Post new topic Reply to topic  [ 81 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Tau and other species
 Post subject: Tau and other species
PostPosted: Thu Mar 11, 2004 7:35 am
Quote (primarch @ 11 2004 Mar.,00:05)
But can the Tau realistically hold off a major Imperial incursion?
Tau cannot defeat the Imperium due to size, but the Imperium could certainly snuff the Tau by sheer weight of numbers.
Don't worry Primarch, the Tau will suddenly develop multitude allied hordes of Demiurg, or yet another hive Fleet tendril will divert attention, or a Chaos thingy will pop up and cement the Imperium and the Tau - at least for the duration of the crisis.
An it has been hinted that the Eldar consider the Tau to have great potential, and the pointy ears usually know what they're doing...
Unless, of course, Tau sales are doing poorly, and the fate of the Squats hangs on their head. but don't worry, like the Squats they'll still live on at Epicomms and a hundred other websites and on a million gaming boards.
Back from oblivion (again)?
PostPosted: Thu Mar 11, 2004 8:21 am
Quote (primarch @ 10 2004 Mar.,23:05)
The Tau empire is in the eastern fringe, outside of the range of Astronomican. That's why Imperium will be forced to use calculated jumps in Tau territory and won't be able to travel as fast as within the range of Astronomican. This means the Imperium has effectively lost the ability to bring the superior numbers to bear on the Tau. And besides, they are more concerned with a couple of Hive fleets, Necrons, Mr. Abbadon...
PostPosted: Thu Mar 11, 2004 6:11 pm
As I said before, a Tau, Eldar, Imperial and Squat alliance would send the rest of the riffraff running !   :o
PostPosted: Thu Mar 11, 2004 8:15 pm
Good point about the astronomicon, that would certainly be a limiting factor.
PostPosted: Thu Mar 11, 2004 10:15 pm
As Tau don't have psyker nor the "navigator gene" they can't enter warp space but whith using computers and AI they can "skim the surface" of the warp and by so they are 1/3 as fast as there imperial counterparts when it comes to "warp travell" they are much safer, hope that made some sense...
The old Lie: Dulce et decorum est
Pro patria mori.
PostPosted: Thu Mar 11, 2004 11:17 pm
If the Tau could make a computer that replicates the navigator function, I think the Imperium would be in serious trouble.
Even chaos would go down the tubes without a fertile race to possess.
PostPosted: Fri Mar 12, 2004 3:16 am
Quote (primarch @ 11 2004 Mar.,22:17)
Well, I don't think the Tau would go on a genocidal spree, and as such there would still be humans and around, and I'm sure some of them would be discontent enough for various reasons to turn to the Chaos gods.
PostPosted: Fri Mar 12, 2004 5:21 am
A few months back, in W/D, there were Chaos "possessed" Tau conversions ... no one is safe ... :ghostface:  }:)
PostPosted: Fri Mar 12, 2004 8:05 am
I don't think they can. In order to "see" the warp you have to have psychic awareness; you can't move in warp for long periods with calculations alone as warp is not called the realm of CHAOS for nothing. Computers don't have that awareness as they can't have any psychic ability.
PostPosted: Fri Mar 12, 2004 12:16 pm
The Tau will 'adopt' psychic mercenaries.
PostPosted: Fri Mar 12, 2004 7:05 pm
How can the tau be possessed if they are not psychically aware?
PostPosted: Fri Mar 12, 2004 7:14 pm
I don't know ? ??? ? But I saw it a few months back in a W/D ... I'll see if can find the issue in my Black Library, later ... ? ? ? :;):
PostPosted: Fri Mar 12, 2004 9:18 pm
Good, let me know.
PostPosted: Sat Mar 13, 2004 3:13 pm
And this is the biggest problem that I have with the Tau. Yes, the are not psychically aware, and yes a Tau was possessed (by a Tzeentch Greater Daemon). However, this was a 'shoehorn the fluff to fit the rules because they are cool' event as the Codex Daemonhunters had just been released.
The entire situation was just dumb, in my opinion.
PostPosted: Sat Mar 13, 2004 4:48 pm
Found the Tau intell ... W/D 278, pgs. 62 & 66.  Article entitled "The Downward Spiral", basically says, the Tau are naive and a G/Deamon in physical space could "convince" them, especially the renegade Tau.  There are pics of the Tau with G/Deamons of Tzeentch and Slann ... pretty neat !  And W/D 283, pgs. 84 & 85 show models of an Ethereal and Battle Suit "possessed" by deamons !  As I said ... no one is safe ... :ghostface:
