Post new topic Reply to topic  [ 1449 posts ]  Go to page Previous  1 ... 55, 56, 57, 58, 59, 60, 61 ... 97  Next
Armyforge Update (Online EA Force Creator)
 Post subject: Re: Armyforge Update (Online EA Force Creator)
PostPosted: Fri Feb 27, 2015 8:34 pm
Hey, I wanted them +1 sniper FREE but you all threw tomatoes at me and voted on this ;)
Thanks for the quick updates!
PostPosted: Sat Feb 28, 2015 3:27 pm
Hey guys!
There is an error in the gargant list. The upgrades are costed at 0 points but should cost 25 points each.
PostPosted: Sat Feb 28, 2015 4:58 pm
Slight updates for AMTL:
Recon Cohort has been removed and replaced with the Crusader Scout Maniple for 150 points.
I don't think this is tracked, but just in case, the Plasma Destructor is now carapace only.
-Vaaish
PostPosted: Sat Feb 28, 2015 5:01 pm
It could be, can limit to one per reaver and two per warlord?
PostPosted: Sat Feb 28, 2015 7:02 pm
NetEA Death Guard 0.2, Plaguehound Titan should be Fester Titan.
The Wargaming Trader
PostPosted: Sat Feb 28, 2015 10:17 pm
@Vaaish - all changes done, also limited the PD to one per reaver and two per warlord (list not fussy about carapace/arm etc)
@IJW Wartrader - fixed, keep em coming
@Mordoten - I've added the option of selecting the weapons for the supa stompa (ie. 3x soopagun or 2x soopagun and 1x mega choppa)
@Jimmy - I've updated the marines as requested however there was no way to elegantly implement the typhoon speeder upgrade, as you suggested I have altered it to 10 points each and added a note, I suggest lobbying the ERC to make this the standard in the list, it makes no odds in terms of balance and makes bookkeeping easier ;)
please keep the updates coming :)
PostPosted: Sat Feb 28, 2015 11:24 pm
@kyuss: Sorry was out most of the day, but that works quite well. :) Could we also add this limit to the Support Missile? Also noticed that it says the list is 3.23 under dev. The list should be 3.24 Approved.
Thanks!
-Vaaish
PostPosted: Sun Mar 01, 2015 12:36 am
Will sort it, I already upversioned it to 3.24 *APPROVED* too
Quick question, is the support missile carapace only as well? I'll have to code differently if so
PostPosted: Sun Mar 01, 2015 12:52 am
Yeah, both the Support Missile and Plasma Destructor are carapace only. Technically, so is the Carapace Landing Pad but it's not explicitly limited to carapace only and there's not much reason to worry about folks taking more than one or combining a PD or Support Missile with one.
-Vaaish
PostPosted: Sun Mar 01, 2015 3:13 am
server updatorized
An online epic force creator:
Armyforge
PostPosted: Sun Mar 01, 2015 9:09 am
Awesome!
PostPosted: Sun Mar 01, 2015 7:01 pm
Adam, can you update again? I fixed the AMTL list so support missiles and plasma destructors share upgrade slots
PostPosted: Tue Mar 03, 2015 12:05 pm
The Gargant Big Mob kustom upgrades are still costed at 0 points, instead of the correct 25.
PostPosted: Tue Mar 03, 2015 12:39 pm
right you are, fixed, will appear next time Adam refreshes the server
PostPosted: Wed Mar 11, 2015 4:04 pm
For Squats there is the 1.5 Version of Thurgrimm.
http://www.taccmd.tacticalwargames.net/ ... 34&t=26499
Please update this. Thank you!
