Post new topic Reply to topic  [ 102 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
Necron list up in the vault.
 Post subject: Necron list up in the vault.
PostPosted: Thu Feb 26, 2004 8:55 am
Warmaster skeletons, with a bit of conversion, would I feel yield passable wraiths, at least from my memory of the size of the models. Make it so they're on one leg and then add some long scythey things to the arms.
PostPosted: Thu Feb 26, 2004 1:00 pm
Quote (Hergrmir @ 26 2004 Feb.,08:55)
A good idea.  :D
Back from oblivion (again)?
PostPosted: Thu Feb 26, 2004 4:38 pm
I have that M/M Borg Cube ... we use it as a terrain bit.  Plus I do have 8 or so stands of Chaos Androids (can you say T2 ! :;): ) ... interesting concepts, Furgie ! ???
PostPosted: Thu Feb 26, 2004 4:55 pm
Quote (furgie @ 25 2004 Feb.,22:21)
Not being a 40k player (nor much of an epic one either), I was in GW (The Plaza) lunch time and laid my eyes on the Necron 40k models for the first time! I was blown away by them, and almost picked up Codex Necron just for the read.
I highly recommend the Necron Codex just for the background. IMO it has some of the best background of any WH40K codex (along side with the demon hunter codex, these 2 are by far my favorites in terms of background). The art work also seems alot better in the last few codexs.
PostPosted: Thu Feb 26, 2004 5:21 pm
Maybe FW will do a Necron army for Epic since the initial release for them is still a few years away.  Maybe even some  Dark Eldar.
Adrian
PostPosted: Thu Feb 26, 2004 5:29 pm
We could only hope! :;): ?
They did a great job with the Tau! :D
PostPosted: Thu Feb 26, 2004 10:03 pm
Quote (vanvlak @ 26 2004 Feb.,12:00)
A good idea. ?:D
Validation! Huzzah!   :laugh:
Someone else recommended using Eldar antigrav platforms with the weapn removed and a suitable upper torso placed on top for destroyers, but I think everyone's pretty much got those covered.
For the pylon, use one of the hull crescents from the smaller Necron escorts (Dirge I believe?) and prop it on it's side, make some kind of stand and add in a crystal in the hollow of the crescent maybe? Main reason I'm putting out ideas is because I myself will never get around to them.
PostPosted: Thu Feb 26, 2004 10:41 pm
I really hope FW does a necron line, its sure better than waiting until 200x to get it from fanatic.....
PostPosted: Fri Feb 27, 2004 12:27 am
For a pylon I've been playing with half a key-ring, mounted on a two-pence piece (for the moment) and I nicked some stick on jewels from my daughter's Barbie nail set...
Not quite FW standard, but with a lick of paint....
Furgie
PostPosted: Fri Feb 27, 2004 1:18 am
Quote (furgie @ 26 2004 Feb.,23:27)
You know you're impatient when...  :p
Actually, it seems like a workable idea, for the moment. Certainly cheaper than buying Necron escorts too.
PostPosted: Sat Feb 28, 2004 9:28 am
Quick question on points cost. (Bit of a newbie one this...)
When adding a Tomb Lord Character to Warriors, the cost is 20 plus 25 for a single stand?
Or just 25?
Little confused.
Furgie
PostPosted: Sat Feb 28, 2004 9:45 am
Well it says +25 in the army list, so my guess would be it is in addtion to the 20 points for a warrior.
