Sussex, UK)
Agreed and agreed. Simplicity is ok as long as it is ok for the gaming experience but in case it does not model well what should be happening with a minimum of common sense yoi might consider increasing the overall length of the battle by 15-20 minutes (in a 4 hour battle that is not much) and get a much more comprehensive result with minimal chages. I would go for that.
Still, if we do NOT apply any house rules, it seems that adding leman russes or other stuff like that to an infantry company is poo. For an infantry (not mechanized) company, stuff like demolishers *might* be good since they add to ther firepower of the squad, specially in firefights when you want to conquer an enemy entrenched position, but not as the stop-gap option to get a shot at tanks that treaten your formation, that it would be my idea of why to take them :l So the rules are quite weird here.
And yup, do whatever works for you. As long as you have fun it is good! :cool:
Xavi
Commanding legions forward while sitting in a nice armchair.
PostPosted: Thu Sep 09, 2004 11:56 am
L4's school of thought can never be questioned. We also use a bunch of house rules to suit our tastes.
I prefer to only allow SOME formations to act independantly. After all the IG is traditionally not a very flexible force. Leave that to armies like Space Marines and Eldar. Even though ity may not allways be common sense it is sometimes nesescary in order to differentiate armies and give them unique characteristics. One of the main problems in E40k was IMO that you had no real sense of command structure for each army. You could have IG or Ork formations of only a few tanks and Eldar hosts bigger than an IG company!
Though it may make the IG less effective I prefer to have huge formations grinding the enemy down rather than many smalll flexible "realistic" formations. It just feels a bit more fluffy IMO.
But like I said: do what suits your tastes. :)
Cheers!:)
PostPosted: Thu Sep 09, 2004 3:55 pm
Quote (Mojarn Piett @ 09 2004 Sep.,00:46)
To each his own I guess. But I don't think it would slow the game down, at least by much.
Xavi suggested allowing each "squad" in a formation to select and fire at it's own target. So let's see, that means I could have ten different targets with ten different combat resolution calculations to do for just my first tank formation?
I can not see how anyone could argue this would not slow the game down. Should we allow this, the number of each seperate calculations per activation would grow quite large, and slow for very little aded "realism". The very game mechanic we are using is based on massed fire is effective fire.
Of course if that is what you think of as fun, well then have at it.  :;):
dafrca
              - Cities of Death, page 59
PostPosted: Thu Sep 09, 2004 4:01 pm
Well ... my work is done here ... :;):  Thanks Boyz ! :D
PostPosted: Thu Sep 09, 2004 4:02 pm
Nope, I suggest each PLATOON (6 infantry bases, or 3 tanks) to shot at different target. That is 2 formations for an basic infantry company, 3 for a tank company. If you rake a tank platoon in the infantry company, then it would be an other one as well (can select an other target).
So not as many as you say :)
Regards,
Xavi
PostPosted: Thu Sep 09, 2004 4:28 pm
The way we do it is that formations are only integrated during transport. Using SM1 TO&Es generally with some modifications as required.  Examples: IG Tac Det is 9 Stands, when activated, they would move, fire etc.  A L/Russ det. is 3-5 tanks, when activated they would do the same.  No unit would consist of both vehicles and infantry etc., save for during transport and a few exceptions like a Commissar Stand with Rhino.  The rule we made for special troops (as in SM2) like Chaplins, Libs, Medics, etc., that they can be attached to standard units. Like a Medic stand and his Rhino may be attached to an SM Tac Det of 8 Stands and in this case they would activate as one unit.  Of course there is a lot more units to activate, generally. :D
PostPosted: Thu Sep 09, 2004 5:45 pm
Quote (Xavi @ 09 2004 Sep.,08:02)
Regards,
Xavi
Xavi,
So when you wrote:
Well, I was proposing even more flexibility than that, with each squadron acting on their own like an independent formation...
You ment Platoon. OK so it is a lower number, but it still will slow the game down. My two tank companies go from two activations with two combat resolutions to two activations with eight combat resolutions (three platoons plus command tank each).
To be clear, I am not saying your idea is "bad" but what I am saying is let's not think it will not slow down the game, it will. Why am I so sure, because we play tested split fire in many different forms durring the playtest of the original rules. I was one on the side for allowing split fire.
We tried split by type (All At to one target and all AP to another. We tried allowing each unit to fire, we tried troops and trasports, we tried only Super Heavies and Titans, we tried lots of different combos. Each had some good points and some bad, but all of them added to the time needed to finish an activation, thus the normal game took longer. The one formation/one target took the least amount of time.
But please play as you see fit.
dafrca
PostPosted: Thu Sep 09, 2004 5:57 pm
Usual problems with terminology, heh. A squadron in the spanish army (the one I based my model on) is a platoon in the US army.
I was thinking more along the lines of assigning the HQ as an "upgrade" to one of the platoons. That would mean that a tank company would be 3 groups, not 4: 3, 3 and 4 tanks. An infantry company would be 2 (infantry platoons, one of them containing the HQ) or 4, depending if you turned the transports into independent units or not after the dudes dismouted.
And yes, of course it would slow the game down. It would also be more realistic IMO and I would be glad to pay the price for slower game but with better "reasoning". But well, that's me. We are already beating a dead cow here :)
Regards,
Xavi
PostPosted: Fri Apr 22, 2005 4:22 pm
Scratchbuild a full 2-4K E:A army!
No buy cheap models crazy stuff, just hardcore plastic, clay, putties, and assorted random junk! Lower than low costs, mediocre model quality, but still looking like an army.
I thought both orks and LatD qualify for such a project, my preference being LatD.
So, now here's my questions for you:
-What army should I take?
-How should I do it? Building ideas are all welcomed.
-Any ideas for a start? I wanna start with 2K, does anyone have any ideas for a 2K ork/LatD list?
Frecus
The glade wanderer
Madwarrior
I declare extra- Er... Extri- No... Erm... Ah whatever, just nuke the planet! - Inquisitor anderwell, after retreating from Siza V, wounded.
Check my comoc @ http://www.comicofmana.tk
PostPosted: Fri Apr 22, 2005 4:38 pm
Hmmm, are you really sure you want to do this, afterall most of the basic plastics are really cheap on e-bay, provided you're careful :D possible cheaper than the clays/putties etc,
However it would be interesting to see how you get on, I'll see if I can think of any helpful hints.
LotD would be my choice :D
PostPosted: Fri Apr 22, 2005 6:20 pm
Hi Frecus.
That sounds like quite a task.
I'd recommend that you go for a vehicle heavy army. Modelling 5 miniatures to a base is going to be a lot of work.
Another reccomendation would be to go for an army with high points cost so you don't have to build as many models.
You could build a Necron army perhaps?
Cheers!  :)
PostPosted: Fri Apr 22, 2005 10:04 pm
I agree, its crazy and wierder than the primarchload..... :;):
PostPosted: Sat Apr 23, 2005 6:45 pm
Quote (Warmaster Nice @ 22 2005 April,18:20)
Hmmm... I agree with those, but necrons are themselves hard to build...
I also thought of speed freeks, who can get all buggiez & wagonz. I made a little list for that option, containing 32 buggiez, 3 speedstas, 7 gunwagonz, 1 scorcha & 1 badboyz, 12 deathkoptas, 12 gunwagonz, 5 fighta bommerz.
I could take more gunwagonz & less buggiez...
Frecus
The glade wanderer
Madwarrior
PostPosted: Mon Apr 25, 2005 9:11 pm
I got a new speed freek idea!
I got an idea for a unit of massive monowheels with guns attached to the axis to represent 9 buggies. I also reduced a lot of building time by taking a total of 8 gunfortresses. So what do you think of this list:
Da mastas blitz brigade, 8 gunwagonz, mekboy speedsta, bad ork smallwheelz (bike boyz), 2 flakwagonz...370
Blitz brigade, 4 gunwagonz, mekboy speedsta, flak wagon, gunfortress...370
Kult of speed, 8 deth wheelz (buggies), speedsta, extra deth wheel (buggy)...275
Blitz koptas, 4 deth koptas...150
Huge gunfortress mob, 6 gun fortresses, extra gun fortress...835
Total: 2K
Models: 40
Frecus
The glade wanderer
Madwarrior
PostPosted: Tue Apr 26, 2005 9:02 am
40 scratch-built models, wow, this one I have got to see :D
