Post new topic Reply to topic  [ 102 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
The increasing power of aircraft
 Post subject: The increasing power of aircraft
PostPosted: Thu Jul 21, 2005 1:34 pm
So how does this get back to Epic?  In a larger game, that means the player should guess the relative amount o flak going to be present and use his lander smartly somewhere on the flank where th AAA will be minimised, or not take it at all.  It is a vulnerability of the platform that the player needs to incorporate into his tactics.
In fact, I think a lot of people have begun to do so.  I know I have.  The "Banzai" air assault is very effective and therefore quite tempting but I've found that in many cases an outlying or flanking formation works almost as well while allowing much greater preservation of the air assault force.
This conservation seems especially true of Marine players.  I typically see Thawk loads of Assault/Dev or all Dev.  A flanking assault can kill a small formation, provide crossfire, allow the aircraft to take off and provide future support and still leave an effective formation on the ground.  It's nowhere near as flashy as the occasional SHT/Arty intermingled assault target, but the aggregate effect is probably equivalent while maintaining more tactical flexibility.
Then again, the Banzai attack is so much more Orky... :p ...sometimes you just have to do it.
PostPosted: Thu Jul 21, 2005 3:49 pm
Good points, Guys ! Definitely some things to think about ... I agree, that we don't need to make aircraft a very detailed subsystem ... ?In Epic, I generally think we need to stay away from "the F/W IG Syndrome" ... a dozen different versions of the same thing ! ?We're limiting most of our AFV types, for example to one or two. Like the Leman Russ ... if it has a long barrel, it's a Standard L/Russ ... if short, it's a Demolisher. ?:;): ?Aircraft types too, maybe ?two versions of the Lightening, T-Bolt and Marauder ... based on the model ... ?Neal's point values sounds good ... or at least reasonable ... ?:)   And Tas's points about Landing Craft/Forced Entry are valid also ... You have to "be smart" about landings, whether with Drop Pods/Ships etc.  It's easy to lose your assault force if you're not careful !  :o
PostPosted: Fri Jul 22, 2005 1:12 am
Quote (nealhunt @ 21 2005 July,22:34)
So how does this get back to Epic? ?In a larger game, that means the player should guess the relative amount o flak going to be present and use his lander smartly somewhere on the flank where th AAA will be minimised, or not take it at all. ?It is a vulnerability of the platform that the player needs to incorporate into his tactics.
In fact, I think a lot of people have begun to do so. ?I know I have. ?
Great! I really like it when real world stuff proves true on the tabel.  It shows that you have a solid set of rules
The SM air mobile attack is faster, more accurate and leave a "High Guard" available.
You are right - Its not as sexy in terms of weight of metal.  But it is a much more tactically elegant move!  And frustrating when you see it happen to you and you cant do a thing about it.  :p
True. Thats what the Japanese and Russians thought too!  :L
Good dialogue - thanks!
Tas
PostPosted: Fri Jul 22, 2005 5:05 am
Agreed Tas !  And I don't like using air assault troops in a Banzai Charge !  :;):
PostPosted: Fri Jul 22, 2005 2:20 pm
Quote (Legion 4 @ 21 2005 July,21:05)
Agreed Tas ! ?And I don't like using air assault troops in a Banzai Charge ! ?:;):
If you are sending your troops into a meat grinder, does it matter where they die, in the air or on the ground?
Too often the "Bonzai" style attack feels like desperate last ditch efforts. You know, nothing to loose anyway, so use up as many men as you want.
dafrca
              - Cities of Death, page 59
PostPosted: Fri Jul 22, 2005 3:00 pm
Tas:The SM air mobile attack is faster, more accurate and leave a "High Guard" available.
Can you elaborate on that?  I feel like you're making a reference I'm missing.  Is "high guard" a specific tactic?
Dafrca:Too often the "Bonzai" style attack feels like desperate last ditch efforts. You know, nothing to loose anyway, so use up as many men as you want.
That's not desperation for Orks.  It's SOP. :p
PostPosted: Fri Jul 22, 2005 3:24 pm
I try not to do "desperate moves" ! :D
PostPosted: Fri Jul 22, 2005 10:39 pm
Quote (nealhunt @ 22 2005 July,07:00)
Can you elaborate on that? ?I feel like you're making a reference I'm missing. ?Is "high guard" a specific tactic?
The first time I heard the term used was to describe the fighters that flew as protection for the bombers in WWII. The person used it in such a way that made me think they were literally flying above the bombers, it made sense to me, below them would be a bad place to be when the bombs started to fall.  :laugh:
dafrca
PostPosted: Fri Jul 22, 2005 10:43 pm
That's not desperation for Orks. ?It's SOP. :p
:O
Too true Neil, too true.  :laugh:
dafrca
PostPosted: Sat Jul 23, 2005 1:02 am
Tas:Quote ?
Sure neal. ?As dafrca has explained, its is the positioning of a reactive force above the enemy which can be used in support of your main effort. ?It is a generic concept which was used amongst others by 8th Air Force bomber escort forces. ?However it is a prinicpal rather than a tactic, and a principal from which certain tactics become possible
It was also a crucial concept in Blitzkrieg. ?An aerial service onc all to ground forces to soften up tough targets, strike rear areas or prvide air coverage against other fighters (known sometimes today as CAP = Combat Air Patrol, or DCA = Defensive Counter-Air).
So back to the example, what I was suggesting is that the points you have spent on the SM air assualt give you rapid insertion to anypoint on the board and then a highly mobile gun platform which can be used either in support of the landed elemenst or anyone else. ?Just its presence provides a big threat.
On theother hand the Superheavy assault, whle very nasty (and yes I do love my Superheavies! :) ) is still located on a single piece of real-estate. ?You know if anyone has cover or is out of range from him, you are safe.
EDIT: Of course in EA the true "High Guard" position is in orbit over he battlefield.  From there the enemy can just obliterate everything - you are relying on him wnating the real-estate and putting troops in to take it rather than just vaporise your troops...which wouldnt be a very fun wargame at all really...
Tas
PostPosted: Sat Jul 23, 2005 4:35 am
Yep !  CAP is kind of the modern version of the term  !  So back in my old Air Assault days in the 101, in front of the assault/lift ships (UH1H Hueys) carrying Grunts were the Cav in pink, red and white Teams. White = OH-58 Scout ships known as "Loaches" (light observation choppers), Red = AH1s Cobras known as "Gunslingers".  And OH-58s & AH-1s together = Pink.  Along with the UH1Hs were AH1s from an Attack Helo Bn.  So the SM Thunderhawk almost fills all roles, closer to a Hind-D, really !
PostPosted: Sat Jul 23, 2005 5:34 am
Think of the "1st/9th Air Cav Air Moble" attack in "Apocalypse Now".  Excellent exmple of observation helo/Attack helo/Troop Lift co-op.
"Charlie Dont Surf!!!!" :cool:
Tas
PostPosted: Sat Jul 23, 2005 5:39 am
You got it, Tas ! :;):  We even had speakers mounted on one of our New UH-60 Blackhawks in Central America !  And "Flight of the Valkyries" blared over the Darien Jungle ! :laugh:
PostPosted: Sat Jul 23, 2005 6:17 am
Too kewl!
I've done that going up the Mekong River delta on a Destroyer, with the "Good Morning Vietnam" soundtrack over the Upper Deck broadcast - very LOUD! :p
:D
Tas
PostPosted: Sat Jul 23, 2005 2:05 pm
Quote (Legion 4 @ 23 2005 July,04:35)
CAP is kind of the modern version of the term ?! ?
IIRC, the term "Combat Air Patrol" was first used in WWII.
