Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 106 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
Blood Axe List
 Post subject: Blood Axe List
PostPosted: Sun Sep 21, 2003 6:33 pm
Hmm...your about 30lbs ahead of me then Legion4, we could make an epic wrestling team together...
...the titans.... :D  :D
PostPosted: Mon Sep 22, 2003 6:09 am
Eat more wings & pizza !  :D  The Titans - good name ... :laugh: We can take on Jervis, Tony, Gav, Andy etc. ... They wouldn't stand a chance !   :laugh:
PostPosted: Mon Sep 22, 2003 3:46 pm
Eat more wings & pizza !    The Titans - good name ...  We can take on Jervis, Tony, Gav, Andy etc. ... They wouldn't stand a chance !
Once we beat them into submission we'll demand them to make the epic models WE would like to see.
PostPosted: Mon Sep 22, 2003 4:34 pm
Works for Me !!! :laugh:
PostPosted: Wed Oct 22, 2003 8:54 am
Noticed that TAS asked about Vanquisher "command" tanks.
As most of my Russes and Chimeras are from the SM-2 era, I've been toying with some ideas on how to represent the two now mandatory command vehicles, the Vanquisher and the Salamander. Frankly, I don't much like an idea of different-looking command tanks if only for the reason that in real life I fear they would be "bullet magnets" very quickly, but converting is always fun so here are my two cents.
First the Leman Russ Vanquisher, "old skool". This one is easy - one day I tried old metal Predator turrets on Russ hulls, and surprise surprise, they fit very well! A bit longer barrel and a very nice, T-55eque round turret with obviously more room for the commander to, well, command. The downside is, of course, that you need old Predator turrets, but they are quite easy to replicate by casting.
Other option would be to build them by yourself - not as difficult as you may think! Few years back I made some originals I was about to use to cast my own Predator turrets and sponsons to get a) Preds from extra plastic Rhinos and b) to get tanks more resembling the old WH40K plastic Predator. Still haven't got around to actually making the molds, but maybe one day...
But I digress. Turrets I made from sawed-off round screw heads with piece of plastic rod, or if you want strenght, brass rod or thin brass tube. This is superglued to the screwdriver slot for barrel, a Rhino bolter hatch is added to the top (in this case, Imperial hatch sprue certainly works better) and the gaps are green stuffed, although any filler will do.
Total work time about 10 minutes a piece. I think all will agree that if you need Vanquishers only for command tanks this will be very acceptable amount of time.
Additional quick-to-make embellishments fitting for a Vanquisher would be, for example, a bore evacuator (or the fat thingy on the middle of the barrel in modern MBTs if I'm wrong on the English terms) from a piece of thin plastic or metal tubing, and some sort of gun shield/recoil mechanism from green stuff. This is especially important if you have new, detailed Russes - the plain Predator-style turret will look somewhat out of place there. ?
Then the Salamander. Those build from the artillery hulls are very, very nice, but the only real idea I have is to build a taller cargo compartment ? la M577 to a bog-standard Chimera, as I don't want to have totally dissimilar transport vehicles in one Company. Green stuff is your friend, but does any of you more talkative friends have better ideas for poor ole Chimeras?
Lastly, for the Executioner I recommend the new-style plastic WH40K plasma pistol, instead of the old round "Black & Decker" one. Not sure which version you guys were referring to in earlier posts, so apologies if I'm stating a known fact here! The new version is available, thinner and more "to scale", especially after some cutting!
-Janne Korhonen
ODERINT DUM METUANT
PostPosted: Wed Oct 22, 2003 11:25 am
Thanks Teekkari, some great stuff there.  As always the problem is finding time, not inspiration, for modelling.
Cheers!
Tas
Tas
PostPosted: Wed Oct 22, 2003 10:42 pm
The M577 is only seen at Bn and above. ?I had an M577 in the R.O.K. as the BN LOC. ?But as a Co. Cdr, my CMD track was an M113 just like all the other tracks in the Co., for a number of reasons, one being as you stated, that CMD vehicles are priority targets ! ? And yes, you are correct in identifying the "bore evacuator" ! :;):
PostPosted: Thu Oct 23, 2003 7:00 am
I have seen the plasma pistol suggestion before, but I think it is too big for the Executioner. It would make a passable plasma blastgun if one was to make a Stormblade.
IMO to make a Vanquisher the simplest method is just to put a long barrel with a muzzle brake to a standard Russ. IIRC the Vanguisher turret isn't any larger than that on a  regular Russ.
PostPosted: Thu Oct 23, 2003 3:37 pm
I've used the plasma gun from the old predecessor to Necromunda, "Confrontation", for an Executioner conversion.  I've used other weapons from that sprue too, to upgrade dreadnaughts also.  They are smaller than the current range of 40k small arms, and fit well into Epic scale.
PostPosted: Sun Nov 02, 2003 9:51 pm
I love 28mm 40k weapons. They make great main armament for 6mm sci-fi AFVs.
I especially love the old Codex Grey laser gun. It looks much better as a 6mm sci-fi weapon than it did as a 28mm small arms rifle.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Thu Apr 15, 2004 12:46 pm
This thread has been archived.
PostPosted: Tue May 10, 2005 7:06 pm
Hey guys.  Over last weekend, I posted a list for the Blood Axe clan on the EA Forum.  I would love to hear some feedback from you guys.  I can also provide a .doc file if anyone would like a copy.
http://www.specialist-games.com/epic/fo ... IC_ID=6391
As a quick teaser:
DESIGN NOTES: The goal of writing a Blood Axe list was to create an army list that is Orky in feel, yet different enough from the core list to give it a distinct flavour and feel. The following were the major ideas that I wished to include:
1) Looted imperial vehicles. I believe this is mandatory for a proper Blood Axe list.
2) In keeping with their background of raiding from spacecraft, I felt there needed to be a substantial Planetfall potential.
3) Create a new concept for Ork armies similar to a 20th century Air Assault force that operates with rapid, helicopter insertion into dangerous areas.
PostPosted: Wed May 11, 2005 4:44 pm
Hi. I noticed this fairly quickly, and I have been looking for the time to go into it in more detail. One thing that I am not sure about is your theory that the Blood Axes would be a 'drop' force. I have not heard this before.
Also, I am not convinced that any amount of Ork tinkering would be able to make a Vindicator (or Hellhound) into a Flak Wagon!  :D  I understand that there are there mainly because they dont have transport, but you have no actual Gunwagons in the force. Is this right, or an I just confused?
I must admit, that my conception of a Blood Axe force is extremely similar to the standard Orks, with the addition of Imperial-type vehicles and a few more Stormboyz.
I am sure that there is an easier way of dealing with the vehicles, either simply having a seperate stat that covers five of six different vehicle types (Predator-type, Leman Russ-type), or applying a standard modifier to the basic normal stat line (for example +5 points, -1 armour, +1 firefight, all ranges reduced by 15cm to a minimum of 15cm, +5cm speed) and then limiting exaclty which vehicles can be purchased (so no Shadowswords for example).
PostPosted: Wed May 11, 2005 5:15 pm
I posted a typo.  Either no one else caught it or they realized what it meant and ignored it.  It should have been:
Gunwagons
Razorbacks
Vindicators
Hellhounds
Predator
I went and edited the thread.
With respect to the standard Ork-conversion modifiers, I considered that, but then that would mean making point costs for all the different variations.  At the very least it would require a Marine-conversion factor and an IG-conversion factor because of the different point structures for the armies, i.e. different initative, strategy and morale rules make the point conversion different.  I made up the Appendix Count-as-IG option for people who really wanted to field Imperial vehicles with minimal modification.
I'm actually strongly considering gutting my entire IG force to make a Blood Axe army that could be fielded either way...
From GW's official fluff:
By means of a few working spacecraft crewed by slaves, and by infesting suitable space hulks, the Blood Axes are able to launch sporadic raids on other Ork clanz. They do this to settle old scores; to capture loot, slaves and Gretchin.
That put the drop-theme in my head and it seemed fun and different than the core Ork list.  The Drop Kan idea is one that I've had running around my head so long I can't remember if I read it in fluff, a friend made it up way back when, or my own demented imagination produced it.  I've even got a mental image of a crunched-down soup-can sort of pod, with a parachute landed haphazardly next to it.
Are there mechanical/balance concerns or is it just the style you dislike?
PostPosted: Wed May 11, 2005 5:29 pm
I like it Jimbo - any Imperial left overs from the Squatachan disease will find an Orky home. I only disagree with CS on one point - a Mekaniak WOULD find a way of making a Vindicator an AA weapon. And I think I'll prove it... :p
Back from oblivion (again)?
Users browsing this forum: Google [Bot] and 91 guests
