Post new topic Reply to topic  [ 125 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9  Next
E:A in US W/D 29er2 !!!
 Post subject: E:A in US W/D 29er2 !!!
PostPosted: Wed Jul 20, 2005 2:42 pm
A large battle - a main effort if you like - does attract the commitment of specialised resources to make sure it works.  That includes AA, Arty, CAS, Combat engineers, etc etc.  This has been true from ancient times (-4k), why wouldnt it be so in 40k?
That's all fine and dandy in the real world.  I agree whole-heartedly that is how it works.  The problem is that this is a game, restricted by game mechanics, which in this case don't deal particularly well with air cover.
This is basically much the same problem as with the all-WE lists (AMTL and OGBM).  The rules for those kinds of units are auxiliary to the primary mechanics and significant deviations from the original design assumptions are likely to cause balance problems that simply can't be resolved.
A few WEs or modest air support does not cause problems because an army can divert a relatively modest amount of resources to anti- tactics.  Mass-WE and significant air cover requires a radically different army composition in order to remain competitive.  That is a bad thing for the balance (and variety) of a tournament environment.
PostPosted: Wed Jul 20, 2005 3:25 pm
Hmmm ... you may see a problem (power players, poor rules for army composition, etc.) others don't, Neal ?   Should there be new limits on certain unit types ... or what ?  Any suggestions, without "reinventing the wheel" ?  Limiting certain units (ie. 0-2 ?), like in the past, would that work ?   Revise point values, etc. ?   ???
PostPosted: Wed Jul 20, 2005 3:31 pm
Quote (nealhunt @ 20 2005 July,14:42)
A few WEs or modest air support does not cause problems because an army can divert a relatively modest amount of resources to anti- tactics. ?Mass-WE and significant air cover requires a radically different army composition in order to remain competitive. ?That is a bad thing for the balance (and variety) of a tournament environment.
Is it?
I can see that with the lists being published piece meal as they are its a problem, but once we have a greater diversity of lists then things will change.
My main thought is with Bugs. They will force everybody to change their ideas.
It should be noted that at Call 2 Arms there was very little in the way of artillery. This in my eyes was a huge benefit for my Speed Freak horde and a contributing reason for them doing so well.
Tiny
PostPosted: Wed Jul 20, 2005 3:34 pm
opps didn't really finish my point.
If there are a large number of different lists and type of lists then it will not be possible to design your army to take on all comers and force players to improve their play and not just their army composition.
Tim
PostPosted: Wed Jul 20, 2005 5:17 pm
Air ironically faces another problem. 'Reasonable aircraft' (ones with range 45cm and below) become less effective at 4 and 5 k games. Here there is so much flak (every leman russ company/mech formation brings a hydra etc) that they find opperating on the battlefield suicide.
PostPosted: Wed Jul 20, 2005 5:34 pm
Quote (Legion 4 @ 20 2005 July,15:25)
Besides the massed-WE balance problem parallel, this could also be seen as a parallel with the point-density issue.  In a high point density, maneuver-based armies lose their advantages while at low point densities horde armies can't bring their strengths to bear.   The "official" 2-5K point range is a wide enough spread that balance is significantly skewed at the ends of that spectrum and point values are based mostly on the "true" tournament point levels of 2500-3500 on a 6' board.
My suggestion is to keep aircraft in the relative power range of previously published versions.  They should have values in the 150-200 range for interceptor formations, 250-350 for bombers, and ~200 for transports at DC 2-3, carrying 8-10 stands.
Those point ranges are where the 33% restriction on 2500-3500 point armies provide the best overall mix of strategic choice and play balance.  Moving outside of them is most likely going to start to skew air cover one way or the other.  Currently, I see it skewing in favor of taking newer, more surviveable air formations which is then forcing additional flak choices.  While this may end with an overall net balance, it is reducing the choices available to army commanders.
The counter-argument which I can almost hear already is that it will make the aircraft too "generic."  That's possibly true.  However, as EA is based on ground unit combat, do you really want to risk restricting the ground force composition for the addition of a small amount of variety in air cover?  I certainly don't.  Give me the generic air any day.  I'd even be fine with a completely abstrated air support system in a vein similar to the spacecraft.
For the record, this isn't a new idea I recently introduced.  It's been around a while and is not simply a "new army syndrome" response as has been implied on occasion.  There has been a long history of complaints regarding 9-FB formations in the Ork army because they are too surviveable as a whole and I maintained from before publication (along with some others) that the SM Landing Craft was not balanced precisely because of its insane durability versus any reasonable air defense.
PostPosted: Thu Jul 21, 2005 12:44 am
I will verify that Neals statements are correct he did voice his concerns long ago about Huge Ork Air Formations and the SM Landing Craft's durability.
"And thats the way it was"
Walter Cronkite
Jaldon
PostPosted: Thu Jul 21, 2005 3:07 am
While I agree that there is an issue with this, remember that the LAST thing ANY commander wants to do is an opposed air landing, or amphibious assult for that matter.  The defender has all the advantages and even a small amount of damage or a lucky hit to a troop transport in flight (or at sea beyond the surf zone) is going to have disproportionate causualties.
D-Day style assaults are a thing of the past - nobody can afford the losses in men or materiel anymore.  Especially when you can land 20miles away then meet them without that vulnerability.
So how does this get back to Epic?  In a larger game, that means the player should guess the relative amount o flak going to be present and use his lander smartly somewhere on the flank where th AAA will be minimised, or not take it at all.  It is a vulnerability of the platform that the player needs to incorporate into his tactics
Tas
PostPosted: Thu Jul 21, 2005 1:34 pm
So how does this get back to Epic?  In a larger game, that means the player should guess the relative amount o flak going to be present and use his lander smartly somewhere on the flank where th AAA will be minimised, or not take it at all.  It is a vulnerability of the platform that the player needs to incorporate into his tactics.
In fact, I think a lot of people have begun to do so.  I know I have.  The "Banzai" air assault is very effective and therefore quite tempting but I've found that in many cases an outlying or flanking formation works almost as well while allowing much greater preservation of the air assault force.
This conservation seems especially true of Marine players.  I typically see Thawk loads of Assault/Dev or all Dev.  A flanking assault can kill a small formation, provide crossfire, allow the aircraft to take off and provide future support and still leave an effective formation on the ground.  It's nowhere near as flashy as the occasional SHT/Arty intermingled assault target, but the aggregate effect is probably equivalent while maintaining more tactical flexibility.
Then again, the Banzai attack is so much more Orky... :p ...sometimes you just have to do it.
PostPosted: Thu Jul 21, 2005 3:49 pm
Good points, Guys ! Definitely some things to think about ... I agree, that we don't need to make aircraft a very detailed subsystem ... ?In Epic, I generally think we need to stay away from "the F/W IG Syndrome" ... a dozen different versions of the same thing ! ?We're limiting most of our AFV types, for example to one or two. Like the Leman Russ ... if it has a long barrel, it's a Standard L/Russ ... if short, it's a Demolisher. ?:;): ?Aircraft types too, maybe ?two versions of the Lightening, T-Bolt and Marauder ... based on the model ... ?Neal's point values sounds good ... or at least reasonable ... ?:)   And Tas's points about Landing Craft/Forced Entry are valid also ... You have to "be smart" about landings, whether with Drop Pods/Ships etc.  It's easy to lose your assault force if you're not careful !  :o
PostPosted: Fri Jul 22, 2005 1:12 am
Quote (nealhunt @ 21 2005 July,22:34)
So how does this get back to Epic? ?In a larger game, that means the player should guess the relative amount o flak going to be present and use his lander smartly somewhere on the flank where th AAA will be minimised, or not take it at all. ?It is a vulnerability of the platform that the player needs to incorporate into his tactics.
In fact, I think a lot of people have begun to do so. ?I know I have. ?
Great! I really like it when real world stuff proves true on the tabel.  It shows that you have a solid set of rules
The SM air mobile attack is faster, more accurate and leave a "High Guard" available.
You are right - Its not as sexy in terms of weight of metal.  But it is a much more tactically elegant move!  And frustrating when you see it happen to you and you cant do a thing about it.  :p
True. Thats what the Japanese and Russians thought too!  :L
Good dialogue - thanks!
Tas
PostPosted: Fri Jul 22, 2005 5:05 am
Agreed Tas !  And I don't like using air assault troops in a Banzai Charge !  :;):
PostPosted: Fri Jul 22, 2005 2:20 pm
Quote (Legion 4 @ 21 2005 July,21:05)
Agreed Tas ! ?And I don't like using air assault troops in a Banzai Charge ! ?:;):
If you are sending your troops into a meat grinder, does it matter where they die, in the air or on the ground?
Too often the "Bonzai" style attack feels like desperate last ditch efforts. You know, nothing to loose anyway, so use up as many men as you want.
dafrca
              - Cities of Death, page 59
PostPosted: Fri Jul 22, 2005 3:00 pm
Tas:The SM air mobile attack is faster, more accurate and leave a "High Guard" available.
Can you elaborate on that?  I feel like you're making a reference I'm missing.  Is "high guard" a specific tactic?
Dafrca:Too often the "Bonzai" style attack feels like desperate last ditch efforts. You know, nothing to loose anyway, so use up as many men as you want.
That's not desperation for Orks.  It's SOP. :p
PostPosted: Fri Jul 22, 2005 3:24 pm
I try not to do "desperate moves" ! :D
Users browsing this forum: No registered users and 109 guests
